08-05-2021, 10:44 AM | #57 |
Drives: 2019 ZL1 Join Date: Mar 2019
LOL!
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90 |
08-05-2021, 10:51 AM | #58 | ||
Petro-sexual
Thank you for commenting.
08-05-2021, 11:26 AM | #59 | |
KingLT1 was nice enough to post the best I've seen on this topic 2 years ago.
https://www.camaro6.com/forums/showt...ght=TUTD+edits And he posted a video last week of a Houston guy picking up .30 via a TCM tune, so...
'20 ZL1 1LE A10,
08-05-2021, 04:29 PM | #60 | |
Drives: 2018 Camaro ZL1 Join Date: Dec 2017
08-11-2021, 09:50 AM | #61 |
Drives: 2019 Chevrolet SS Join Date: Mar 2019
All, The ZL1s TCM needs to be unlocked to remove the torque management limiter for 1st gear..... ON the ZL1 the 1st gear has a very low torque limit and if you log your car using hptuners you will notice that the the tb and Power Enrichment does not activate until the tb opens up 100%. THe torque limit in 1st gear does not allow the car to open the tb 100% because it would exceed the tq limit thats why my 60' stock was 1.66s best even with tuned ECM, once i tuned the tcm and removed the tq limit in 1st gear, that one change dropped my 60' to a 1.50! and allowed the car to open up 100% tb from the hit and go into PE mode much quicker!
08-11-2021, 09:54 AM | #62 | |
Drives: 2021 Red Hot ZL1 Join Date: Sep 2020
08-11-2021, 10:19 AM | #63 | |
08-11-2021, 10:39 AM | #64 |
That would have to be tested to see which performs better on street tires. TCM tune and traction control vs no TCM tune and no traction control.
08-11-2021, 11:00 AM | #65 | |
'20 ZL1 1LE A10,
08-11-2021, 12:37 PM | #66 |
I dont have any but there is a table in the transmission tcm you can see when you download the 10 speed tcm tune from your unlocked trans thats basically showing a torque limit and the first gear torque limit is wayyy less than the other gears. if you watch my youtube videos the ones they linked above with the black zl1 you will see how much of a difference it makes from a launch. from a roll it probably wont matter as much since your not starting in first gear....
08-11-2021, 01:30 PM | #67 |
I'll take your word for it, but I find it counterintuitive that removing the torque limit would not result in worse traction in 1st/2nd gear. What other edits did you make to the stock TCM tune?
'20 ZL1 1LE A10,
08-11-2021, 01:35 PM | #68 | |
Removing the torque limit allows full power, and gets you MUCH better 60ft times.
08-11-2021, 02:35 PM | #69 | |
'20 ZL1 1LE A10,
08-12-2021, 06:40 AM | #70 |
Pray Performance tuned the TCM so im not sure what else he has modified besides a couple shift points to get 1-2 to shift at 6500 not 6200, and like stated above, I run a full drag pack at the track and turn off the traction control completely off when I make my passes and the drag radials hook up under full power from a stop at the track in a prepped surface.
