12-02-2020, 02:19 PM | #15 | |
Evil Genius of Chevrolet
Drives: 2017 Z06, 2019 XTS, 2013 SS Join Date: Feb 2017
GPI SS2 VVT cam, ECS Novi 1500 supercharger, Corsa Extreme, Detroit Speed and BMR suspension, Circle D triple disc, Melling oil pump, LS2 chain tensioner, ATI 10% UD, DSX E85 kit, High Energy coils, BTR springs, LS2 Lifter trays, Titanium retainers, hardened push rods, FIC 1000 injectors, ZL1 pump, Mighty Mouse catch can, AEM gauges, Tial BOV, Richmond 3.91 gears, Custom gauge bezels, Speed Engineering headers, Stainless Works HF cats, DSX Aux pump, 710rwhp on E85.
12-02-2020, 02:22 PM | #16 |
Drives: 2010 SS L99 Join Date: Sep 2018
I went with the ADM cooler, works great no issues
Previous PB:11.079 @ 122.99mph.. New setup time: TBD
The 11.079 pass: https://youtu.be/pz27Zq54t_E Build thread - www.camaro5.com/forums/showthread.php?t=555371 |
12-02-2020, 02:32 PM | #17 | |
12-02-2020, 02:35 PM | #18 |
Same here, on the highway I have no issues at all, nice and smooth at 75-80mph. Locks up at 55 in 5th gear..Cruises at 1600-1800rpm.
12-03-2020, 08:47 AM | #19 | |
Drives: 2010 Camaro 2SS Join Date: May 2016
It’s the one without the bypass for cold weather.if I was in an area that got cold for extended periods of time I would have went with the lpd4739 because it comes with the bypass for cold weather. |
12-03-2020, 02:54 PM | #20 | |
12-03-2020, 04:04 PM | #21 | |
Circle d also makes a good converter. I just went with Fti because I got a good deal on it. And yes you will have to get a trans tune done once you install the converter. Neither one will have shuddering or a studder feeling if tuned correct no matter which stall you choose.You could easily run a 4200 stall on this car and with a good tune would have no ill effects except the engine revving higher when you start out and a fuel mileage drop. Not saying that’s what you want or need just don’t go with a different stall then your combo needs for fear of it shuddering or stuttering. |
