10-17-2020, 12:52 AM | #1 |
Drives: Chevy Camaro 2017 Join Date: May 2019
Ls7 Lifter & TspVVT3 cam
8kmiles now with the .645/.635 cam. Took it on a roadtrip From texas to LA & back. No issues so far. Just curious when should I replace the ls7 lifters I installed with the cam. I have titanium dual valvesprings so I don’t plan on replacing them till maybe 35k+ miles since those can handle up to .660. Or any recommendations? To keep it reliable with this big cam.
10-17-2020, 01:32 AM | #2 |
Drives: 2016 2SS coupe 2015 3LT Stingray Join Date: Aug 2012
I would go with johnson or morel lifters ls7 lifters are not designed for those spring pressures high lift cams
Ported intake manifold and throttle body kooks 2" headers no cats
10-17-2020, 02:13 AM | #3 |
10-17-2020, 08:00 AM | #4 |
Depends on what you go with...both Johnson and Morel make drop-in lifters that work with factory trays.
2016 NFG 1SS A8
10-17-2020, 08:05 AM | #5 |
I’m gonna go ahead and say if it sounds and runs ok, don’t touch it. Ideally you run the appropriate lifter from the start but no way I’d tear into it until first signs of an issue. Plenty of ls7 lifter cars out there surviving.
10-17-2020, 01:16 PM | #6 |
I just started learning more about internals. I don’t want the ls7 lifters failing on me and then it breaks my cam or something. Was hoping maybe someone with better knowledge than me would know if im fine or not fine. Its stock 6500rpm limit so it’s nothing excessive.
10-20-2020, 12:21 AM | #7 |
You can get seop in lifters but I would still chamge the trays rhey are only 10
10-20-2020, 02:50 PM | #8 |
Drives: 2018 Camaro SS 1LE Join Date: Jul 2018
I'm a bit interested in these...care to expound?
10-20-2020, 08:30 PM | #9 |
Drives: 17 2SS, 8L90, Cam, Heads, E85 Join Date: Dec 2016
