09-15-2020, 11:39 AM | #29 |
Drives: 2019 Chevy Camaro ZL1 M6 Join Date: Jul 2019
If my car used a qt between oil changes I’d be jumping up and down and screaming at my service advisor. If it burned a qt every 1000 miles........I’d be getting a new engine or I’d trade it away.
09-15-2020, 11:49 AM | #30 |
Drives: 2017 Chevrolet Camaro ZL1 M6 Join Date: Jul 2020
Zero oil usage at 24K miles.
09-15-2020, 02:24 PM | #31 |
Drives: 2019 ZL-1 Join Date: Feb 2009
Outlaw: I dont know who you learned about cars from but I ALWAYS check my oil AT LEAST twice a month......Warranty DOES NOT COVER LOW OIL LEVELS.....
2012 Yukon XL Denali w/ 6.2 AWD |
09-15-2020, 03:05 PM | #32 |
Drives: '21 Wild Cherry ZL1 Join Date: Aug 2018
09-15-2020, 03:10 PM | #33 |
Drives: 22 ZL1, 20 Taco, 20 Cayenne S Join Date: Oct 2019
I'm having flashbacks to my GT350 days. Those you never had to change the oil, you just had to add it.
I've used 2 quarts in about 9k miles with one track day and a lot of spirited/fun driving. I don't think that is bad considering what kind of engine/car it is etc. This is extremely unscientific, but I kept my one track day 15-50 Mobil oil in all summer and it seems to like to burn that more than the 0-40 Dexos. |
09-15-2020, 03:44 PM | #34 |
1LE Convert
Drives: 2018 ZLE Join Date: Apr 2017
I only run Mobil 1 15W-50 and only drive my car to/from track and mechanic. I burn about half a quart per track day. Not sure if normal, but I haven't investigated it. Car seems to run fine.
2018 Camaro ZL1 1LE (Red Hot)
2002 BMW Spec E46 race car (Lizard Green) Previous cars: - 2018 Miata RF GT (Machine Gray/Auburn) - 2017 Camaro 1SS 1LE (Summit White) - 2008 BMW 135i (Montego Blue) - 1996 BMW 328i (Arctic Silver) |
09-15-2020, 05:28 PM | #35 | |
Drives: 2018 Hyper Blue ZL1 1LE Join Date: Dec 2018
Maybe there was a break in issue with the CRV, if someone drives a new car hard when it's cold I don't expect good results. Some people start it on a cold morning, drive 1 mile to the freeway onramp and punch it. |
09-15-2020, 06:55 PM | #36 |
Drives: 2017 ZL1 Join Date: Apr 2020
IMO it is from breaking them in with a full synthetic. See the same thing in modern 4 stroke outboards. Break in on Dino oil to let rings seat. I bought my car with 1900 miles so it was too late. But the car runs like a scalded dog . Just my opinion
2017 ZL1 M6 Silver Ice Metallic
09-15-2020, 08:27 PM | #37 |
Drives: 2020 Camaro ZL-1 1LE Join Date: Jul 2018
Oil Consumption
Zero usage in 6000 miles. 2k of that on a road course.
Home Track: NCM Motorsports Park
09-15-2020, 09:03 PM | #38 |
Drives: 18 ZL1-1LE, 10 JKU Join Date: Jul 2018
Mine is using a little bit of oil, but like minn19 mentioned, i too had a gt350 and Ford didn’t consider that voodoo as needing replaced til it burned more than 1 quart every 500 miles.
So OP don’t buy a gt350 lol, because waiting 6k miles you could’ve gone through more that the engine could hold and you’d get to pay for it... Does Chevy have a mileage limit set Per quart for replacement on these? |
09-15-2020, 09:21 PM | #39 |
21k is just barely broken in and shouldn't be using any oil. If it were mine I'd run a leak or compression test but so many problems could have occurred.
'20 ZL1 1LE A10,
09-16-2020, 07:30 AM | #40 |
Drives: Hyper Blue 2016 2SS 6M Join Date: Sep 2017
As much oil as these cars hold, if you maintain the level, you can probably run with 8 quarts even for extreme driving / track days with no issues. I don't recommend this, of course, but two quarts down on these cars is not like 2 quarts down when the capacity is 5 qts or less.
Baby Blue
09-16-2020, 09:54 AM | #41 |
09-16-2020, 04:26 PM | #42 | ||
Drives: 2018 ZL1 1LE Join Date: Jan 2020
WOW you guys that are ON ME about checking oil levels every 400 miles are really ON ONE.... For what reason would you do that on a car with less than 20k miles????
PLAIN AND SIMPLE IT SHOULD NOT BURN THIS MUCH OIL. regardless...... and to whomever wants to know who taught me about motors tell me how many motors YOU built that did this??? Quote:
A warranty most certainly does cover LOW OIL LEVELS if the engine is burning oil when it should not. I don't track this car nor sling it into corners..... If I did I would MAYBE be ok with it consuming a quart between oil changes every 4-5k miles.... A warranty would not cover if the "OIL LOW" Light came on and i kept driving it like a moron... that's not what we're dealing with here...... I mean it's pretty simple.... We have LOTS of dudes in here with NO oil consumption..... We have MOST dudes not coming in this thread because they have NO oil consumption.... And the leftovers are probably the ones who may have improperly seated rings..... i'll just tell the dealer to start doing the oil changes and every time it comes up under serviced i will document then start the lemon law research...
2018 ZL1 1LE Summit White M6
"MOVN WA8" currently stock 2012 CTS-V Diamond White A6 Coupe "Becky" 1995 Z28 1LE 383" LT1 A3 N2O Drag Car 9.06@153 |
