07-29-2021, 01:04 PM | #15 | |
Dyno Show Queen LOL
08-01-2021, 08:33 AM | #16 |
Drives: 2018 Camaro SS Join Date: Sep 2009
08-01-2021, 09:15 AM | #17 |
Dyno Show Queen LOL
He used straight meth.
Honestly all the Cars I pat attention to in Houston I've never seen any mix water with it. I think the mixing goes more towards the imports. It's probably less dangerous used as cooling vs making up for an inadequate fuel system. I can remember from 2010 to 2014/15 people sprayed for cooling primarily and sometime after that no matter 5th or 6 gen people where using it as fueling all the time. I used meth for 1 dyno session on my 5th gen I had a terrible blower the ls 2300 edelbrock 3 passes on the dyno and had to refill the washer bottle. Needless to say I just pulled the kit off it worked for sure dang snout would ice over. A month later went twin turbo ago kit.
08-02-2021, 06:59 PM | #18 |
Drives: 1SS Summit White 6 speed Join Date: Jul 2017
Great responses guys
Upgrading fuel system to run E85 costs as much as the supercharger kit did haha Even with lt4 fueling and more boost I'm still gonna get higher IAT's
16 1SS M6 White
Magnuson 2.3 Heartbeat Roto Fab Solo Performance Cat deletes and Axleback Hurst short shifter #'s coming soon Riaction coilovers 1LE sway bars BMR mm BMR chassis brace Flow one 19" wheels wrapped in Mickey Thompsons 02 Z28 M6 35th anniversary 80k miles T-tops Leather Bolt ons Joy to drive this classic every day! Daily Driver |
08-02-2021, 07:02 PM | #19 |
Dyno Show Queen LOL
What numbers are ya wanting?
08-03-2021, 08:01 AM | #20 |
BAMF SS
800 rwhp, 9-12 lbs of boost through a p1x. With procharger's stage 2 a2a intercooler and dual nozzle meth, I never see more than 5* over ambient on my IAT's.
2016 1SS A8: FBO + Circle D + P1X + Meth + Tuned by Pray Performance
Stock Longblock 800 SAE rwhp. 9.4 @ 145 mph. |
08-03-2021, 07:50 PM | #21 |
I have no need for more than 600 whp if that
Stock clutch and brakes still Want them to last another few years
16 1SS M6 White
08-03-2021, 07:57 PM | #22 | |
Are you still on 93 octane ?
16 1SS M6 White
08-04-2021, 05:07 AM | #23 | |
Dyno Show Queen LOL
Here is her build a long the way... Stock w eforce and can tune 551 rwhp Eforce, headers, and rotofab 578 rwhp Eforce, headers, rotofab, LT4 injectors, and DSX aux pump, 613 rwhp and 666tq We picked up the car in Nov 15 and she been supercharged since early 2016 no problems so far other than front seal leak and axels bolts that backed out all covered under warranty. Still on stock clutch about to turn 70k. She drives it freaking hard harder than I drive mine No lift shifts and all..
08-04-2021, 06:12 AM | #24 |
You have your IAT sensor right behind the throttle body (mounted in the manifold), correct? Meaning that you are spraying the sensor with 2 nozzles of methanol? This being the way that you set up your IAT table for the lack of methanol, because if there is no spray of methanol on it, readings are different?
08-04-2021, 07:06 AM | #25 | |
invest in the LT4 fuel system for an OEM like reliable no baby sitting 600 RWHP. Ted.
www.jannettyracing.com
08-04-2021, 07:53 AM | #26 | |
BAMF SS
08-04-2021, 07:59 AM | #27 |
You don't need to run full E85. Run E50-60(102-106 octane), it's all you need. It takes roughly a 60/40 mix pump E/93 to get around E50. LT4 fuel system should handle that on 8-9psi. E will allow full timing with higher IAT's without knock.
2016 NFG 1SS A8
08-04-2021, 08:11 AM | #28 | |
BAMF SS
if you are at WOT: there is no fail safe, because the system is operating like it normally would if you are not at WOT: it will run like complete crap, if it can even idle (mine barely did), as you are dumping a bunch of fuel in it. unless you are one of those people who feel the need to "send it" when their car is obviously not running right, common sense should kick in.
