Old 08-19-2018, 05:30 PM   #15
zr1chris
zr1chris's Avatar
Drives: 2018 Camaro 1SS/1LE
Originally Posted by avalonandl View Post
Will have dealer change it at next oil change. I pay people to do this stuff now....old and gray....LOL
Will make sure they add the 88900330 AC Limited slip LUBE too....
Don't need the additive if they use the correct fluid.
zr1chris is offline   Reply With Quote
Old 08-19-2018, 07:36 PM   #16
speedup
speedup's Avatar
Drives: 2017 2SS Convertible
Probably going to do this soon, just want to make sure I get the right stuff,
88862624 (ACDelco 10-4034 Dexron LS 75W-90 Gear Oil) is what the manual says I need, do I also need to add the limited slip additive?
looks like 1.2 quarts of fluid needed
that all ?
2017 2SS, Hyper Blue, 8sp, NPP, MRC
speedup is offline   Reply With Quote
Old 08-19-2018, 07:38 PM   #17
zr1chris
zr1chris's Avatar
that all ?
From the research I've done on this... It's already in it. That's what the LS stands for.
Old 08-19-2018, 07:45 PM   #18
Rock-It Man
376 cubic inches of fun
Rock-It Man's Avatar
Drives: 2023 Camaro ZL1 A10
It's a legitimate question.
Gen 5 Camaro and Gen 6 Corvette required an additive even though the oil was "LS".
However, the current "LS" oil in the the current GM performance rear axle requires no additive.
This information is and has always been in the Owner's Manual. No guessing required.
Old 08-20-2018, 09:53 AM   #19
modru2004
Drives: 2018 2ss
my 18 2ss with 5500 miles has developed the rear diff groan. gonna take it to the dealer once it starts getting cooler. it only happens on the rare morning it gets really cool. so until it can be reliably reproduced on a cool morning im just gonna wait.
modru2004 is offline   Reply With Quote
Old 08-20-2018, 10:15 AM   #20
shawndean22
Drives: 2017 Camaro 1LE
30k miles, still haven't changed mine....
shawndean22 is offline   Reply With Quote
Old 08-20-2018, 10:37 AM   #21
torqueaddict
Drives: Tesla M3 LR-AWD [Former 1SS owner]
The common denominator in most if not all of theses cases seem to be cooler weather so probably a viscosity issue. I would guess people in hotter climates need not worry as much.
torqueaddict is offline   Reply With Quote
Old 08-20-2018, 10:44 AM   #22
whiteboyblues2001
whiteboyblues2001's Avatar
Originally Posted by dfmoeller View Post
Just looking for some opinions. My 2018 2SS M6 Camaro just turned over 3000 miles. I've heard suggestions that limited slip differentials should have their fluid changed anywhere between 500 miles to 20,000 miles. What is the consensus on this?
Thanks.
Doug
Early Gen 6's had an issue with "rear end groan" in which the rear axle made some noise. Generally it was cleared up with a fluid change. I changed mine (2016) early and had no issues (take that for what it's worth).
So, it certainly won't hurt, and in this case, may even prevent a known issue. My advice is to change it. You will be surprised at what comes out after break-in.
whiteboyblues2001 is offline   Reply With Quote
