10-27-2020, 10:44 PM | #57 | |
Drives: '21 Wild Cherry ZL1 Join Date: Aug 2018
Yet potentially hundreds or thousands of engines with faulty valve springs managed to make it through QC? I know Polaris tests EVERY engine that leaves their production facility prior to installation. Does GM? If no then, yes, that QC is superior regardless of quantity. The reality is if only a small portion of the heads, supplied by a now known specific batch, affected would have been tested prior to assembly as it would have easily been detected prior to have ever been installed on an engine. Yet here we are. Or perhaps you are the one that has no concept of how valve spring seat pressure, open pressure @ max lift & subsequent durability can be easily evaluated by nominal test equipment available to manufacturers. You do know there is equipment that does that, right? I mean because aftermarket valve train suppliers do this in batches, & they’re small peanuts compared to GM. Or maybe you’re a corporate troll? Last edited by gtfoxy; 10-27-2020 at 10:55 PM. |
10-28-2020, 12:59 AM | #58 |
Drives: 2020 camaro lt1 Join Date: May 2020
Well....I got my car back from the dealer.They took my brand new camaro lt1 and rebuilt the engine in stead of replacing the motor.after 220 miles on the car #4 cylinder is toast,valve spring broke and valve broke the piston.Not happy with GM decision to rebuild motor vs.replace motor.(only 220 miles).So I filed a complaint.Not good customer relationship.
10-28-2020, 01:09 AM | #59 |
Drives: Fast if no one's looking Join Date: Aug 2019
10-28-2020, 05:42 AM | #60 | |
Drives: 2021 Camaro LT1 Join Date: Sep 2020
If my motor goes BOOM be ready for a thread. |
10-28-2020, 06:15 AM | #61 | |
I dunno man, a few hundred bucks, if you already have an air compressor, for valve springs, TDC stop, hand spring compressor & an afternoon would solve the problem for good. |
10-28-2020, 07:20 AM | #62 | |
Hard to want.
Drives: 2020 red hot 1SS 1LE Join Date: Aug 2017
10-28-2020, 07:35 AM | #63 | |
Drives: 2017 Camaro 2LT RS 3.6L Join Date: Mar 2016
10-28-2020, 07:40 AM | #64 | |
Hot Camaro
1) A sled today costs $12,000-$15,000 (most models, there are a couple of exceptions). Think about that for a minute. Based purely on the number of parts and what goes into assembling a machine, how do they justify that price tag? And parts of what they use in the powertrain is used in other products as well, so it isn't a lack of volume on the main pieces... 2) The sheer volume of vehicles that GM builds outstrips what Polaris does on any level. The massively higher volume of what GM is building simply couldn't be inspected, repaired, and re-inspected the way you're describing. 3) Polaris motors for their sleds are two-stroke and immensely simpler mechanically than what goes into cars today. Testing is much quicker and easier to do, especially the majority of it is based on compression and leak-down testing. |
10-28-2020, 07:44 AM | #65 | |
Hot Camaro
While I completely understand that warranties exist to handle defects like this, they are not expected to kick in as you basically "drive the vehicle off of the lot." The relative instantaneous failure of the car demonstrates that there was a major issue at time of assembly and GM's only remedy in this situation should be to buy the car back from you. Look into your state's Lemon Law details as well to see if it covers any sort of mileage restriction that could force GM's hand to buy the car back. |
10-28-2020, 07:46 AM | #66 | |
Drives: 2019 Camaro 2SS Join Date: Nov 2019
Back on topic. I would be very nervous owning a new 6.2 liter. what if you're at 37k miles and then you have an issue. Now you're on your own dime. This sucks, glad I have a 19. Was gonna upgrade but not now.
2019 Camaro 2SS, Shadow Grey
10-28-2020, 07:50 AM | #67 | |
Hot Camaro
Problems can arise anywhere, at any time. And sometimes they take a very long time to recognize and correct. It seems that this issue was the result of supplies being used to make the springs, it was caught fairly early, and is being corrected as it is found to be an actual problem "in the wild." GM is not still building this motor with the bad parts (that they are aware of).... |
10-28-2020, 08:09 AM | #68 | |
Drives: 2021 Acura RDX SH-AWD Advance Join Date: Aug 2019
10-28-2020, 08:14 AM | #69 | |
10-28-2020, 08:26 AM | #70 | |
Drives: 23 LT1/22 Colorado TB/69 Chevelle Join Date: Jun 2006
Did they replace ALL of the valve springs or just the broken one? It was my understanding that on performance engines like LT1, they were supposed to replace all of them if there was no engine damage. I could be wrong though. |
