04-10-2018, 02:43 PM | #1 |
Drives: 2016 Summit White 2SS Convertible Join Date: May 2017
PLEASE HELP WITH OFFSETS
Could somebody please shed some light on this for me? I am obviously not very bright, as I am having trouble understanding offset. I want to run the 285/30/20 on 20x10 wheels and 305/30/20 on 20x11 wheels set up. I see many people running the 23 offset in front and 43 offset in rear with this set up. I phoned to order wheels and was told that the best offset for me would be 25 in the front and 33 in the rear with those tire and wheel sizes that I mentioned earlier. Is this true? What will the 25 offset in front and 33 in rear do compared to the 23 and 43 that most people run? I know the stock off set for my 2SS is 25 in front and 39 in back, but that is with narrower wheels. Please help, as I want to order wheels right away....
Adrenaline red leather, A8, Magnetic ride control, Dual mode exhaust, Black Bowties, body colour hood vents, Sema grill, front wind splitter, black SS center caps, low gloss black wheels
04-10-2018, 03:11 PM | #2 |
Drives: Summit White 2016 2SS Join Date: Jan 2015
I have 10'' wide front and rear, at 25 mm offset, the fronts fit fine with 285's, as for the wider rears, someone else will have to chime in.
2015 1LE sold
2016 2SS sold |
04-10-2018, 04:10 PM | #3 |
SABIO
43 in the back is the 'standard' for an 11". This would place the wheel flush with the fender.
The furthest I have seen is 38mm. Some like just a little more. But 33mm... hmmm. That would be too much in my opinion. 43mm. Pokes out 15mm. Flush. 38mm. Pokes out 20mm. I like this one. 33mm. Pokes out 25mm. :( A 10" in front is tight. 23mm fits. A 25mm moves it 2mm closer to the strut. Could be tight enough that you might need a small space. Which is not a huge deal. Are these custom cut wheels? Or are they selling what they have in stock...that will kinda fit.?
04-10-2018, 04:15 PM | #4 | |
2015 1LE sold
2016 2SS sold |
04-10-2018, 04:22 PM | #5 |
SABIO
Well there you go. 25mm up front is peachy
Up to you to decide on the rear. Search for 25mm space. Some have done it. You can see what it looks.like.
04-10-2018, 05:19 PM | #6 |
Drives: Camaro 50th anniversary edition Join Date: May 2017
The 20 and 43 is the 1LE OEM wheel.
Front- 285/30-20x10 ET20 OEM 1LE. Rear - 305/30-20x11 ET43 OEM 1LE. Less ET more poke out 43 = flush 38 poke out a bit 33 poke out a lot
Soleil
_____________________________________________ A car is fast enough, if you fear to unlock it in the morning." (Walter Roehrl) |
04-11-2018, 06:10 PM | #7 |
Thank you very much for all the help guys. I just ordered up the 20x10 with a 23 offset and a 20x11 with a 43 offset wrapped in Nitto NT555 G2's. 285/30/20 front and 305/30/20 rear.
04-11-2018, 06:11 PM | #8 |
The info you guys gave me kept me from being sucked in to buying wheels that would have stuck out WAY to far.
04-11-2018, 06:16 PM | #9 |
Drives: 17 1SS 6MT, 09 Tacoma TRD Sport Join Date: Nov 2017
04-11-2018, 08:22 PM | #10 |
SABIO
Glad all of us could help. That is why this forum is here.
04-11-2018, 08:53 PM | #11 |
Drives: 2016 Camaro RS 1LT 2.0L Turbo Join Date: Apr 2016
I'm not sure if offset changes with different diameter wheels...but this coming weekend I will be installing FS01's with a 10mm spacer in the rear and 5mm in the front.
The wheels are a 25mm offset. Ill add a pic to this thread once they're on. (Extended dorman studs will be going on the rear). Essentially it'll be what a 15mm in rear and 20mm in front offset looks like. I also run -2.2° front/ -2.5° rear camber, and lowered.
'16 1LT 2.0T RS - Catless DP, Intake, Tune/ Eibach springs FE3 shocks/ BMR front bar FE4 rear bar/ Xpel'd front end, CP Reload sealed/ Radenso Pro M.
04-11-2018, 09:24 PM | #12 |
Drives: 2016 SS w/2SS A8 Blue Velvet Join Date: Dec 2009
I'm running a 23 offset with the 285 20x10 30 up front and a 305 20x11 30.
The fit is perfect and I'm also lowered 7/8" on all 4 corners.
Never grow up, it's a trap!
04-11-2018, 10:14 PM | #13 |
SABIO
Hey. Good old Blue Velvet making an appearance.
Sweet color. Your wheels cant be 30mm in the back. They would poke out something huge.
04-11-2018, 10:31 PM | #14 | |
No they’re not...... my rears are a 43mm offset and 23mm up front
Thread Tools | |
