08-15-2022, 10:10 AM | #15 | |
08-23-2022, 01:45 PM | #16 |
Ok, so we increased the TCC line pressure to 200 psi and that seems to be doing the trick.
Getting lockup at WOT now.
08-24-2022, 07:59 AM | #17 |
Petro-sexual
Thanks to everyone for following up and sharing. I'm still learning, too. I left much of these settings alone, except for bumping pressures a bit, but knew there could be better strategies out there. Thanks for contributing everyone!
08-24-2022, 10:27 AM | #18 | |
With a higher stall I would probably consider locking the part throttle shifts again depending on how loose the converter is. WOT shifting, locked should trap higher, but that doesn't always mean you will run quicker. The 4-5 shift on a A8 drops quite a bit of RPM. So, would staying unlocked be "quicker" on a centri car that will drop 4-5psi on the 4-5 shift locked vs remaining unlocked and only dropping 2-3 psi on the shift? I haven't tested that but would be curious to know. Side note, I assumed that you upped the line pressure when the converter was changed. That is tuning 101 really. High stall converters slip more until locked(if lockable). In order to get the clutches to grab they need more pressure applied.
2016 NFG 1SS A8
08-24-2022, 02:40 PM | #19 | |
I dont have any pulls where the converter was completely unlocked with the Rick Clarke tune for comparison. It just had a constant slip of 250 rpm. I want to say with my previous tune which was completely UNlocked at WOT, I saw a 3-4 psi drop.
08-24-2022, 10:51 PM | #20 |
That sounds backwards from how it should be. Locked converter will drop to a lower rpm on the next gear vs unlocked and converter slipping to a higher rpm.
2016 NFG 1SS A8
08-25-2022, 07:15 AM | #21 | |
The only fair way to do this would be locked vs unlocked with the same engine tune.
08-26-2022, 10:30 AM | #22 |
I didn't have time to capture a bunch of screenshots, but I did look back through my old logs last night and compared with recent ones. Happy to do the legwork if specifically requested, but here's my conclusion.
In my case, with TCC *unlocked* and with torque mgmt *on* during a shift, there was a consistent 3 psi drop between gears in 90 degree ambient. With TCC *locked* and torque mgmt *off* during a shift, there was a consistent 2 psi drop with same ambient temp. What would it look like with TM off and TCC unlocked? I'm not sure. I've concluded the difference is that there is also a noticeable dip in rpm with TM on during the shift compared to with it off... so final conclusion is that powering through the shift and the slight amount of wheelspin was what was really keeping the rpms and psi up through the shift. If I had DR's and no wheelspin... I bet I'd see more psi drop.
08-26-2022, 09:38 PM | #23 |
So I've been going over my logs too. Unlocked, the rpm drop isn't quite as bad vs locked. Unlocked will keep you in higher boost & rpms during shifts. But at a price. You're slipping the converter and thats not putting it to the ground.
I ran back to back tests. I had "normal/tour" set to lock and "Pattern B/Sport" to unlocked. Both lock in 4th though. **TM & Torque Reduction are disabled** I did 40-110, 50-120. The converter locked was quicker everytime...barely. BUT...It was shifting early on the locked run. I was shifting 2-3 @ 61 mph and 3-4 @ 90 mph for BOTH locked and unlocked. Here's an example of difference locked vs unlocked: taken from WOT pulls. 60 mph unlocked is 6369 rpms 60 mph locked is 5981 rpms 90 mph unlocked is 6646 rpms 90 mph locked is 6265 rpm so you can see you need to set the shifting differently as with our cars, the shifts are based on mph and not rpm. When the converter was Unlocked, it was perfect...shifting at about 6800-6900. Locked it was shifting at 6500-6600...way early. So if I were to increase the 2-3 to 63 and the 3-4 to 93, there would've been a bigger difference in favor of being locked. I do love the feel of driving around with the converter unlocked. So what I ended up doing is: Set Tour to run unlocked for DD. WOT is set to lock in 2nd. why not Set Sport to unlocked for DD. WOT set to unlocked until 4th for dig racing. TUTD is set to locked (Stock apply/release settings) this is for roll racing, and set the shifting to 31/63/93/118 I really don't know when to lock the converter when racing from a dig. People seem to not want to share that info. My gut tells me to try to lock it in 2nd. Closest 1/4 mile track is many hours away, so kind of hard to test dig racing.
New Mods - GPI drop ins, Kooks 2", LT4 fueling, Cam, Circle D Converter, 3.5 pulley & dual nozzle meth. Last edited by grampa_ss; 08-28-2022 at 02:31 PM. |
09-26-2022, 11:40 PM | #24 | |
Drives: 17 2SS, 8L90, Cam, Heads, E85 Join Date: Dec 2016
I haven't noticed any differences in any tables in the TCM besides of course the TM switches and the higher desired shift times. |
09-26-2022, 11:43 PM | #25 | |
I know this was a more recent table HPT added for this specific reason, I think others reported that it did work, but its not working for my OS. |
09-27-2022, 12:32 PM | #26 |
Yeah, desired pressure table. I dont have my tuning pc on hand so I dont know the table number.
