02-15-2019, 05:34 PM | #1 |
Drives: ‘15 Z/28 550/1801, AC/Radio, Black Join Date: Aug 2017
Thoughts/experience with Goodyear F1 SC 3R tires.
Hey all, long time lurker. I’ve seen lots of posts on people switching to less track oriented rubber, but I was wondering about the Goodyear F1 Supercar 3R’s that come on the ZL1 1LE.
https://www.tirerack.com/tires/tires...8&autoModClar= They’re still streetable competition tires, a lot cheaper than the Trofeo’s, slightly better wear rating (though not directly comparable from one manufacturer to another), has anyone tried a set? Thanks for any and all info.. |
02-15-2019, 06:15 PM | #2 |
Drives: 2012 BMW 135i Join Date: Nov 2016
I’ve written a track and road review if search for my posts. Short summary: mega fast: 1.5 second a lap faster at Dominion then my trofeos (unfortunately conditions were different but the trofeos doesn’t tolerate early throttle like the 3r). 305 appear to be wider then 305 trofeos. Handle early throttle on track better then trofeos. Worse cold grip. Tram less then the trofeos. Street noise is about the same. I ran a 2:04.4 with them at vir. I see no reason to buy trofeos with these available.
02-15-2019, 07:15 PM | #3 |
Ah yes must have missed that in the search. Very promising!
02-17-2019, 02:23 PM | #4 |
Life Is Short Enjoy It!
Drives: Original Owner 15 Z/28 #934 Join Date: Sep 2016
I also have them and for the money much better value than Trofeo's - they do everything well, but wet - since you are in S. Cal like me - I think this is your best overall option for the money.
02-17-2019, 05:15 PM | #5 | |
I’ll just have to wait out the wet weather, and all the fun roads being strewn with mud and rocks |
02-17-2019, 08:23 PM | #6 |
Drives: 2015 Z/28 #0058 Join Date: Apr 2018
PS4S transform the car on the road. Really enjoyable ride/noise/manners. As well as cold/wet weather confidence
Current:
- '15 Z/28 #0058 | White | A/C | Speakers | Michelin PS4S 305/30/19's - '22 Ridgeline RTL | White | Ebony, '22 CR-V EX-L Hybrid | White | Ebony Sold: - '15 Z/28 #0048 | White | A/C | Speakers | Michelin PS4S 305/30/19's https://www.instagram.com/__jon__athan__/ |
02-17-2019, 10:40 PM | #7 | |
A PS4S, R888R, RE71R, RE11 (or whatever the replacement is now) will be a much better "cold" street tire. With all that said, it behaves on the street just like a trofeo. So if you know what you're getting into with Trofeos (and why) then this is a great choice. For circuit cross I'm considering a 325 R888R. |
02-18-2019, 06:48 AM | #8 |
Even the PS4S guidelines says it's not meant for cold weather...
"The Pilot Sport 4S excels in warm dry and wet conditions, so like all Max Performance Summer tires, is not intended to be serviced, stored nor driven in near- and below-freezing temperatures, through snow or on ice." "Tires exposed to temperatures of 20 degrees F (-7 degrees C) or lower must be permitted to gradually return to temperatures of at least 40 degrees F (5 degrees C) for at least 24 hours before they are flexed in any manner, such as by adjusting inflation pressures, mounting them on wheels or using them to support, roll or drive a vehicle."
Current:
02-18-2019, 07:19 AM | #9 |
Drives: . Join Date: Jun 2016
Not heard much comment on Michelin Pilot Sport Cup, Cup+ or Cup2 on this forum.
I'm running the older Cup+ in Porsche 'N' specs at the moment. They're: - better than the Trofeo's on the road (less stiff, less tramlining) - not quite as fast on track, but wear less - better in the wet than Trofeos - better in cold temps than the Trofeos (I got caught in snow and survived!) Unfortunately I'm not sure the Goodyear F1 Supercar 3R is going to make it to Europe for me to be able to do a comparison with that tyre. I'm probably going to try to latest Michelin PS Cup2's in 'N' spec next... |
02-18-2019, 08:12 AM | #10 |
Raging Bull Reborn
Drives: '09 CGM Z063LZ '15 RH Z/28 #0631 Join Date: Mar 2012
I run Michelin cup 2's on my 09 Z06; and I was putting them on my Z/28 in thes spring, as the stock Trofeo R's are at 3mm; hey once they are warm..they stick like crazy, otherwise make sure its 60F..as too much power and they chatter as you slide. Five miles at highway speed and they warm up.
However I was considering staying with the Michelin cup 2's for these reasons: 1.they only weigh 1 more lb per wheel than the trofeo r's 2.they come in 315 width, which will fit both ends of the car in an unstaggered fitment 3.They wear well, my Z06 shows only slight wear after 3000 miles, I'm expecting 12500 to 15000 miles??
Toy 1 '15 RH Z/28 w/AC & Radio S/N 0631 Toy 2 '09 CGM Z06 3LZ My DD: '17 Ford Mustang GT Her DD: '14 F150 Ecoboost 3.5 |
02-18-2019, 12:20 PM | #11 |
Drives: 2015 Z28 Join Date: Nov 2016
I have 3Rs. Better than the Trofeo in almost every respect.
Quieter Cheaper Wider Wear (TBD) but good so far The only thing they may not be as good as the Trofeos is wet traction. Not that I've gotten squirrelly with the 3Rs, the Trofeos just seem to stick better in the wet. |
02-18-2019, 03:27 PM | #12 | |
I’m out winter league r888r, re71r and the contis seem to do the best between 15 - 40 degrees. I haven’t seen a damaged tire from the aforementioned mentioned group in 3 years. My supercars saw a few miles of snow before setting a 2:04.4 the next day at vir, again, no damage. However, I drove a buddy’s focus st with RS-3s to show him the line at Shenandoah and they were literally hockey pucks. It’s fair to say, 500hp and sub 40 degrees don’t mix |
02-19-2019, 11:49 AM | #13 |
Drives: 2015 Z28 Red Hot Join Date: Jan 2017
They're great tires and as mentioned they are better than the Trofeo's. Less warm up time on the track too. I highly recommend them
02-22-2019, 10:10 PM | #14 | |
Drives: 2015 Z/28 #898 Join Date: Oct 2016
