12-01-2022, 12:08 PM | #1 |
Drives: Track prepped 2018 Camaro ZL1 (a10) Join Date: Aug 2013
WARNING headers melting wire harness $6,000 later and entire car interior stripped
Because my 2" ceramic coated headers melted the wiring harness in the engine bay (that runs from one end of the car to the other) I had to have the entire thing replaced which involved removing literally everything from the inside of the car and more...
The dealership said the wiring harness was too close to the headers and someone had pulled it off the wall, but I've heard other members say it needs to be moved regardless. Not sure but either way, I thought I'd post this in case it helps someone else avoid this happening to them
2018 ZL1; Mag 2650 and 2 inch LT Headers , every SPL suspension upgrade, MCS 2 way coilovers, sway bars, square SC3R 325's all the way around, and multiple brake cooling upgrades
12-01-2022, 12:16 PM | #2 |
Drives: 2019 Chevy Camaro ZL1 M6 Join Date: Jul 2019
Wow, sounds like defective ceramic coat. I don’t think it should get hot enough to do that with the coating.
Kong Stage X Port, NW103, LPE HPFP, XDI +30 Injectors, ARH Headers, Flex Fuel, JMS Booster, AWE Touring, Elite E2-X CC. Stock heads, stock cam, stock pulleys: Tuned by KingLT1. 740whp Uncorrected on e50
12-01-2022, 12:31 PM | #3 |
Drives: 18 ZL1 - M6 Join Date: Mar 2019
OMG!!! As someone that’s going to have headers installed soon, is there anything in particular that I should ask the installer to do and/or make sure is performed during or after the header install? Extra heat wrap, rerouting wires, etc.? Sorry brother
12-01-2022, 12:32 PM | #4 | |
Drives: 2021 Red Hot ZL1 Join Date: Sep 2020
12-01-2022, 12:53 PM | #5 |
Drives: 2023 ZL1 A10 Join Date: Nov 2021
Sorry to here , another member here has a Thread same thing , I think he's repairing his same harness. I've used this Header Turbo wrap before, on my 1970 Camaro fuel supply and return lines, that were close to the passenger side Header. The headers were jet hot coated, and as stated above after sitting off for a bit you could touch , but not running (personal experience) and the engine compartment didn't have no where near the components in our cars , to hold the heat and very little air circulation.
Is the Dealership going to add protection wrap or relocate or both to the area? Also ask the Dealership if the job there doing is under warranty. A suggestion. Or are you going to remove and reinstall the stock manifolds . That would be horrible if happens again. Sorry for your misfortune. TC
2023 ZL1 A10 Shadow Gray Metallic
12-01-2022, 01:01 PM | #6 |
Drives: 2017 zl1 Join Date: Apr 2021
Before i wold have ripped the whole car apart i would have cut that section out and repaired all the wires. Done properly would have no issues and saved you a bunch of time and money. Sucks it happens.
KOOKS LONG TUBES AWE EXHAUST ROTOFAB FLEX FUEL 55% E TUNE PORTED THROTTLE BODY |
12-01-2022, 01:05 PM | #7 | |
12-01-2022, 01:32 PM | #8 |
Drives: 2017 ZL1 Join Date: Mar 2022
Would love to have someone post pics of the reroute that is supposed to happen when you put headers on.
12-01-2022, 01:44 PM | #9 |
This was a few years back , Don't think they had the 2500f coating, I purchased top of the line , or at least I thought I was. Thought I'd reply, didn't want , to think I was talking about there 2500f or latest coating.
12-01-2022, 01:46 PM | #10 |
I did my own install of ARH ceramic coated headers. I didn’t have to relocate any wiring and I have had nothing burned or melted by the headers. I recently drove the car 1800 miles over 2 days and still no issues.
12-01-2022, 01:48 PM | #11 |
Looks like they were actually touching. A coating isn’t going to matter if that was the case.
Not to be a jerk but There’s posts back in 2016 stressing to move that harness
12-01-2022, 01:57 PM | #12 |
Drives: '86 IROC-Z '18 ZL1 Join Date: Jul 2019
When I put my headers in, I was debating on putting the harness behind the coolant overflow or not. The biggest thing I see where people could mess up is the harness has to plastic connections that pop I to the body and keep it secure. If those were to break abd the harness was loose, it could totally get way to close to the header abd melt.
That being said, I track my car and the harness stayed secured in those connections. |
12-01-2022, 02:16 PM | #13 |
No worries, just clarifying. I think the next coating below the 2500f is 1300f.
12-01-2022, 02:17 PM | #14 |
