Old 03-05-2021, 04:07 PM   #1
Minerbros66
Minerbros66's Avatar
Drives: 2020 Camaro 2SS, 2018 Shelby Raptor
GM Suspension Upgrade Question
What is the difference between:
https://accessories.gm.com/bergerche...bodyNumDoors=7
And this:
Obviously one comes with more stuff, but are the sway bars in both of these the same? The links do look different. Are these worth it? I bought a 2020 2SS New last April W/O MRC because it had all the other options and it was the only one like it locally to me. Not a track car just a driver may do a track day now and again but mainly a light to light car. is there another brand that is better? Thanks in advance!
2020 Camaro 2SS A10
2018 Shelby Baja Raptor #87
Minerbros66 is offline   Reply With Quote
Old 03-06-2021, 12:10 PM   #2
ABM1SSSG3
ABM1SSSG3's Avatar
Drives: 2017 Arctic Blue Metallic A8 SS
I can only address the first part of your question. Yes, the sway bars are the same. The links are also the same. The bottom picture has the blue joint protector on it. The top does not. The top kit is for MRC equipped cars, which yours is not. The bottom kit is designed to work with non MRC cars that have the SG3 GM lowering kit, however it also works without the lowering kit. You just won't get the full advertised 18% less body roll.
2017 SS Arctic Blue Metallic A8 GM big brake kit SG3 Lowering & FE4 sway Bar Kits
ABM1SSSG3 is offline   Reply With Quote
Old 03-06-2021, 12:38 PM   #3
ABM1SSSG3
ABM1SSSG3's Avatar
If you're interested in the GM lowering kit for your non-MRC car, the part # would be 84203549, and you can get it for $1125 at shopchevyparts.com. They also have the sway bar/handling link kit for less than $400. Berger (the source for your ad) is advertising list prices for everything.
Old 03-06-2021, 03:22 PM   #4
Minerbros66
Appreciate the reply's I do some more digging into it. Thanks!
2020 Camaro 2SS A10
