05-02-2024, 06:51 PM | #1 |
Drives: 2023 Camaro Convertible ZL1 A10 Join Date: Mar 2023
is this oil guage correct
one picture is idle the other is going about 40 miles per hour. recently I had an oil change from the stealership but I do not remember it going up that high.
Am I trippin Is this right? |
05-02-2024, 07:14 PM | #2 |
Drives: 2023 SS 1LE Sharkskin Join Date: Jun 2023
How's your oil level?
ΜΟΛΩΝ ΛΑΒΕ
05-02-2024, 07:26 PM | #3 |
05-03-2024, 08:59 AM | #4 |
could it be possible that the stealership used different weight oil then the Supercar that I have been using?
05-03-2024, 12:30 PM | #5 |
Sarcasm loading --------
or the pump could be failing.
Keep an eye on it. Before some pumps fail the oil pressure gets high spikes. Mine did. Some say new pumps are better, but I know someone with a 22 ZL1 where the pump failed.
2018 MBM ZL1 1LE - Stock 2014 CRT ZL1 574 rwhp, 537 rwtq - SOLD 2010 IBM SS Camaro VVT L99 w/ TR6060 swap, 489 rwhp, 444 rwtq - SOLD |
05-03-2024, 01:03 PM | #6 |
Drives: 2021 Red Hot ZL1 Join Date: Sep 2020
I'd say you're fine, the oil pumps vary pressure depending on rpm. As long as you have a 2019+ ZL1 which you do, its unlikely the pump is failing.
05-03-2024, 05:01 PM | #7 |
Yours stealership theory could be right with the heavier oil weight. I kind of wish you had a panned out view to see the RPMs for said oil pressures. 40 at cold start idle is about right
05-04-2024, 03:52 AM | #8 |
ZL1 Driver
Drives: Camaro ZL1 & BMW M3/E92 Join Date: May 2009
I noticed the oil pressure up a bit with my oil change last week. Cold idle 40. Cruising at temp was 40-50s. Warm idle 30-32.
