04-02-2023, 06:01 PM | #1 |
Pillar Pod and Banks Gauges
Has anyone installed this Pillar Pod with Banks Gauges for just street use? If so, what are you displaying? How hard/easy was the install?
https://zzperformance.com/products/c...uge-pillar-pod https://bankspower.com/products/bank...ge-datamonster
'22 2SS | Wild Cherry Tintcoat | Design Package 3 | NPP | MRC | A10 | NAV | Ceramic Coating | Full Frontal PPF | New Hood and Side Stripes | Michelin PS AS 4
Range AFM Disabler | Mishimoto Catch Can | Diode Dynamics side markers | Cold Air Inductions CAI | LLoyd Velourtex front/trunk mats with Camaro SS logo ZL1addons Deluxe Rock Guards, Stealth Lift Pads, and Tow Hook | Escort MAXcam360c | Footwell Lighting | Banks gauges in ZZPerformance pillar pod | Paddle shifter extensions |
04-02-2023, 08:49 PM | #2 |
Bunch of previous posts on this. But, TLDR:
04-02-2023, 08:49 PM | #3 |
Drives: 18 ZL1 - M6 Join Date: Mar 2019
I haven’t done the install yet, but I’m gonna reference this video when I do. Good luck with yours and provide feedback if you wouldn’t mind.
https://youtu.be/9-QDneCUzL8 |
04-02-2023, 09:25 PM | #4 |
Drives: 2022 Camaro 1SS 1LE Join Date: Nov 2021
Your horsepower numbers look very impressive. I am assuming you had to build the bottom end?
2022 Camaro 1SS 1LE 6-speed
04-02-2023, 10:19 PM | #5 |
I actually saw some of the other posts, and an install video. Should have worded my question a little different. I am really interested in seeing what people are monitoring with the Banks gauges. I didn't really see that in any of the other posts, but I haven't read every one of them.
Range AFM Disabler | Mishimoto Catch Can | Diode Dynamics side markers | Cold Air Inductions CAI | LLoyd Velourtex front/trunk mats with Camaro SS logo ZL1addons Deluxe Rock Guards, Stealth Lift Pads, and Tow Hook | Escort MAXcam360c | Footwell Lighting | Banks gauges in ZZPerformance pillar pod | Paddle shifter extensions Last edited by SS_Don; 04-12-2023 at 03:13 PM. |
04-03-2023, 06:28 AM | #6 | ||
04-12-2023, 03:10 PM | #7 | |
Drives: 2019 Summit White ZL1 Join Date: Mar 2020
I didn't see that in the PIDs. Does it pull the data from the ECU and you can make custom displays ...or am I missing something? I would like the Banks I Dash over the P3 and it looks like a wideband is enviable so the looks like pillar gauges are the way to go |
04-12-2023, 08:55 PM | #8 | |
Yes, the Banks reads the data from the ECM in realtime. You can set from 2 to 8 values displayed at any one time, and you can customize what values you see.
04-13-2023, 11:43 AM | #9 |
Understand the need for the Flex Fuel Sensor and the 50% fuel mix radiation. It was when I looked at the PIDs for a 2019 6.2 liter engine I didn't see the ethanol content. But it does show up in the 2016 Camaro SS listing. Assuming the settings will be the same for the most part or does any know if the ECMs are different?
Thanks Joshinator99! |
04-13-2023, 11:47 AM | #10 |
Different for a 2019 ZL1...
04-13-2023, 12:52 PM | #11 | |
Both my 2017 SS and your 2019 ZL1 will both use the same ECM (E92A). The 2016 SS used the E92 which is just a little bit different.
