05-06-2024, 07:42 AM | #1 |
Drives: 2020 Camaro ZL1 Join Date: Oct 2020
V-Bands and catback?
Does anyone use v-bands on a typical catback system? I've noticed that i have a couple of exhaust leaks that I need to tweak after installing my new AWE exhaust this past weekend, and I can't for the life of me get the leaks to go away. Any suggestions?
2020 ZL1 A10 Shadow Gray Metallic
Magnuson Magnum DI TVS2650R| Mamo Throttle Body V2| RotoFab Intake| AWE Touring Catback Exhaust| TCM Tune| Tune| Eibach Pro| BMR Rear Cradle Lockout| PPF| Ceramic| BCForged HCS21 |
05-06-2024, 08:36 AM | #2 | |
Having FUN in the SUN...
Drives: 2022 M6 ZL1 1LE Join Date: Jan 2022
I had my mid pipe and axle back welding together, makes the system easier to drop / install with no alignment issues.... but does make it a bit harder to handle working from jack stands. I think having V bands at that location would make dropping / installing easier, but perhaps a pinch more work to get everything aligned again. Food for thought.
2022 M6 ZLE: Katech Standard Ported Blower + Ported Heads + 103mm TB + Oil Pump + C5R Chain + Valve Covers + Coil Relocation Kit
TSP VVT and DoD Delete Covers + LME Chain Guide + DSX Billet Lid + ATI Damper + 9.17" Lower + 2.4" Upper + MM Wild Catch Can Coated AR Headers + GESI UHO Cats + V Bands + AWE Touring + Magnaflow Center X + MSD Coils + Banks iDash + JMS Booster ALL the BMR Read End Goodies + BMR Motor Mounts + JRE Terminator Cam Package + Big Gulp + GMS High Flow Crash Bar DMS Front HX + Fender Tank + FIC 30's + APEX SM.10's + TOYO 305/345 R888R's = 775rwhp 815rwtq @E55 13.5psi |
05-06-2024, 08:57 AM | #3 |
Interesting, I just want the "ticking" sound to go away lol i don't care if it will make it more difficult to remove in the future....It sure is annoying though
05-06-2024, 08:57 AM | #4 |
Drives: 2021 Red Hot ZL1 Join Date: Sep 2020
I never had any issues getting my AWE catback to seal, the only place I had trouble getting a consistent seal with from the Kooks headers to the high flow cat connection pipes. I used this sealant and the leaks went away. Its very durable and will hold up for years. I know people that have used it for slip fit exhaust parts too so this is an option. Either of these will work but one allows more work time before sealing.
https://www.amazon.com/gp/product/B0...e?ie=UTF8&th=1 https://www.amazon.com/gp/product/B0...e?ie=UTF8&th=1 |
05-06-2024, 09:29 AM | #5 |
I'd hate to have to use that stuff if i didn't have too. It seems like the exhaust is coming from where the pipe inserts into the other. Specifically where there are little notches.....maybe i'm not installing the clamps correctly but I never had this issue with the old Borla i had.
