Old 07-04-2018, 08:51 AM   #99
Glen e
Retired from Car mfrs....
Glen e's Avatar
Drives: 2LT RS/HR-V
Not sure what you expected from any valve when you bought it. Live with a valve through few oil changes and you'll appreciate it. A copper crush washer is used on many high-end cars instead of Rubber. It'll last longer, it seals, but it's impervious to heat. And there is a very simple way to take off the filter without making a mess, using a tall kitchen garbage bag, do a search here.
Old 07-08-2018, 06:00 AM   #100
VinnAY
Drives: 18 1SS/1LE
Too many oil changes over my lifetime that never had a valve and I never made a mess of things. The best thing a valve does is lighten your wallet but props to any one that likes them.
Old 07-08-2018, 10:08 AM   #101
enzia35
Drives: '16 Garnet Red 1SS
It’s a small cost over many years.
'16 Camaro 1SS
'18 Miata GT
Old 07-08-2018, 03:14 PM   #102
Gunmetalmissle
Drives: 16 ngm ss
I use a Stahlbus on cars that have the drain plug in a difficult to reach location. Makes it so much easier. I’ve debated buying one for the SS even though it’s in a convienient location already.
Gunmetalmissle is offline   Reply With Quote
Old 07-10-2018, 08:47 AM   #103
Gabhart
Gabhart's Avatar
Drives: 2018 Hyper Blue 1SS 1LE
Race Ramps is the way to go for oil changes. Also recommend a magnetic drain plug. I installed one from Dimple
Gabhart is offline   Reply With Quote
Old 07-13-2018, 06:02 AM   #104
Cheekster96
Cheekster96's Avatar
Drives: 2018 2SS Bright Red
Where do you guys get your magnetic oil pan drain plug from? I seen some from Amazon but do not know the metric thread sizing.
Coming up soon on my first oil change.
Lee
Lee
Cyr Plantation,ME>>>boonies
2018 SS Camaro
2022 Silverado 2500HD Big Red
Cheekster96 is offline   Reply With Quote
Old 07-13-2018, 09:25 AM   #105
Laststandard
Drives: 2018 1SS 1LE
M12x1.75
https://www.amazon.com/Needa-Parts-6...eywords=653096
I purchased that one from Amazon.. fit just fine. Can't bring myself to spend $30 on the fancy anodized one.
2018 1SS 1LE (sold)
Laststandard is offline   Reply With Quote
Old 07-14-2018, 04:18 PM   #106
Cheekster96
Originally Posted by Laststandard View Post
M12x1.75
Thanks!!
Lee
2018 SS Camaro
Old 07-28-2018, 07:20 AM   #107
breakskeet
Kevin
breakskeet's Avatar
Drives: 2018 Callaway Camaro ZL1 1LE
Oil filter torque spec for my Corvette Z06 is 22 lb.ft. Most likely it it the same for the Camaro.
breakskeet is offline   Reply With Quote
Old 07-28-2018, 07:28 AM   #108
BurningMan
BurningMan's Avatar
Drives: 2017 Camaro 2SS / 2012 CBR1000RR
I use a Stahlbus oil drain valve, and a FilterMag oil filter magnet.
BurningMan is offline   Reply With Quote
Old 03-16-2019, 07:01 PM   #109
wintertopdown
Drives: 22 Convertible V8 LT1
The madness
This first DIY oil change has been an all day and now night affair.
I purchased the ramps from Harbor Frieght and they worked great. I did need to remove the rubber guards before driving up otherwise they would get caught while driving up.
The 15mm drain bolt was extremely overtightened and stripped both externally and the internally. At last a “bolt extractor” was able to loosen this monster. The filter was also very tight and required a pair of vice grips to rotate.
Below are photos.
MARS Auto had the bolt I needed and the AMSoil. My local Advanced Auto Parts has Mobile 1 and Castro’s, Penzoil, Royal Purple, etc but my gut told me to go with the brand I use in the bike. The Harley certainly came in handy too because I went back to harbor freight multiple times. The staff hooked it up, cash is king.
wintertopdown is offline   Reply With Quote
Old 03-17-2019, 01:07 AM   #110
wintertopdown
A shot of the clean oil pour completes the series
Old 03-17-2019, 01:21 AM   #111
wintertopdown
Took the car out and first thing I noticed was how calm the reverse behaves. The exhaust is smoother and has less harsh attack. It performs well up to 7000 rpms where it pulls in forth to 100 and immediately followed by fifth gear smooths out nicely. 6th cruises by at 65mph around 25-32mpg peak 35mpg.
Old 03-20-2019, 02:49 AM   #112
The Specialist
The Specialist's Avatar
Drives: 2018 Summit White Camaro SS 1LE
Originally Posted by Kevjud View Post
I changed the oil in my SS this morning. Probably one of the easiest cars I have changed oil on. A set a inexpensive Rhino Ramps is all you need.
I'll be ready to change out the oil on my 18 1LE in a few weeks.
I have a set of ramps, though, they're only 5" High.
What is the height of your Rhino's, and did you have to make stairs in front of them to clear your spoiler?
I've looked at the long two piece Race Ramps online at 8" in height. $300.00 seems like a lot for a few extra inches.
Thanks,
The Specialist is offline   Reply With Quote
