03-06-2020, 09:39 AM | #1 |
Drives: 2019 1LE/ss 2014 ss/rs summit white Join Date: May 2016
Meth/procharged
Currently running a d1x with 10lbs of boost. Curious on what meth kit I should run(alky). What nozzles, how many, set area, and most of all why should I?
No other mods other then d1x. Cars also a 1le will be doing a LT4 fuel upgrade also(fyi) Last edited by s3rics213; 03-09-2020 at 10:35 AM. |
03-06-2020, 09:48 AM | #2 |
Drives: 17 Camaro SS 1LE & 16 Sierra AT CC Join Date: Nov 2016
Have you changed out any of the stock fuel system at all?
2017 Camaro SS 1LE - Procharger D1SC w/ Tial 2" BOV & Race intercooler / ARH full length catless headers / Alky meth injection system - 650rwhp on conservative tune SOLD |
03-06-2020, 09:49 AM | #3 |
If the engine is still on the stock fuel system then you have a ticking time bomb on your hands. You definitely need the Meth kit asap for fueling, cooling, and octane. 10lbs is pushing the octane wall of 93 with the LT1's high compression and well past the stock fuel systems limits.
2016 NFG 1SS A8
03-06-2020, 10:40 AM | #4 |
Drives: 2017 Camaro SS 1LE (F1A-94 FBO H/C) Join Date: Jun 2017
if your installing your own meth kit i'd go alky as it comes with install instructions compared to the RPM custom kit i bought, its definitely not as advertised. Some stuff missing. I'd upgrade stock fuel system though, and internals if your trying to push more power. Right now i'm having a DSX Aux fuel issue, doesn't appear to be turning on so car isn't getting enough fuel.
Performance Mods: F1A-94, DSX Flex Fuel Kit, MSD Spark Plug Wires, KOOK 2" off road headers, MBRP Race catback exhaust, Pray Performance Custom Boost Cam, Rocker Arm Trunion Upgrade Kit, 7.850" Hardened Chromemoly Length Pushrods and Johnson Racing 2110R Lifters, TSP CNC'd Heads, Ported MSD intake manifold, 103mm Katech Throttle body, Forged Pistons/Rods, RPM Meth kit, DSX Aux Fuel system, AEM Failsafe and banks gauge, LT4 HPFP, LT4 injectors, BMR motor mounts, Hurst Short Throw, Manley SS exhaust valves
Videos of my car? Check here: https://www.youtube.com/channel/UCNi...Qy1OL4NVGlPogw |
03-06-2020, 11:05 AM | #5 |
Cars a 1le and internals and what not will be changed later. I’ll only need to do high side and injectors when I get around to it. But back to the concern about meth size and amount of nozzles.
2019 ss/1LE d1x, LT4 fuel System, Triple meth nozzle, ported BTR, 2” Texas speed headers, Built 377 SPDC motor, CTporting heads, TooHighPsi port system, SMG aux.
1014/800 on E55/meth 890/750 on 93/meth Working on tuning the port system for full e. With questions just message me here for a faster response. https://www.facebook.com/eric.willia...ibextid=LQQJ4d |
03-06-2020, 11:31 AM | #6 |
High side and injectors should be your number one priority at this point.
2016 NFG 1SS A8
03-06-2020, 12:28 PM | #7 |
Drives: 2017 50th Camaro SS Join Date: Jul 2016
Just did the Alky Control MAP based system with dual #10 nozzles. Install wasn't bad. You have to bend the pump attachment strap to clear the fender.
50th Anniversary Edition |Borla Atak and 60606 mid pipes| Kooks 1 7/8" | ProCharger Stage II |305/45/17 DRs | Circle D 3500 stall | LT4 fueling | Custom made Lowside Aux Pump | Alky Control Meth | DSX E85
03-06-2020, 01:33 PM | #8 |
Thank you for answering what I asked lol. I may do a in trunk tank.
03-06-2020, 02:31 PM | #9 | |
a Meth system as a fuel supplement is Dancing on the Landmines. Lots of people been there done that and bought the farm. Ted.
www.jannettyracing.com
03-06-2020, 02:39 PM | #10 |
My intank pump should be fine being the lt4 pump. I don’t want it as a fuel sup. The tuner I’m going through said to going dual nozzle, just never replied to why I should.
03-06-2020, 06:22 PM | #11 |
He has a 1LE so it already has a LT4 low side... just needs LT4 high side and a JMS booster.
2016 NFG 1SS A8
03-06-2020, 07:07 PM | #12 |
Thanks man and yeah ik about the fuel side of things just was trying to get more of a input on meth. Haven’t seen anyone post what size injectors they go with and why. Not trying to have meth as a fuel sup but more for what it’s intended with temps. I’ll be able to run e occasionally. ( not all to knowledgeable on meth, I get how it works just haven’t looked to much into it) just know I’ll be talking with my tuner tomorrow and see why he said that I need to be 2 nozzles.
03-07-2020, 05:28 AM | #13 |
I just realized why you've gotten away with the stock LT1 hpfp and injectors, your location of New Mexico. The higher altitude means thin air so you are not making the kind of actual power at 10psi of boost that we'd expect at low altitude.
As far as meth injection, dual nozzles to me means a lot of fuel. If you truly want the system more for cooling than for fuel supply, then I would suggest instead a water/methanol injection system (like AEM or Snow) and use windshield washer solvent. This would mean a lower amount of methanol was being injected, as the solvent is around ~35% methanol at the -20º formulation from what I've heard. The water would do a lot of the cooling. |
03-08-2020, 12:19 PM | #14 |
I Understand this, I've been looking into the lt4 fuel area just trying to find the best deal and to make sure they are the correct parts. I understand ill need to get the fuel upgraded thats being bought Monday, reason for this is to see why my tuner was saying to go dual nozzle(unless he's wanting it as a fuel additive). I don't want meth to sup fuel cause thats a nightmare, was originally trying to stay away from it. Ill be doing the injectors and hpfp, which will be needed anyways for the level ill be at to run e. Running meth will not be a all the time thing either and don't want to depend on it, so wanting to see what system to go with to no do that. to my understanding alky is the the(only kit) to use.(they're other out there ik that)
Tags |
d1x, meth kit, pro charger |
