08-02-2021, 08:15 AM | #29 |
Petro-sexual
Don't forget the cost of tuning, too. Calibrators don't include that cost, and while there are resources to find that can guide you to tuning some of this stuff, to get the most out of a tune, a knowledgeable calibrator is going to probably be the way to go.
08-02-2021, 09:50 AM | #30 |
He knows a guy.
2016 NFG 1SS A8
08-02-2021, 11:21 AM | #31 |
Petro-sexual
I'm tempted to look into that T93-conversion (I guess it's to a T87A) from HHP. I haven't noticed a follow-up from whoever here started to look into that. What I'm worried about is losing the ability for the TCM to integrate the differing modes our cars have. Maybe it does it just fine, but there's almost always something you have to give up for something like this, and maybe I don't really need that level of integration, I like to keep it because that's how the car was engineered. I should just reach out to them, lol.
08-02-2021, 12:41 PM | #32 | |
08-02-2021, 12:53 PM | #33 |
Drives: 2021 Red Hot ZL1 Join Date: Sep 2020
I've seen no updates from anyone that was making this T87 swap. Would love to see some before and after drag times.
08-02-2021, 01:20 PM | #34 | ||
Petro-sexual
I'm wondering what's really left on the table at my power level. It's not that much higher than stock, but, if I got a few tenths, that'd probably be worth it, honestly. My buddy's wondering how low the torque limits really are, because he's really had to lower a lot of the bottom-end of his powerband to keep from seeing TMA and throttle closure. So much so, the torque curve actually rises with RPM and doesn't ever fall-off. Perhaps some of that is VVE tuning, but MAF is good - confirmed with WB and trims (where applicable). But - he really had to pull VTT down, in the lower RPMs. That sounds bad, but the car was spinning the DRs in 3rd around 40 anyways, so it's not like, on the street, he's losing much, but wondering if there is some power left is what is killing him, ha. I guess it would be worth seeing what T87-guys are/were seeing and seeing if we could compare.
08-02-2021, 03:01 PM | #35 | |
Drives: 2020 Camaro ZL1 Join Date: Oct 2020
2020 ZL1 A10 Shadow Gray Metallic
Magnuson Magnum DI TVS2650R| Mamo Throttle Body V2| RotoFab Intake| Borla S-Type Catback Exhaust| TCM Tune| Tune| Eibach Pro| BMR Rear Cradle Lockout| PPF| Ceramic| BCForged HCS21 |
08-02-2021, 08:26 PM | #36 |
HPP sells and tunes them, so they better have some happy customers out there that they can tell a buyer about. I've exchanged a bunch of email with them and perhaps it's time for a call.
'20 ZL1 1LE A10,
08-03-2021, 07:29 AM | #37 | |
Petro-sexual
08-03-2021, 09:29 AM | #38 |
haha understandable
08-04-2021, 05:56 AM | #39 |
BINGO. TCM unlock for 2017-2019 and the 4 credits is around 450, while I paid 459 for my SS Rotofab. TCM tuning was worth a lot more in the 1/4 mile than the CAI was for my SS. Anyone paying attention should already know this, locked TCM really spoils the party in the ZL1. Look at how guys install drag radials on a car with 650hp and boatloads of lower-rpm torque. Then they get a 1.6 short time, or slower. The locked TCM is not allowing them to use all of the torque and power that they already paid for just buying the car, let alone if they spent even more money on engine parts. Not to mention, tire changes can really suck with a locked TCM. My own 2017 SS had a locked TCM for a while, and when I installed the popular 305/45-17 MT drag radial, it f-ed up my shifts, found out that 1st gear was only getting to 5500~5900 at best, so I checked it with the stock tire and it would reach ~6100 or a little more with that tire. So the stock tune was not even correct for the stock tire, and then it really sucked with the tire change.
08-04-2021, 07:41 AM | #40 | |
Petro-sexual
I was just trying to keep my comments relative to the bigger power a lot of others are making
I was watching one of CSPs earlier builds on Andrew's car and you could see flat-spots in the dyno curves of the stock tune. He never mentioned it, but I suspect it was throttle or TMA limiting torque. I have noticed those flat-spots on a lot of stock-tune dynos, right about the same spot in the powerband. I've also read and seen comments in videos about the throttle not opening from a dig all the way until after a certain speed or whatnot. It is my opinion these seem to be torque limits from the stock tune. I'm no expert, and I wasn't there for those runs, and almost none posted scans from the logs, so I don't know for certain, but I do know these limits are real, and it's a graceful balance to get them all to jive with each other to have a car that will open the throttle all the way when you command it to, and to have full timing when commanded.
08-04-2021, 11:07 AM | #41 | |
08-04-2021, 12:39 PM | #42 | |
