02-17-2015, 01:55 AM | #15 |
Drives: 2012 SS/RS Join Date: Jul 2013
On what I've read here before I wouldn't trust the by or Megan racing ones on a road course. I'm sure they hold up just fine if you don't beat them up too much.
02-17-2015, 10:38 AM | #16 |
Drives: 2022 1SS 1LE A10 BCD WCT+PDR Join Date: Mar 2008
If I am buying coilovers so I can exploit my car on the track, I am buying a quality piece. RideTechs have gotten high reviews, have a great warranty and bang for the buck, they would be my first choice with Pfadt second.
02-18-2015, 03:00 PM | #17 |
Drives: 2010 2SS CGM Camaro, 1988 6.6L IROC Join Date: Mar 2010
I have the lightweight Padt coilers now and had the Koni Yellows been available at the time I would have gotten the Konis. That or if I had the money Penske. Ridetech worked with Fox Racing and is basically Fox inside of the Ridetechs. Koni, Penske, Bilstein and Fox all have years of pedigree vs Pfadt who I had initial hiccups with additional services I prepaid for and they stumbled on fulfilling, then went belly up when I needed replacement parts and had to outsource from other vendors. Doing a search revealed others having issues after Padt went belly up and had to go to outside vendors for resolution as well. Koni, Bilstein and Penske have MANY authorized shops more than capable of rebuild and revalve services. It would take a lot for them to go belly up and even if they did, plenty of shops who can work on them and they use a lot of common seals and valving parts available outside of Koni, Bilstein and Penske. Pfadt sported too many unique parts only Pfadt would have to deal with. Even though Padt is supposedly coming back, with issues with simple service requests I had prepaid for and took numerous tries before they fulfilled to what we agreed, I wouldn't trust them to do a simple, basic service let alone a revalve. If Ridetech ever went belly up like Pfadt did, which I really don't see happening, Fox Racing would be able to do service and revalve.
While BC and Megan are good for the street I'd still take a set of Konis yellows and a good set of springs over them. There were just too many BC and Megan owners having random issues within a year. I've had Konis from the early 90's that have only required basic servicing to bring back to out of box performance. Sorry for the rant. Every time I see the name Pfadt, it kind of brings back the frustrating conversations with them... |
02-18-2015, 03:09 PM | #18 | |
02-18-2015, 08:39 PM | #19 | |
I had an adjuster break on one of my '95's Konis. They replaced it no questions asked. They are a solid company. And I completely believe that sometimes you have to pay for quality. I just need to decide whether I want to spend another grand for the RideTechs vs Apex/Pfadts and Konis
02-18-2015, 09:08 PM | #20 |
Drives: '16 C7 Z51 Join Date: May 2012
Keep in mind, Z/28 suspension package is $3439 shipped, but besides the shocks and springs, it also has all major control arms F/R as well as sway bars. If you don't need to change ride height for some reason (I don't), it's a great alternative! In a way, you just buy the kit and call the suspension mods/adjustments done (besides perhaps cradle bushing?).
'16 Corvette C7 Z51 1LT (Build Thread)
'14 AGM 1SS 1LE [COTW 11/17/14] (Build Thread) (SOLD) '13 Mazda MX-5 Club (Build Thread) '17 RAM 1500 Crew Cab 4x4 Night Edition '15 Nissan Rogue S AWD |
02-18-2015, 09:23 PM | #21 |
Yeah Z/28 package is a great package. With Koni coming out with the Yellow dampers with springs, sway bars matched to your year (no need to buy the additional control arms unless you want to change to outboard mounted rear bar) and bushing kit can still be about a $1000-$1500 less than the Z/28 kit. Nice to have more options as opposed to when the 5th Gen first rolled out...
02-18-2015, 09:42 PM | #22 |
Drives: Camaro Justice Join Date: Jun 2007
There is no comparison in the operation of the DSSV valving to a Koni yellow. Compare a Koni Yellow to 1LE struts. RideTech selected Fox as a partner because of the quality or the product and the availability of repair parts and service.
Why anyone would upgrade in inboard rear sway and not replace it? |
03-01-2015, 07:30 PM | #23 |
Drives: None Join Date: Jan 2015
Looks like they are on sale right now, you can get all 4 for $682 shipped.
03-01-2015, 07:52 PM | #24 |
Drives: One of the baddest handling Gen 5s Join Date: Feb 2011
03-01-2015, 07:54 PM | #25 |
03-01-2015, 07:58 PM | #26 | |
03-01-2015, 08:11 PM | #27 |
Has anyone tried just using the Z28 struts in place of their 1LE struts? Without buying the entire Z28 kit, they are about $700 each.
03-01-2015, 08:24 PM | #28 |
I'm not sure one can buy just the Z/28 struts alone and as stated in the above post by L99CAMA2011, valving is important. Since the Z/28 spring/strut assembly is significantly stiffer to the 1LE spring (or even other drop springs for that matter), that may be a bad mismatch.
