07-17-2022, 07:47 PM | #29 |
Drives: 2021 2SS 1LE Join Date: Aug 2020
Read your owner's manual. I think it says to wait more than "a few minutes." It says something about ideally you should wait a couple of hours, and if you can't wait that long, you should at least wait XX minutes.
07-17-2022, 08:10 PM | #30 | |
Shadow Gray '19 ZLE M6
I'll start adding the step of rechecking the dipstick after the car has sat a couple of hours. I'm not sure I fully understand why, but it can't hurt.
PPF | Paint Correction | ZL1 Addons Rock Guards | ZL1 Addons Lift Pads | ZL1 Addons Feather Lite Tow Hook | JWM Smoked Sidemarkers | Wildhammer Smoked Rear Reflectors | JWM License Plate LEDs | RotoFab CAI | ADM IC Reservoir v2 | BC Forged RZ05 | SPL Toe Arms | BW Brake Deflectors | CMS Roll Bar | Schroth Profi II ASM Harnesses . Sold: '99 Trans Am (bolt-ons & cam) | '00 WS6 (bolt-ons, heads, cam, 12 bolt) | '05 CTS-V (bolt-ons, short throw) | '10 SS/RS M6 (short throw, CAI, coilovers, LTs, catback, JRE tune) | '01 WS6 YouTube |
07-17-2022, 09:29 PM | #31 | |
I put in 9.5 QTS to ensure it will show on the stick, then let it sit several hours (just to be sure) before reading the stick to figure out how much more to add to get to the top of the hashed area. I track mine, so wanting to ensure it's at the top without going over. |
07-18-2022, 06:56 AM | #32 |
Drives: '18 1SS 1LE Join Date: Sep 2017
So by GM's logic, an oil change on a car dropped off cold might take an hour or two to correctly adjust the oil level, yet they pay a mechanic 0.3 hrs or 18 minutes to do the job.
Right.
'18 1SS 1LE Black, PDR
07-18-2022, 12:31 PM | #33 | |
Drives: SS 1LE, 89 TTA, 91 GTA, 91 Formula Join Date: Jul 2019
Can't use logic around here..... I dump m oil, put in 10 qrts. Double check everything, start the car and let it run for a few minutes, shut it off and check. I've checked it cold, hot, during road course sessions, etc. it always at the top of the dipstick, juuuuust over the hash mark area. |
07-18-2022, 12:37 PM | #34 | |
07-21-2022, 11:32 AM | #35 | |
BLUPRINT_1LE
Drives: 2022 Rapid Blue SS 1LE Join Date: May 2017
I have a 22 1LE and it use 0W-40 vs my old 16 SS camaro said 5W-30, same engine block.
2022 Camaro SS 1LE | PDR | Rapid Blue | Manual | Katech Built SS 1LE | Katech Build Sheet
IG: BLUPRINT_1LE YT: BLUPRINT_1LE ---------------------------------------------------------------- |
07-21-2022, 01:57 PM | #36 |
Drives: 2004 BMW 330CI, 2022 1SS 1LE Join Date: Dec 2021
I don't sweat it too much. I just change with 10QT every time. It's always slightly "overfilled" by 1 or 2 mm if I check it after waiting a few hours. Figure it's better to be close to the top than somewhere in the middle when tracking the car a lot. Up to 3500 track miles with no issues.
07-22-2022, 01:22 PM | #37 |
Drives: 2019 ZL1 Camaro Join Date: Oct 2016
When I change the oil and filter on my 2019 ZL1. (non 1LE)
I let old oil drain out of the pan for at least an hour (usually two hours). I always use 10 quarts of fresh Mobil1 Dexos 2 0W40 I fill the AC PF64 filter with oil, dampen the gasket on the filter with oil and install it. Initially, I fill the crankcase with only 9 quarts. I then bring it down off the Raceramps. Let it sit for a couple hours and keep checking the oil level. Slowly, I keep adding oil until full (I've never used more than 10 quarts total). Full on my car (10 quarts) has always shown near the middle of the hashmarks on the dipstick. When I check the oil level, I always pull the dipstick, wipe it down, wait 15-30 minutes, then check. I find it interesting that 10 quarts in different peoples cars show different levels on the dipstick. 10 quarts using the above procedure in my car has always resulted in the exact same spot on the dipstick in the photo below. Tyrolblue67 Attachment 1104388 |
07-22-2022, 02:20 PM | #38 | |
Drives: 2023 Summit White Camaro ZL1 M6 Join Date: Dec 2021
I have only changed the oil in my Camaro once since I purchased it. I let drain for about 15 minutes and then filled it with 9 quarts before backing off my Race Ramps on to a flat surface. When I checked the oil after letting it sit for a few minutes the oil level was at the bottom of the hash marks. So I added half a quart and let it sit overnight. The next day I checked it again and then added oil until I got to the top of the hash marks. It ended up taking the entire 10 quarts. Certainly the entire system holds more than 10 quarts since it's almost impossible to remove all the oil from the entire system. I have a fluid extractor that I use to change the oil in my SeaDoos, lawn mowers and several vehicles that have the oil filter on top of the engine. I like using it because you can see exactly how much oil you have removed. So it makes refilling the oil easier as you put back exactly what you removed.
2019 Dodge Durango R/T (daily driver) 2003 Nissan 350Z (modified) 2022 Rapid Blue 1SS 1LE M6 (delivered 2/19/22) (Sold) 2009 BMW 135i (Sold) Last edited by ZPirate; 07-22-2022 at 02:42 PM. |
07-22-2022, 04:09 PM | #39 | |
10 quarts every time and I'm at the 3/4 way up the hash marks.
07-29-2022, 03:00 PM | #40 |
Drives: 18 1SS 1LE SCCA FS, 99 WS-6, E46 M3 Join Date: Dec 2017
Mine usually reads a little above the hatched area immediately after an oil change.
I did measure the drained amount once: 9 5/8 qts @ drain after 6000 mi interval. Dipstick still read at top of hatched area just prior to drain. My process is to drain a level car (on lift) for 30-60 minutes and add the full 10 qts.
07-31-2022, 03:14 PM | #41 |
Drives: 2017 1le current /2015 2ss 1le sold Join Date: Jan 2016
Slow day at the forum eh?
2017 1LE Hyper Blue
08-08-2022, 01:58 PM | #42 | |
Drives: Duramax, 2018 Camaro SS 1LE Join Date: Nov 2020
If it ain't buckin, chirpin & makin all kinds of bad noises.... then I ain't happy!
