01-30-2017, 09:58 PM | #1 |
Drives: 2018 ZL1 2015 1SS 1LE Join Date: May 2013
New to turbos
Just going to throw this out there, hoping to get some opinions/advise.
I have a 2015 1LE and plan to put a twin turbo kit on it very soon. Never ran anything non NA, but have spent some time reading and have a good idea on what I may need. I have an interest in the not yet released Huron Speed Twin kit. I'm not going to go crazy (at first) planing on 600 rwhp / 600 ft/lb at about 8 psi, make it a lot more fun but reliable for a daily driver. My budget is undecided, but I don't want to cheap out and don't want to go nuts. According to their posts the kit will be mostly bolt on, and includes everything but fueling components. I have the ZL1 fuel pump (1LE), what size injectors should I be looking at? I plan on keeping the stock internals (for now) other than fuel, is there anything else I should focus on engine wise? Keep in mind I'm going for 600/600. I may swap out cylinder head bolts to be safe. Since the car will be in the shop and on the lift, I plan on swapping out the clutch to handle the added power. I know that is not necessary, but I usually like to over build and under use. For now I'm going to keep the NPP 2.5" exhaust and JBA high flow cats. Since it's going to be pretty low boost those should work, right? Any thoughts or input would be helpful, thanks!
2018 ZL1 2015 1SS 1LE Stock...ish |
01-30-2017, 10:00 PM | #2 |
Drives: 2006 Z06 Join Date: Oct 2010
AGP kit, and done.
Nick
Corvette Z06 -1200ish rwhp |
01-30-2017, 10:15 PM | #3 |
I 2nd the agp kit, its been proven to be a great and reliable kit, plus it uses high quality component's that mirror oem quality manufacturing , the only con for some is the turbos are hidden down below, opps forgot one other pro, agps customer service is top notch especially Kevin
Cai intake and a few other mods😎
01-30-2017, 10:51 PM | #4 |
Drives: 2014 Camaro 2SS 1LE Join Date: Jul 2015
3- to AGP kit!!!! I'm 2014 1le on everything stock 850cc and BAP+ meth kit! I made 672/695 on 12psi and it's safe ! Now I put triple clutch , triple pump with flex on stock long block 807/811 on 13.5psi ! I'm in Ohio and drive car ad DD on winter( just 4 sand bags in trunk on all season tires! AGP very well done kit! Contact Kevin he very helpful!!!!!
AGP TT 807whp 811wtq 13.46psi E85+methanol
01-30-2017, 11:09 PM | #5 |
Drives: 2009 ZR1 Join Date: May 2010
4th for AGP. You're only issue will be making only 600whp
01-30-2017, 11:39 PM | #6 |
'It's an experiment'
Drives: [COTW 2/09/15] '11 GPI LSA SC Z/LE Join Date: May 2014
747 RWHP 794 RWTQ
"Horsepower sells cars, torque wins races." - Enzo Ferrari See My Build: http://www.camaro5.com/forums/showthread.php?t=385577 |
01-31-2017, 02:19 AM | #7 |
Drives: All things Turbocharged Join Date: Dec 2010
+5 AGP
Since you aren't going for the moon on hp, go with some smaller turbos that will spool really quick even on your stock engin. 54/57 in .63 are fast and have made 840whp. |
01-31-2017, 06:53 AM | #8 |
Okay the AGP kit has my attention.
What injectors should I be looking at for my 600/600 goal that will allow room to add more later? Should I consider spark plugs too? Will the NPP exhaust work well with the AGP kit?
2018 ZL1 2015 1SS 1LE Stock...ish Last edited by Buschman; 01-31-2017 at 07:28 AM. Reason: blah |
01-31-2017, 06:59 AM | #9 |
Drives: 2011 Camaro 2SS Join Date: Sep 2015
I like hellion personally, i like opening up the hood and seeing twins
01-31-2017, 07:06 AM | #10 |
60# would work but might as well get some id850's or equivalent when/if you decide to go more hp
2010 Camaro 2SS/RS LS3
1093/1066 416, AGP 6262, E85, Cam |
01-31-2017, 07:12 AM | #11 |
Kevin can answer all that on the phone while ordering. You can do 850 or 1000cc injectors, it all depends on how much room you want to grow. They also have plugs. Depends on power level. For 600rwhp 1 step colder is fine. If you want to make 800+ later then just plan on swapping them out for some colder plugs later.
Nick
01-31-2017, 07:28 AM | #12 | |
Drives: 2014 SS 1LE Join Date: Apr 2014
First, your jba cats wont work, but you will reuse your stock manifolds. Second, I give another vote for AGP. I have their kit sitting in my living room and will install it once it warms up a bit here in Ohio. AGP was there to answer my dumb questions and quick to respond when I had an issue. I am not sure what to think about the Huron twin kit. It looks like it may be nice. But also, I didn't see any other kit for sale in the classified section more than their single turbo kits. Your goal of 600 will most likely go up once you achieve it. Might as well prepare to be bitten by the bug lol. |
01-31-2017, 07:40 AM | #13 | |
01-31-2017, 07:41 AM | #14 |
Drives: 2015 Camaro 2SS 1LE Join Date: Feb 2015
Agp all the way. You'll probably have issues only making 600. I made almost 700 @ 8psi on e85. Also, you'll always want more with the ago there's room to grow. I made 830whp @ 15psi with the base turbos. If I wanted more I would just need to go with some bigger ones, and the kit is has proven itself time and time again.
AGP Twin turbo kit, base 54/57 Borg Warner turbos, TSP stage 4 N/A cam, AGP twin 430lph e85 pump fuel system w/ flex fuel sensor, 1000cc FIC injectors, Grimm speed manual boost controller. (830 rwhp 778 rwtq @ 15.5 psi)
Thread Tools | |
