10-24-2018, 06:22 AM | #1 |
Drives: 2018 ZL1 2015 1SS 1LE Join Date: May 2013
LSX F1A guess
My build is getting it's final tune this week. New LSX B15 crate engine, F1A procharger, race inter-cooler, E85, Fore dual pumps, AUS 1300's, FAST intake, long tubes (no cats), Dewitt radiator and all the supporting goodies.
Going to be pulleyed for 15lbs of boost. Shop is doing a dyno day on Saturday 10/28. I'm not going to see final numbers until then. Any guesses on what the numbers will be? Big THANKS to Vector Motorsports in Brighton MI for all the work. I'll post final engine bay pics on Sunday. They did some custom fab work to make it look as good as it performs.
2018 ZL1 2015 1SS 1LE Stock...ish Last edited by Buschman; 10-24-2018 at 12:18 PM. Reason: Boost |
10-24-2018, 08:40 AM | #2 |
Depends on how that F1A is pullied. It should put down some killer numbers on E85 without a doubt. I'll say 945/849
10-24-2018, 08:52 AM | #3 |
21 pounds should get about 1100. You can do the math from there.
10-24-2018, 09:53 AM | #4 | |
Oh man that is going to be a beast. Let me know how much boost you are going to run ? Are you going to do the 15lbs of boost the LSX recommends ? What other mods are you doing to get this baby faster ? Did you change the diff, axles, driveshaft, or are you adding a meth kit as well ?
Specs
TSP Stage 2 Boosted Cam 227/235 at 114 LSA Fore Innovation Triple pump staged (Walbro 342 primary and 2x Walbro 450 secondaries) Procharger D1x with a 3.85 pulley ID1050x Injectors Flex Fuel Sensor Monster LT1 Twin Disk Clutch Holley Sniper Efi Intake Manifold NW 103mm Boosted TB 747rwhp at 12psi on E85 |
10-24-2018, 11:39 AM | #5 |
Drives: 2010 Camaro 2SS M6 - Intake/Exhaust Join Date: Sep 2014
in for results!
10-24-2018, 12:30 PM | #6 | |
Driveline and suspension was done last year. RXT 1200 clutch, G-Force driveshaft and outlaw axles, re-built diff with tru-track/JRE caps/LPW cover 3.91 gears, Pedders bushings, Pegasus sub frame bushings, JPSS 32mm sway bar and Pedders XA coil-overs. Running 17” Racestars with 305 ET street R’s. Not going with meth yet. Last build was a forged ls3 big cam nitrous setup. Going to have to relearn how to drive the car!
2018 ZL1 2015 1SS 1LE Stock...ish |
10-24-2018, 12:38 PM | #7 |
Math isn’t fun. Always been more of a SWAG guy.
10-24-2018, 01:58 PM | #8 | |
I am saving my pennies for a 416ci boosted stroker but I am going with a D1x cause I don't want that much power. Meth will help with IAT but if you are running E85 that should help with internal temps.
Specs
10-24-2018, 06:12 PM | #9 | |
I was thinking about building a stroker, but then I came across the LSX crate. Saved me time, money and will be more reliable than a stroker IMO. Two more test and tunes at Milan Dragway this year. I’m going for 10.75@130+. I wanted to make sure I have more than enough car to get there. Should be all about the driver now.
10-24-2018, 07:13 PM | #10 |
Drives: 2012 2SS/RS LS3 Join Date: Dec 2011
My F1-A build hit almost 850 rwhp, maxed out with a 3.85 12-rib on E-85. That's a low compression 427 though. I am getting limited by too small of headers.
2012 2SS M6, ERL Superdeck 6 427, PRC 255 Heads, Procharger F1A w/ 3.85 pulley, 1300hp intercooler, Squash Dual 450lph, E85, ID1700, RXT Clutch, DSS 1pc driveshaft, GForce axles, Eaton Detroit Trutrac, a bunch of other crap I don't feel like typing.
10-24-2018, 07:43 PM | #11 |
How many pounds of boost did you make on that pulley? The LSX is running at 9:1 compression too.
10-24-2018, 09:10 PM | #12 | |
For me I have the stage 2 air to air intercooler. Like I said before all of these things are waiting in the garage until I have the 416 stroker on the 1LE.
Specs
10-24-2018, 10:46 PM | #13 | |
You're going to want to take those 3.91s out for a lower gear. That is gonna spin like crazy |
10-25-2018, 06:29 AM | #14 |
I went with procharger’s race intercooler.
Thread Tools | |
