04-12-2014, 10:25 PM | #1 |
Drives: 2010 Camaro 2SS Join Date: Jun 2013
Balanced to understeer during autocross
Would like some advice. Current setup:
20x10 rear, hankook ventus v12. (275-40-20) 20x8.5 front, michelin pilot super sport (255-45-20) 1" lower Bmr sway bars, full stiff rear, middle front BMR pro bushing kit My issue was that at test n tune today, during the morning the car was perfectly balanced and very sticky, but as the day wore on i seemed to lose front grip. I ran rears at a constant 36 and modulated the fronts between 38 and 34 hot trying to help, but nothing made it handle like it did in the morning. Best results were actually at the 34 hot. Tires never felt overheated. They got warm but I could leave my hand on them without being uncomfortable Anyone have ideas as to what i may be doing wrong? Considering putting the front way bar at its loosest setting to try to help with the "hot" understeer.
PIN IT TO WIN IT!
04-12-2014, 10:58 PM | #2 |
Drives: '14 1SS 1LE white Join Date: Nov 2013
When surface temps rise grip usually improves, and the rear tires on a RWD car usually benefit first.
You didn't mention how much front camber you're running either. Did you spray the tires at all during the event? |
04-12-2014, 11:04 PM | #3 |
Drives: 14 1SS Camaro 1LE, NPP, Recaros Join Date: Nov 2013
go full soft on the front or drop some front PSI, add camber, if you have the $$, go to a square setup like the 1LE, 285 all around. Try left foot braking to provoke trail braking.
04-12-2014, 11:16 PM | #4 | |
alignment that I got about 3 weeks ago, requested specs as close to the "aggressive street" settings that I could get using pretty much all stock adjustments Front Toe: 0" total Front Camber: -1 and -1.1 deg caster: 6 and 5.5 deg (no adjustment available) Rear Toe: 1/8" total (in) Rear Camber: -.6 and -.7 deg Square setup is definitely a priority in terms of planned upgrades, may have to wait til next year though. Not worth it to buy bigger rims and run these tires (they will fit 20x10) and selling tires/rims isnt really cost effective either, just gotta deal with it best I can until it's time for new fronts. I appreciate the input!
PIN IT TO WIN IT!
04-14-2014, 09:49 AM | #5 |
corner barstool sitter
Drives: 08 Mustang GT, 19 WRX Join Date: Jul 2012
Just guessing that you got a bit more aggressive and faster as the day progressed, to the point where -1°-ish front camber wasn't enough any more (particularly with those wheel width and tire differences).
Did anybody notice where your outside front tire cambers were in the middles of turns? Or better yet, took pictures? Norm |
04-14-2014, 01:32 PM | #6 |
Drives: pleather and Chiclets Join Date: Mar 2012
Mr Peterson is spot on with that camber. My "agressive street" alignment has twice the camber front and back. There is definatly some room in your posted alignment for speed.
04-15-2014, 09:12 AM | #7 |
Drives: 1994 1LE / 2006 Z51 Corvette Join Date: Jul 2009
I agree with the posts above, you need more camber front and rear for sure. I don't know if I would go any more toe on the car, if you are not going to swap it between street and track settings.
For sure the car would greatly benefit from a wider front tire, even on our race cars running 305's front and rear we were still fighting a push to some degree depending on the track. Nothing beats more rubber on the ground. Did you by chance get any tire temps? |
04-15-2014, 03:10 PM | #8 |
Casey Woodside
Drives: a very fun car Join Date: Jun 2010
Going with a squard set up will help out a ton will fix just about all under steer problems
Instagram @caseywoodside
http://youtu.be/CSc9aPh_X_w |
04-18-2014, 02:09 PM | #9 |
Update:
Softening the front sway bar to loosest definitely helped the second day. Still felt like I was starting to lose grip as things got hotter though. Ill assume it's like Norm said, I was just getting more aggressive as I ran. Never did get temps, I've just got my good ol fashioned pressure gauge. Hand could stay on the tire without burning. Will definitely try more camber...and also the first competition put the bug in my butt. I can make podium with my current setup but 1st place is going to require superior tread and wider fronts, I'ma bite the bullet and just do it. Considering 20x10 TSWs all around and Hankook RS3. Any opinions are appreciated
PIN IT TO WIN IT!
04-18-2014, 02:51 PM | #10 |
What class are you running in?
Be careful when making mods at autocross - in SCCA, 10" wide wheels will bump you out of the Street and Street Touring classes up to Street Prepared all by themselves. Norm |
04-18-2014, 03:00 PM | #11 |
Negative Camber Junkie
Drives: 2010 1SS LS3/6MN ABM 1 of 23 Join Date: May 2009
I will leave this here for you too.
T.
"Horsepower is something that looks great in a Magazine article, but suspension is what actually gets you around the track fast.." Jack Olsen
The drag strip is like sniffing glue, it's cheap, it's a decent buzz, it doesn't last long and they are all the same. Road racing is like China White Heroin, the buzz is stronger, the high lasts for hours, it's extremely addictive and they are all different. I can't wait for my next Track fix. DA HAWKS OWN DA CUP!!!!! |
04-18-2014, 03:36 PM | #12 |
Drives: 2010 2SS/RS Join Date: Mar 2010
^Diggin that graphic - Thanks TBone!
2010 CGM 2SS/RS:
Pfadt'ed Out Level 4, Pfadt Featherlight Coilovers, Pfadt ZL1 Sways, Pedders Radius Rod Inserts, CTS-V Brakes, Borla S-Type, Quad Tips, Forgestar 22" F14's (Show), CAI Intake w/ scoop, Rx Catch-Can, AAC Lighting, Showstopper Sidemarkers "Information is the oxygen of the modern age" Build Thread |
04-18-2014, 08:51 PM | #13 |
TESP. Other mods aside from tires/wheels put me there already (see first post)
PIN IT TO WIN IT!
04-18-2014, 10:13 PM | #14 |
Shirley. I mean surely. Dammit I meant, oh hell with it.....
T.
