05-23-2020, 07:14 AM | #1 |
Drives: 2018 ZL1 , 2020 GMC AT4 Carbon Pro Join Date: Apr 2019
Front end clicking/ popping?
I think I may have seen this mentioned before, but I can't find it anywhere. I've noticed that when I back into my garage, the front end, especially the drivers side, has a clicking noise. It seems to be mainly when I'm turning the steering wheel. Has anyone experienced this? If so, what did it turn out to be and is it something that poses a danger to driving the car?
05-23-2020, 07:19 AM | #2 |
unfortunately it is pretty common and it happens mostly in reverse. No known fixes but check the basics or have the dealer investigate.
05-23-2020, 08:13 AM | #3 |
Drives: Buick Grand National, BMW M5 Join Date: Nov 2019
Check wheels lugs. I head they were torqued at 80 lbs but should be 120 lbs.
05-23-2020, 09:21 AM | #4 |
Drives: 2019 ZL-1, Shadow Gray, Sold Join Date: Jan 2019
Lugs should be at 140 ft lbs.
05-23-2020, 10:12 AM | #5 |
Drives: 1971 Chevy Camaro Join Date: Dec 2016
Let me weigh in on this. We just returned from a 2400 mile trip and spent 4 days on the Tail of the Dragon. Clean the hub behind the center cap really well and blow out any particles with an air hose. Apply a super thin layer of anti seize to the hub where the rotor slides over as well as the backside of the rim’s mounting surface. We experienced no noise whatsoever after pushing really hard on the Dragon all 4 days.
05-23-2020, 12:24 PM | #6 |
Most of the hub clicks are simply clicking in a turn or u-turn. The front end click is a separate item but check the hubs first.
05-23-2020, 01:38 PM | #7 |
Drives: Red hot ZL1 A10 2017 Join Date: Nov 2016
Clean
Re-torque https://static.nhtsa.gov/odi/tsbs/20...82871-5448.pdf Same topic next page .... https://www.camaro6.com/forums/showthread.php?t=573959 |
05-25-2020, 11:19 PM | #8 |
To fast is not enough
Drives: 2019 ZL1 Camaro & 2020 CT5-V Turbo Join Date: May 2019
Do what crossroaddemons says and troubles are over. That's what to do. Torque to 140 Lbs
Thread Tools | |
