Old 11-03-2019, 01:38 PM   #1
17rsvert
17rsvert's Avatar
Drives: 2017 HBM 2LT RS Convertible V6 A8
DIY blue and white footwell lighting
My car came without a lighting package, no spectrum lighting or courtesy footwell lighting, so I added a budget version.
I wanted to keep the installation as OEM as possible, so the first challenge was to find lighting that would fit the existing light cutouts. Not as easy as it sounds. I ended up buying blue SMDs on EBay, but no luck finding a 1/4 turn lamp socket that fits a 16mm hole. The sockets I bought on Amazon were listed as fitting a 16mm hole, but actually fit a 13mm hole. I made snap-on bases for them out of 1/8 inch thick PVC (cut with a band saw) and the 3 layers are held together with PVC cement. The SMD wires run through a hole in the base, and is held on with 2-part black epoxy. Since the OD of the round sockets I bought were just under 16mm, I decided to use them. I made my own 1/4 turn mounts for the sockets out of the same 1/8" PVC using a dremel tool. Those 2 pieces are epoxied to the socket.
Shown here with connector leads (red/black) soldered on and covered with heat shrink tube. The connector is the same that comes on the SMDs.
17rsvert is offline   Reply With Quote
Old 11-03-2019, 01:54 PM   #2
17rsvert
17rsvert's Avatar
Now that I had the lights, it was time to make a wire harness. I used a single pole, double throw rocker switch to be able to switch the lights off, white, or blue. One end of the power lead (red/black 2 conductor wire) has 2 thin gold colored pins soldered on to tap into the power lead and ground. The other end attaches to the common on the rocker switch, and ground to the light wires. The two leads that go to the lights are 3 conductor for ground, blue light, and white light. At the end are female connectors that will accept the lights. All connections are soldered and heat shrunk. If you zoom in you can see the blue SMD glued to the snap-in PVC base.
Old 11-03-2019, 02:16 PM   #3
17rsvert
17rsvert's Avatar
Installation on the drivers side is easy, the passenger side, not so much. There are three 4mm screws that hold the drivers side trim panel in place, but once removed the panel did not drop down easily. The seat side of the panel has a lip that wraps over the air bag module, preventing it from dropping. There is not enough clearance behind the panel on the firewall side to get the lip free of the air bag. I ended up loosening, but not removing the 2 screws that hold the air bag. By loosening the screws, I was able to drop the airbag about a half to 3/4 inch, enough to get the panel lip past it. I was able to drop the front of the panel enough to work over it, but the I never figured out what was restricting the back.
There is enough clearance through the center console to feed the wire from the driver side to the passenger side, just gently poke a stiff wire through to use as a snake and tape the end of the harness to it to pull it through.
Once the passenger side lights are mounted, the connections can be made to the harness and the panel can be put back. There are some wiring harnesses that I had to move to the side of the A/C vents so the panel would fit back properly.
On the drivers side, I used the dremel tool and a small file to cut the rectangular hole for the rocker switch. Picture shows it mounted under the dash, next to the center console.
Old 11-03-2019, 02:32 PM   #4
17rsvert
17rsvert's Avatar
Rather than cut into the existing wies to tap into them, I kind of cheated. The gold colored pins on the end of my harness wedge between the plastic and metal in the existing electrical connector. The existing black wire is black wire is ground, and grey is the courtesy light circuit. The connector is easy enough to get to, if I have a problem with reliability of my connection, I can always re-do it.
Here's a picture of the lights in place and the connection points.
Old 11-03-2019, 02:38 PM   #5
17rsvert
17rsvert's Avatar
Hitting the rocker switch enables me to switch between blue or white light, or turn them off completely. These are courtesy lights, so they come on when a door is open, and fade slowly after about 10 seconds. They also go on if the interior lights are turned on using the rotary light switch on the dash.
Old 11-03-2019, 05:11 PM   #6
Trochoidal
Drives: 2017 Camaro 2SS A8
You did a good job with your install and it looks great. The best part is the integration to your stock door plunger and the dimmer switch.
Old 11-03-2019, 06:31 PM   #7
DIYguy
DIYguy's Avatar
Drives: 2017 Camaro 1LT
Smile
Very nice.
Glad that you did everything robustly (heat shrink and soldered).
It should be trouble-free.
Gen6 Camaro LT (my daily driver), Cruze ECO (grocery getter), Chevy SS Pickup (wife's daily driver), Honda Shadow, Honda CBX
DIYguy is offline   Reply With Quote
Old 11-04-2019, 04:31 AM   #8
17rsvert
17rsvert's Avatar
Originally Posted by DIYguy View Post
Very nice.
Thanks for your help looking for parts!
Old 11-04-2019, 06:29 PM   #9
17rsvert
17rsvert's Avatar
By request, here's links to some of the parts:
Blue leds
https://www.ebay.com/itm/T10-6-SMD-6...edirect=mobile
Wedge base led socket
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Single pole, double throw rocker switch
If you're patient and want to save a few bucks, I'm sure you get this stuff cheaper on Ebay shipped from Asia.
The only problem with the lights is they don't fit as-purchased. I had to build the snap-in bases for the blue LEDs and modify the bulb sockets to fit.
The wire, shrink tube, connector pins, and 2 pin led connectors I already had from other projects.
Old 11-04-2019, 11:05 PM   #10
STYLO LT1
STYLO LT1's Avatar
Drives: 2016 Camaro SS Vert.
Great job! Looks awesome! 👏👍🏻
STYLO LT1 is offline   Reply With Quote
Old 11-10-2019, 08:22 AM   #11
17rsvert
17rsvert's Avatar
Thanks!
Old 11-11-2019, 03:45 PM   #12
Drew145022
Drives: 2017 Camaro 2SS Vert
This looks so good I think I will have to do this with white and red
Drew145022 is offline   Reply With Quote
Old 12-28-2019, 05:25 PM   #13
nystyle246
Drives: camaro 1SS
hell yeah!!!! just ordered all my parts
nystyle246 is offline   Reply With Quote
Old 01-30-2020, 06:51 PM   #14
17rsvert
17rsvert's Avatar
Get anywhere with your project?
