Old 11-26-2020, 04:34 PM   #1
Konnerfallos1
Drives: Camaro
Camaro door pad question?
Hi guys, I recently had a unnamed friend in my car and he scratched the top leather pad on the door pretty bad. For reference it is the larger one that goes up over the door and almost to the window itself. I am wondering if anybody knows if that individual piece is replaceable and if it is what is the part number for it? I didn't really like the factory black ones anyways so maybe some aftermarket company makes cooler ones im not sure, but I am looking to replace it so any suggestions would be appreciated!!
Konnerfallos1 is offline   Reply With Quote
Old 11-26-2020, 07:27 PM   #2
Jb54
Drives: 2019 Camaro SS M6
I don't believe that is a replaceable piece. Think you would have to buy a whole new door panel. You could also go to an upholsterer and see if they could fix it. Probably be cheaper that way.
Jb54 is offline   Reply With Quote
Old 11-27-2020, 07:21 AM   #3
Camaro_QC
Camaro_QC's Avatar
Drives: 08 Tiburon GS, 2018 Camaro 2.0T
Can't be replaced unless you remove the door panel and undo the plastic welds which is a PITA.
Reupholstering it would require the same work.
Get a new door panel it might be cheaper.
2018 Camaro LS | 6 spd | 2.0L turbo | Nightfall Grey | RS package | Technology Package.
Order WDGHKX
1100 - 5/08/2018 | 3800 - 6/18/2018
2000 - 5/09/2018 | 4200 - 6/21/2018
3000 - 5/28/2018 | 5000 - 6/27/2018
6000 - 6/29/2018
Camaro_QC is offline   Reply With Quote
Old 11-27-2020, 12:37 PM   #4
Petrol Head
Drives: Fast if no one's looking
The door card is only available as one complete assembly as seen below. It would be between $230 and $360 depending on what options you have and your color.
https://www.gmpartsdirect.com/v-2019...rim-front-door
Petrol Head is offline   Reply With Quote
Old 11-27-2020, 07:03 PM   #5
craigss50
craigss50's Avatar
Drives: 2017 Camaro SS Fifty
I had a bottom panel redone in my C5 which required melting out the plastic welds and rewelding. Only cost me $100 each door card. So it may be less expensive to have a auto upholster redo it. The only issue may be getting it to match the other door card.
craigss50 is offline   Reply With Quote
