Old 10-23-2020, 12:36 PM   #57
OB0001
2018 SS A8 11.85@117.06
OB0001's Avatar
Drives: 2018 Camaro SS A8 "Dark Knight"
Originally Posted by lt4camaro View Post
Can you show me where you drill and tap for the brake vacuum port. Also do the stock bolts work OK? are they long enough? . Any other quirks as I am going to do this myself. Thank you in advance.
here ya go
DARK KNIGHT
2018 SS A8 11.85 @ 117.07 GPI Tuned E85 stock tires Roto Fab CAI LT 2 intake
OB0001 is offline   Reply With Quote
Old 10-23-2020, 02:55 PM   #58
lt4camaro
lt4camaro's Avatar
Drives: 2021 LT1 10 speed auto
Originally Posted by OB0001 View Post
here ya go
That looks like the drivers side rear corner of the intake. Where did you get the fitting? Thank you again
lt4camaro is offline   Reply With Quote
Old 10-23-2020, 10:18 PM   #59
Fraxum
Fraxum's Avatar
I think it is something like this...... (Maybe) THe collar compresses and pull really hard to remove.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
I did buy this part just in case but GPI already did it for me. They do not charge all that much for the mods so why bother unless you enjoy the crafting.
Old 10-24-2020, 07:38 AM   #60
lt4camaro
lt4camaro's Avatar
Thank You, yeah I always do my own stuff. I am a self taught mechanic and body and paint. I tweak every performance car I have had to always just make it faster, quicker than it should.
Old 10-24-2020, 10:09 PM   #61
Fraxum
Fraxum's Avatar
Cool. Let us know how it goes.
Old 10-28-2020, 12:25 PM   #62
Fraxum
Fraxum's Avatar
i am in touch with Rotofab to see if we can better fit a Rotofab CAI with the LT2 IM.........
Old 10-28-2020, 12:41 PM   #63
OB0001
OB0001's Avatar
Mine fit better than the original IM
DARK KNIGHT
Old 10-29-2020, 04:30 PM   #64
Fraxum
Fraxum's Avatar
Wierd. I wonder if there are small RF differences. I think mine is one of the original GEN6 RFs with the sound tube hole. I plugged that. I traded my ZL1 rf for it.
Old 10-29-2020, 04:44 PM   #65
s346k
s346k's Avatar
Drives: like an old lady
i also had no issues with the rf and stock tb on LT2 manifold.
Old 10-30-2020, 02:23 PM   #66
ButcherSS
I purchased my LT2 Intake from GPI. I clearanced the bottom, tapped the brake line fitting and ported it myself. I picked up 2 mph on my very first run at Atlanta Dragway over my ported Pray LT1 manifold. My Rotofab didn't fit like before but still sealed. My car started and idled normally at first start up.
ButcherSS is offline   Reply With Quote
Old 10-30-2020, 02:53 PM   #67
lt4camaro
lt4camaro's Avatar
Nice gain for sure, good going ButcherSS. BTW how easy is it to unhook the vacuum brake feed connection from the original intake? I had trouble a few years ago unhooking that line from my 2015 C7. Any tricks you can share would be appreciated.
Old 10-30-2020, 03:11 PM   #68
BlackbeastSS2
BlackbeastSS2's Avatar
Drives: 2019 Camaro 1LE Shock Candy
I felt the same way you mentioned above in regards to previous car I had when I took off that line on my 2016. Then when I traded it in I had to fight with it when I replaced it.
This time I left it on the original manifold and ordered a new line for the LT2.
Description:Brake Vacuum Hose
Part Number: 23409532
Quantity:1
Price:$25.71
103 Katech TB, KATECH Custom Heads, DSX In-line fuel
TSP Headers, Spec P Super Twin Clutch, TSP EL C7 CAM
Diamond Piston & Manley Rods, Roto Fab Big Gulp
BTR Push Rods,LS7 Lifters, ARP, FI Chiller, Kirkey Seats
SJM Line Lock, Hurst Pistol Grip. 747/739 RWHP street tune - 821/794 RWHP track tune 101 octane.
2014 Mini Cooper countryman S All4 M6 daily driver
BlackbeastSS2 is offline   Reply With Quote
Old 10-30-2020, 03:19 PM   #69
lt4camaro
lt4camaro's Avatar
Quantity:1
Price:$25.71
So you disconnected the brake vac line from the Booster?
Old 10-30-2020, 04:50 PM   #70
ButcherSS
I followed my brake vacuum line out and unhooked it from that end located on the driver's side engine compartment. I left the brake vacuum line hooked to the rear of my intake, then pulled my intake off. It was a breeze to unhook the vacuum line from the rear of the manifold with the manifold removed from the car. I used the same fitting as pictured above and my vacuum line didn't fit as deep as the factory push lock.
