01-17-2017, 01:32 AM | #29 |
Drives: 66 Chevelle SS Join Date: Mar 2013
Pretty hard to get into a car you've never driven on track before and lay down a number you can't improve upon. When I run my car I focus on the 60'which is done with getting the suspension dialed in and the mph is done by getting the tune right.
01-17-2017, 05:35 AM | #30 |
There are a bunch of 16ss Camaro's including mine that ran in the 11's with either drag radials or slicks. Mine and snowblind ran over 121, mine with just drag pack and Cai, snowblind did a little more weight removal. I think most is driver issues with launching the car. Drag radials will help a bunch. Nice right up and videos
01-17-2017, 06:10 AM | #31 |
Drives: 2017 ZL1 10 Speed Hyper Blue Join Date: Jul 2016
Thanks for doing this Cal!
2017 ZL1
01-17-2017, 06:32 AM | #32 |
C'mon- really?
Drives: Looking for a ZL1 Join Date: Aug 2009
Nice runs OP for your first time out with your car and with a manual trans. VERY respectable.
Your car definitely has 11's in it once you polish up the launch which will get your 60' times down a lot. That in turn will give you those 11 sec slips. Play around with the rear tire air pressure a bit and if you do with the DRs make sure to get them warmed up. And we all appreciate the work it took for you to post everything! That had to take a while! Thanks again and kudos for having the balls to actually take the car to the track and have fun!
Steve
2018 Camaro 2SS 1LE Black #3805 - SOLD |
01-17-2017, 06:53 AM | #33 |
AKA "Beefcake"
Drives: 2023 ZL1 Sharkskin Join Date: Oct 2009
Thanks for the videos too! Enjoyed them a lot
01-17-2017, 06:58 AM | #34 | ||||
Cal
Drives: 2017 6th Gen Camaro ZL1 Coupe M6 Join Date: Sep 2013
This is the specific information I was looking for. Thank you for the critique!
I'll definitely work on the low RPM launch as you describe. The computer-controlled custom launch certainly doesn't seem to be working anyway. That sounds like a really low RPM, though. I knew I'd have to get RPMs up quickly after the launch to get the torque I need to power out of the hole. Based on what I was hearing from the motors of the other cars that were launching well, I was thinking I'd need to feather the clutch some to apply that torque. Thanks for the details on RPM and clutch work. Quote:
Does anyone know what IAT2 temps trigger timing retard on this LT4 engine? The articles I've read say this motor was specifically modified and tuned for the ZL1 so even Corvette LT4's are probably not the same but they might be close. My goals for this trip were mainly focused on getting used to the car and track, dialing in the Custom Launch settings, and improving my skills, so I wasn't real concerned about the ETs so much as my technique. Of course, when you're lined up against a fast car you tend to act more on instinct. I've got to make sure I've got good habits (technique) first before I can rely on instinct. Getting good at manual launch will be the next big step, I think, providing I remember to lower tire pressure and hit my shift points properly. When everyone at the track sees this brand new shiny 6th Gen ZL1 they all want to try and show their car is better. I'm sorry I couldn't represent the ZL1 better on this trip. For those few that beat me, they didn't beat the ZL1. They beat the green ZL1 driver. They'll see me again, though. Next time I'll get better... each time I'll get faster... Who can defeat someone who refuses to give up?! You don't loose until you stop trying. --Cal |
01-17-2017, 06:59 AM | #35 |
Cal
01-17-2017, 07:05 AM | #36 | |
Cal
HaHa! Yup. That friction point is near the top of pedal travel so it'll take some practice to feather it in just right to get max torque off the line without undue wear. --Cal |
01-17-2017, 07:25 AM | #37 | |
Cal
Thanks for the encouragement. --Cal |
01-17-2017, 07:27 AM | #38 | |
Cal
--Cal |
01-17-2017, 07:34 AM | #39 |
Drives: Stuff and Things Join Date: Apr 2015
Thanks for sharing and sounds like you had fun. As long as you enjoyed it then times have no relevance. As others have said, more seat time will bring better times. Keep at it.
Btw video 7 of 9, that's a hatch WRX (single turbo boxer motor). Dunno if anyone stated or not. |
01-17-2017, 07:35 AM | #40 | |
Drives: 2014 M6 ZL1 Join Date: Jan 2012
15' Ashen Gray Metallic Z/28
14' Crystal Red Tintcoat ZL1 6M, 9.62 at 150.75 MPH 12' Opulent Blue Metallic CTS-V Sedan, 10.690 at 129.60 MPH - SOLD 06' LeMans Blue Metallic Z06, 11.726 at 127.80 MPH Motor - SOLD. 96' Impala SS LTx, 11.397 at 118.10 MPH Motor, 1st stage 10.526 at 127.46 MPH |
01-17-2017, 07:42 AM | #41 | |
OP you are awesome to take your new ZL1 to the track to lay down some numbers. Respect! As has been said seat time is your friend, especially in a manual. Those auto SS guys crow about thier numbers but they just point and shoot. (Just kidding A8ers) You will get better with practice. And seconding low 20 pounds of air in the tires. But no lower. And the quick 2nd gear burnout to get the water off the tires and warm the tires slightly. A big burnout will make street tires greasy and go around the water if you can. And also seconding that low RPM launch with a progressive clutch slip. The goal is a touch of spin and getting into full throttle ASAP. When you get a good launch you will feel it in the pit of your stomach. Put the tach on your HUD and shift right around 6200-6300. You don't want to run into that 6,500 rev limiter (6,500 on the ZL1?) As for me even with the HUD a LED shift light is a big help. My 5th gen ZL1 had a shift light, not sure about the CA6 ZL1. One possible problem might be the Goodyears. In my 5th gens I was able to get low 1.9s on the SS Pirellis, but on the 1LE and the ZL1 I rarely got below 2.0. The CA6 SS runflats hook pretty good too. I know the new ZL1 tires are the next gen F1s so they may not be as big of a hinderance. Also as has been said your ZL1 will need some time between runs. Stacking that supercharger hunk of metal on top of the engine is bound to provoke heat soak. Bye Bye timing. I think with some practice and good DA I think you can beat that 11.8 number totally stock. And I think with a good set of DRS you might be able to knock 1/2 a second off that. You have a fast car. I also like how you appreciated the other cars in the lanes. I feel the same way and met so many cool people in the staging lanes drag racing has become a bit of a social event for me. I'm hooked. As for me I do not worry so much about ETs, but rather enjoy the racing. Sometimes I leave early or late depending on the car in the other lane to put on a nice race for the fans. It is especially fun to beat faster cars who can't get traction or sleepers at the light. Drag on. Oh and about the stock tires. Many ZL1/1LE owners will be switching to Michelins. Keep your eye on the for sale threads. Almost new F1s can be had for about 1/2 the price of new if you are patient.
"Democracy Dies in Darkness" Last edited by Fraxum; 01-17-2017 at 07:54 AM. |
01-17-2017, 07:48 AM | #42 |
Drives: 2017 SS 1LE Mosiac Black Join Date: Nov 2016
Are there any threads that have best practices for launching our cars, both M6 and A8?
