11-09-2020, 04:46 PM | #1 |
Continental ExtremeContact DWS06
Front: 245/45ZR20XL Rear: 275/40ZR20XL
35k on tires and moving Tires feel like they must be 35 psi on all 4 corners. Warmed up with minimal driving will increase them to 36-37 psi. Tpms doesn’t seem to recognize them if they aren’t the stock pirellis. Sensors might be worn out but not worried about it due to the fact that they get checked before every start up and still get reed fairly well on the dash after relearning... Eventually will be replaced. High maintenance tires but worth every penny. Catch myself driving faster than everyone else in the Chicago snow or rain. |
11-12-2020, 08:11 AM | #2 |
Drives: 2014 Camaro 2SS/RS 1le Join Date: Jan 2017
Holy crap, 35k out of performance tires! Wow
2014 Camaro 1LE SS/RS THE MISTRESS
11-12-2020, 08:50 AM | #3 |
I run these on all 4 corners. Fronts are 275/35 and rears are 315/35. The fronts are only the second set on there and am at 118k on the odo. The first set on the front I got 65k out of !! Keep the alignment right and the pressures at 35 cold all the time. I really like these tires. The rears,,,we on the 3rd set of those. lol. Great tires and worth it.
11-12-2020, 09:35 AM | #4 | |
2013 Camaro SS/RS, Stainless Power long tube headers with HF's, Air Raid CAI, Solo Mach XL cat back, BC Racing coil overs, Elite Engineering catch can, Ferrada Forge 8 Wheels, Windows tinted at 20%, Tuned by Dyno Steve.
11-12-2020, 10:50 AM | #5 |
Jedi Master
Drives: Boeing 757/767+2010 IBM 2SS Join Date: Aug 2008
TPMS doesn’t recognize them? TPMS doesn’t know if you put whitewalls from the 1950s....it measures air pressure. But TPMS is driven by batteries in each sensor, which it appears have died in your case. I changed all 4 sensors when I put new tires on back in September after almost 11 years (but only 17000 miles).....as you have higher miles, the sensors need to be replaced.
11-12-2020, 11:02 AM | #6 |
Drives: 2013 2SS/RS Convertible Join Date: Apr 2016
11-12-2020, 03:09 PM | #7 |
No, they are the DWS06'S.. I just went to look. Sorry if I confused anyone.. I thought they were all the same. These that I have are supposedly a new blend of compound than the first set I had on there, so they said. I had to wait a bit when I ordered them for them to come in as the compound I had before had been discontinued.
11-13-2020, 10:08 AM | #8 |
Ahh gotcha. Im not sure how you have traction at all with that amount of power you are putting down. I break loose constantly and I dont put down what you do. I have thought about going with the Sports next time as they are a summer tire and should be stickier. Not to say these are good tires though. I have always had great luck with Continentals. Our old 2003 Mazda MPV had a set after the ones that came with it and only changed those years later due to them dry rotting. I think they were on there for around six years and still had most of their tread left lol. There again, when we sold it, it only had 77K miles on it.
11-13-2020, 04:11 PM | #9 | |
SomeguyK
Drives: 2010 Black 2SS/RS Join Date: Nov 2014
TMS 427, Dart iron Block, Forged assembly, Frankenstien heads, AGP TT 62/62 BB turbo's, AGP/Fore triple fuel system, Tilton clutch, Holley 1 7/8 shorties, Technostalgia tail lights,Oracle, Aeroforce, MGW shifter,Flowmaster, Pegasus subframe bushings,BMR trailing & toe arms,Z28 UCA bushings,Zl1 rear sway bar,Prothane,BMR,Goodridge brake lines,Ridetech HQ coilovers,3.91,Trutrac,billet caps,DSS axles,HE offest,built TR6060,1LE diffuser,Havoc spoiler,SSclones,20in MRR 017, Pirelli P Zero, Nitto NT555RII
More to come. |
11-13-2020, 11:50 PM | #10 |
Then I guess that settles that doesnt it lol. Wont be trying those out.
11-14-2020, 04:10 AM | #11 |
11-14-2020, 07:59 AM | #12 | |
11-14-2020, 01:57 PM | #13 |
SomeguyK
Yup, for anything more than touring they suck. Break loose easily. They are OK in the rain. The MPSS weren't much better. I run Pirelli's up front and The new Nitto nt555r2 in the rear. Track great, great in the rain, and stick on launches and 40mph rolls.
More to come. |
11-14-2020, 07:59 PM | #14 |
Thank you. Decent tread life with the 555?
Tags |
tires |
