Old 10-10-2020, 05:23 PM   #29
Danew_377
Chief Bief
Danew_377's Avatar
Drives: Nightfall Gray Camaro 1SS
I am sure it's on the forum somewhere about if a stock tb will fit with this or if I have to move to an lt5 tb. I have the GPI manifold as well. Just waiting for time to put it on. Thanks gents for posting info.
2016 NFG 1SS M6
JLT Intake, LT2 Manifold, LT5 TB, CSP 2" headers, AWE Catback Exhaust, Apex ARC-8 Wheels.
426whp/434wtq
Danew_377 is offline   Reply With Quote
Old 10-10-2020, 06:34 PM   #30
OB0001
2018 SS A8 11.85@117.06
OB0001's Avatar
Drives: 2018 Camaro SS A8 "Dark Knight"
Originally Posted by BlackbeastSS2 View Post
I agree sounds way better. Did u remove the foam pad? That would help to project more sound.
Did u get any check engine light. I did. Maybe I should try a battery disconnect.
no check engine light, let it idle for about 10 minutes then took it for a spirited drive, yes i trimmed the foam pad to fit the LT2 intake .
DARK KNIGHT
2018 SS A8 11.85 @ 117.07 GPI Tuned E85 stock tires Roto Fab CAI LT 2 intake
OB0001 is offline   Reply With Quote
Old 10-10-2020, 08:53 PM   #31
OB0001
OB0001's Avatar
Stock fits just fine
DARK KNIGHT
Old 10-10-2020, 11:51 PM   #32
Mountain
Mountain's Avatar
The LT2 engine, itself, in the C8 uses the same 87mm TB as on the C7 and Camaro LT1 engine. I hope I am answering the question I think you have, lol.
Old 10-11-2020, 05:45 AM   #33
6spdhyperblue
Drives: 6th gen
Where did you trim it? At the back?
‘16 1SS M6 LT2 intake + boltons on DR 11.0@126+ (Sold)
Old 10-11-2020, 10:35 AM   #34
OB0001
OB0001's Avatar
The back is fine, you just need to trim about a 1/2 inch in between the inter ports the LT2 intake has ridges between each port.
DARK KNIGHT
Old 10-11-2020, 06:04 PM   #35
Danew_377
Chief Bief
Danew_377's Avatar
You are. I bought a Soler throttle body not too long ago and don't want to have to purchase another item when the one I have works great.
2016 NFG 1SS M6
426whp/434wtq
Old 10-12-2020, 09:05 AM   #36
RobbyBeefcake87
RobbyBeefcake87's Avatar
Drives: 2018 Camaro SS 1LE
Here’s a fitting pic. I am not putting it back on but just tested for you. It clears the intake manifold by 1/16 off an inch, plenty of room when the engine revs up unless your motor mounts are lose.
I used 2 nuts and I would recommend 2 black spacers.
You need to use both long bolts that come with strut tower brace. So you need to find 2 more longer bolts.
I appreciate that boss.
2000 Miata - aventi storm wheels, roll bar.
2019 Mustang GT pp1 - svt pp2 wheels, mbrp cat back, sync 3 upgrade, p1x procharger + stg2 intercooler.
2018 Colorado zr2 - zr2 sport bar, showcase spare tire.
2018 Camaro SS 1LE - GM cai, black bowties, suede knee bolsters, 1le plate frame, black fuel door, dark tails + 3rd brake light, euro side markers + led's, GM all weather floor mats, velossatech big mouth, GM strut brace.
2017 Corvette Grandsport (sold) - untouched.
2006 GTO (sold) - iat relocation, air box mod, monero side marker lights.
RobbyBeefcake87 is offline   Reply With Quote
Old 10-12-2020, 04:07 PM   #37
madkat7134
Drives: 2016 camaro 1ss
Did you knock the bolts out of the sleeves to bolt the lt2 intake on or did you use the sleeves ?
madkat7134 is offline   Reply With Quote
Old 10-12-2020, 04:23 PM   #38
BlackbeastSS2
BlackbeastSS2's Avatar
Drives: 2019 Camaro 1LE Shock Candy
I used the sleeves. See page one of thread with picture of vice and bolts. You tap out the bolt and then put sleeve in your new 2020 intake manifold. After sleeve is in manifold just put a bolt in and hit/tap with hammer. Presto you’re done.
Edit:
Update: after getting the engine cover I decided to not use the sleeves. I used a heavier washer on top on manifold.
103 Katech TB, KATECH Custom Heads, DSX In-line fuel
TSP Headers, Spec P Super Twin Clutch, TSP EL C7 CAM
Diamond Piston & Manley Rods, Roto Fab Big Gulp
BTR Push Rods,LS7 Lifters, ARP, FI Chiller, Kirkey Seats
SJM Line Lock, Hurst Pistol Grip. 747/739 RWHP street tune - 821/794 RWHP track tune 101 octane.
2014 Mini Cooper countryman S All4 M6 daily driver
BlackbeastSS2 is offline   Reply With Quote
Old 10-12-2020, 06:06 PM   #39
6spdhyperblue
Drives: 6th gen
Used the sleeves too you swing the sleeve around and it’ll drop right in
Old 10-14-2020, 07:52 PM   #40
BlackbeastSS2
Engine Cover is on!!!
I like the look of it. Took off the Corvette logo and will pic up some carbon Fiber wrap to overlay in its place for now. Next is a tune, it’s running lean with all that extra air according to my AFR gauge. Going to have to fix that Map Sensor it needs to be a touch longer to hide it.
The sound at idle is different and the sound at WOT is let’s say very satisfying to say the least.
Future plans are a coil relocation kit and some nice valve covers that will make that engine bay a lot better.
Old 10-15-2020, 07:45 AM   #41
RobbyBeefcake87
Are you running two catch cans?
Old 10-15-2020, 08:10 AM   #42
BlackbeastSS2
Yes. Running the Mighty Mouse and running a oil separater for the hose that goes into the air intake elbow. I don’t like the factory little plastic filter, so I rerouted the line to go under and into the air intake elbow to clean up the engine bay a bit. But in reality the Camaro engine bay is an octopus of hoses.
