04-06-2021, 05:35 PM | #1 |
HP Difference: 93 v. 104 u/l octane?
I'm going to have these two tunes prepared for my car, but I have never tested any engine and compared pump gas to race gas hp. In this case, it's 93 v. 104u/l. I wondering if anyone here has or knows a shop that has performed such tests? Do you have an opinion of what these dynos would show?
'20 ZL1 1LE A10,
04-06-2021, 07:49 PM | #2 |
Drives: 2018 Camaro SS 1LE M6 Join Date: Oct 2018
The car from the factory is tuned for 93. 100octane 200octane 500 octane won’t make any difference. Considering that your car is stock tune. But looking at your profile seems like you have tuned for your mods. Higher octane really just allows more timing. In tune means more HP.
Camaro 2SS 1LE, MBRP Catback, Mishimoto Catch Can, Rotofab dry, TSP1 7/8” headers,DSX FF, Pray ported MSD, 95mm TB
492WHP 473WTQ |
04-06-2021, 08:05 PM | #3 | ||
04-06-2021, 09:54 PM | #4 | |
Drives: 18 zl1 Join Date: Aug 2017
I don't have any reason to not believe them, but it does seem to be a bit proud |
04-06-2021, 10:14 PM | #5 | |
04-06-2021, 10:36 PM | #6 |
Dumb Ass Deluxe
Drives: A Tricked Out Mountain Bike Join Date: Jun 2019
IMO, you should be running higher than 93 octane in your motor. Keep adding octane until the KS stop picking it up. 1 gal of xylene to 10 gal of pump gas will raise octane 2 points.
(91-->93. 93-->95) Or, obviously, 5:1 will raise it 4 points Keep adding a gallon to creep up on the actual amount you need to stop knocking and add 1 more point for insurance and that's what your engine should be drinking. Any higher octane than necessary is a waste of money, fuel, and lowers power.
04-07-2021, 12:45 AM | #7 |
Drives: 2018 Chevrolet Camaro 2SS 1LE 6M Join Date: Jul 2019
Add a flex fuel sensor, tune for 93 and E85, and call it a day.
Bolt-ons.
04-07-2021, 07:16 AM | #8 |
Drives: 2021 300 Join Date: Jan 2015
Gasoline does not create Horsepower. It supports the Horsepower the engine has built into it. Thru ignition.
04-07-2021, 11:52 AM | #9 |
These results are on a Gearhead Automotive Performance tuned 2016 Ford twin-turbo 3.5L V6. We'll put it on the dyno soon and find out:
'20 ZL1 1LE A10,
