Old 04-23-2022, 01:53 PM   #43
Idaho2018GTPremium
Idaho2018GTPremium's Avatar
Drives: 2021 Camaro ZL1 A10
Originally Posted by Camaroking98 View Post
Yes I can do performance shift mode, seemingly just fine. But again, I do move the shifter to the left. When I do, I pull back on it. It should downshift, it doesn't. I try clicking the paddles. No response, whether I tap them or hold them down...it makes no difference. No response.
Sounds like this is something that should be covered under the powertrain warranty right?
If you put the shifter in the left position and nothing happens w/ the paddles or by moving the stick forward and back, then yeah, it seems like something is wrong.
2021 Camaro ZL1 A10
2022 GR Supra 3.0
Past:
2018 Mustang GT Premium w/ PP1, MR, and A10
2007 MazdaSpeed3
1995 Pontiac Trans Am
1987 Camaro Z28
Idaho2018GTPremium is online now   Reply With Quote
Old 04-23-2022, 03:06 PM   #44
Camaroking98
Drives: 2019 ZL1
I hope since this is technically a drivetrain issue that it's covered under warranty. I've got an appointment at a dealer scheduled for may 3.
Camaroking98 is offline   Reply With Quote
Old 04-23-2022, 03:31 PM   #45
Vigilante375
Drives: 2018 Camaro ZL1
Have you made sure you're in track mode and not pressing the gas pedal and also not have the cruise set? Have you tried all this plus in D or manual mode?
Old 04-23-2022, 06:20 PM   #46
Idaho2018GTPremium
He said his paddles don't respond at all when in manual mode. You don't have to be in track mode to use the paddles, and they should respond no matter how far or not the gas pedal is pushed. They also can be used whether in auto or manual mode. The difference is in auto mode it will default back to auto after a few moments compared to when the shifter is in manual mode, it will stay in manual and hold the gear as long as you want.
2021 Camaro ZL1 A10
2022 GR Supra 3.0
Past:
2007 MazdaSpeed3
1987 Camaro Z28
Old 04-23-2022, 06:33 PM   #47
SATINSTEEL1LE
Drives: 21 ZL1
Remember you are likely in like 8th or 10th gear. When I do this, I have to click the paddle a bunch of times to get all the way down to something managable.
SATINSTEEL1LE is offline   Reply With Quote
Old 04-23-2022, 07:22 PM   #48
Vigilante375
Ah. I see the post I missed on the last page where he was talking about that. I was still fixated on the hold for 3 seconds to lowest gear talk.
Old 04-23-2022, 07:32 PM   #49
Idaho2018GTPremium
Yeah, no worries. Regarding the 3 sec to lowest gear talk...I find in my '21 ZL1 it essentially only takes about 1 second, and it can be done while in any mode (tour, sport, track), as long as the shifter is in manual position. It also works (tested today) whether the gas pedal is at 0% or pushed down. I went to ~1/3 throttle today in 6th or 7th at about 40 mph, and then held the paddle down, and it jumped to 2nd gear 1 second later. I know I've done it in the past beyond 1/3 throttle. It's a very responsive feature for me.
2021 Camaro ZL1 A10
2022 GR Supra 3.0
Past:
2007 MazdaSpeed3
1987 Camaro Z28
Old 04-23-2022, 09:34 PM   #50
Camaroking98
Drives: 2019 ZL1
Yes, I've tried literally everything I can think of. Has to be some sort of computer issue with the trans not wanting to give me access to manual mode when I follow the right steps.
