03-05-2017, 01:34 AM | #1 |
Drives: One of the baddest handling Gen 5s Join Date: Feb 2011
My modded Z28 arms
Hey guys, I am feeling lonely and need some compliment but trolling is also welcomed for laughs. Now do you like what I did to my Z28 toe arms. As you can see I reinforced them for increased stiffness.
03-05-2017, 03:42 AM | #2 |
Drives: . Join Date: Jun 2016
No trolling here, that looks great.
Did you have it jigged when you welded it though? Or have you checked the welding hasn't distorted it..? I was looking at the Pfadt suspension components the other day, they look good - strength gains and mass reduction and they have some sort of GM approved certification apparently. |
03-05-2017, 06:55 AM | #3 | |
03-05-2017, 08:35 AM | #4 |
What kind of material did use i.e. flat plate or channel. I have a set of arms in the garage that I could have done.
Orange Krush II
03-05-2017, 02:45 PM | #5 |
Raging Bull Reborn
Drives: '09 CGM Z063LZ '15 RH Z/28 #0631 Join Date: Mar 2012
more to the point..which alloy did you use. I'm guessing you use a hi tensile steel?
On corrosion, you've now created hidden areas where corrosion can get in and rust. Personally I'd use zinc rich inorganic on the base (the zinc in the coating is sacrificial); followed with a zinc rich epoxy, followed by an epoxy coating. Alternately you might find someone in your area who can spray apply (plasma spray) a zinc coating onto your parts. Ideally you should weld all edges of the added metal to prevent having any crevices where rust can occur; then you just need to paint what you can see.
Toy 1 '15 RH Z/28 w/AC & Radio S/N 0631 Toy 2 '09 CGM Z06 3LZ My DD: '17 Ford Mustang GT Her DD: '14 F150 Ecoboost 3.5 |
