08-07-2022, 11:37 PM | #1 |
Drives: 2016 camaro 2ss Join Date: Jul 2018
rear of the car squatting on to the tires??
I have a 2016 2ss without magnaride on factory springs. I have a set of curva c300 20x9.5 front paired with a 275/35/20 nitto 555g2 and a 20x10.5 paired with a 315/30/20 nitto 555g2 in the rear and my car rubs the outer edge of the rear tires when i hit a dip in the road or pothole, it does not do it often only on bigger holes or dips.
My rear tires are very flush but poke maybe just a couple mm's, barely any, depends on the way you look at the rear of the car. My question is how can i combat this, my goals were to lower the car since it is on factory springs but if i am already rubbing with factory springs then it would surely be worse once i lower it? unless with the lowering springs having a higher spring rate making it stiffer, then it may work?? any suggestions will be helpful. |
08-08-2022, 05:34 AM | #2 |
Drives: 2018 Camaro SS1 1LE Join Date: Feb 2017
I’ve read on the forum that there’s a wiring harness back there that needs to be relocated if you go bigger than 305. That might be what’s rubbing.
08-08-2022, 07:43 AM | #3 | |
Drives: 2020 Camaro 2SS A10 Join Date: Jun 2018
Have to relocate the harness if you use either of those tire specs
2020 Camaro 2SS A10 | Rebuilt by: CBI Street Cars | 2" SE LT Headers | 3" SE X-Pipe | 3" MBRP Axle-Back | Pri & Sec Cat Deletes | K&N Typhoon CAI | LT2 Ported | 95mm ZR1 TB | DOD Delete | BTR Stage I Cam | ECM, TCM & E85 |Tuned by: Shane Hinds | Dyno: 510 rwhp 472 rwtq
08-08-2022, 07:47 AM | #4 |
2020 Shadow Gray 2SS
He's talking about the outer edge of the rear tires hitting the fender lip... Sounds like your wheels have the wrong offset...
2020 SGM 2SS - A10, NPP, MRC, Red Calipers, Black Camaro Fender Badge, Footwell Lighting
Added after delivery: - GMP CAI, GMP Black Strut Tower Brace, MRR017 1LE Wheels, SS Armrest, Black Fuel Door, Stainless Sport Pedals, SS Wheel Caps, Black Lugs/Locks, GM Splash Guards, DD Smoked LED Markers, Smoked Rear Reflectors, Mishimoto Catch Can, Xpel PPF - Full Front, SunTek 35% Tint, CeramicPro coating, RST Stainless Brake Lines, Castrol SRF, MSD Super Conductor Wires Left: My "fun" ride. Right: My "work" ride: a Gulfstream G600. One's top speed is 180 Mph, the other, 620 Mph... |
08-08-2022, 07:55 AM | #5 | |
That might be an optional way to go if you are dead set on lowering. Wide body kits: https://www.americanauthority.com/pr...reetfighter-la Obviously not cheap, but you can buy the kit pieces individually
08-08-2022, 08:26 AM | #6 | |
Drives: 2021 LT1 10 speed auto Join Date: May 2013
08-08-2022, 08:34 AM | #7 | |
Just saying its an option, not saying its practical but an option none the less.
08-08-2022, 09:29 AM | #8 | |
Drives: 2023 and 2024 Convertibles Join Date: Apr 2021
I haven't received my 2023 yet; planning on the upgrade. Thanks! |
08-08-2022, 10:25 AM | #9 | |
Sorry found it: 6:17 Mark
08-08-2022, 10:49 AM | #10 |
The 1/4 panel wheel openings are cut and the wide body flares are added. You do not see the cut (butchered) 1/4 panels. No other way to prevent the tires and 1/4 panel sheet metal from contact every time the rear suspension compresses.
08-08-2022, 10:55 AM | #11 |
Understood so some cutting involved then :x
08-08-2022, 11:04 AM | #12 |
08-08-2022, 12:09 PM | #13 |
08-08-2022, 07:45 PM | #14 |
How wide can I have the rear tires before I need to do this wiring harness relocation?
Thanks! |
