06-07-2019, 08:41 AM | #15 |
I'd imagine that it weighs more...
06-07-2019, 10:03 AM | #16 | |
Drives: 17 Camaro SS 1LE & 16 Sierra AT CC Join Date: Nov 2016
Which OEM ZL1 did you end up going with, is it a bolt in item?
2017 Camaro SS 1LE - Procharger D1SC w/ Tial 2" BOV & Race intercooler / ARH full length catless headers / Alky meth injection system - 650rwhp on conservative tune SOLD |
06-07-2019, 01:31 PM | #17 |
Drives: SS 6 speed of course Join Date: Jan 2016
https://sdparts.com/i-24104126-chevr...ft-system.html
https://www.chevrolet.com/performanc...maro/drag-race You can get it for about $1000 shipped. It is back-order so expect to wait.
06-07-2019, 06:16 PM | #18 |
Drives: 17 2SS, 8L90, Cam, Heads, E85 Join Date: Dec 2016
Does anyone think the stock 2 piece driveshaft along with the excessive slope in the rubber carrier fake bearing thing is the reason for the cheap sounding clunks and sorry NVH qualities the camaro has? (especially when shifting between drive and reverse) Or is it just the excessive backlash GM like to build into the ring and pinion gear? I can't believe no one else notices it and its quite embarrassing to have almost brand new car clunk and clang every time you shift to reverse and clunk every time you let on and off the gas. My assumption is the gear in the SS with the cooler option is probably set up with more backlash due to operating temps that could be encountered on the track than a standard differential.
Sorry to derail the thread but I would consider a aftermarket driveshaft a lot more if it helps this horrible NVH problem the camaro has. |
06-07-2019, 07:55 PM | #19 | |
Drives: 2017 SS 1LE Join Date: Sep 2011
06-08-2019, 08:32 AM | #20 |
I'm almost positive its the excessive backlash in the ring and pinion. If the car is parked on a hill facing down it completely eliminates it since the wheels are trying to push the rest of the driveline forward so it takes up the slack. Then you can put it in drive or reverse and it feels like a normal car.
06-08-2019, 11:44 AM | #21 |
No clunking here. Do you have a tune? Did it do it stock?. There’s a setting in the transmission to minimize clunking.
My 6spd doesn’t do that tho Maybe ur lucky and ur universal is shot? |
06-08-2019, 01:58 PM | #22 | |
06-08-2019, 03:05 PM | #23 |
The stock shaft is really a well made item and the SS manual is the same shaft as the Zl1 convertible manual. FYI. My stock shaft is 14 lbs including the center bearing and support but not the 12 bolts and 2 rubber donuts (don't know what happened to them). It has been posted the whole thing is 22 lbs which is believable....
06-09-2019, 08:54 AM | #24 |
You are exactly right, you preload the driveshaft and take up the slack. I drove an ATS loaner with the 2.0T and the issue seemed somewhat better but still present, which is especially ridiculous on a Cadillac. My logic tells me its got to be extra backlash added for high temp operation, the 14bolt FF axel in my Duramax was the same way but worse, you could almost literally count seconds before hitting the gas and feeling the bank clunk when all the slack was finally taken up. It also makes a very audible noise through the whole car, which is surprising that GM did so much to make so much stuff quite but ignored this.
06-09-2019, 08:59 AM | #25 | |
I think they could have eliminated this through software, maybe they couldn't because of patent infringement or something? |
06-09-2019, 01:18 PM | #26 | |
Except what you’re actually doing is decoupling your transmission from any driveline loads. It removes the clunk because your transmission doesn’t have to break the parking load to shift into gear. The clunk is the auto, not the driveshaft/diff. Sent from my iPhone using Tapatalk
2017 1SS 1LE - Eibach Springs | Pray IM | Katech TB | Borla 60606 | Corsa Extreme | E85 Flex Tune
06-12-2019, 07:23 AM | #27 | |
You can make the same clunk happen when coasting and letting DFCO come on then press the gas and its loud enough its easily heard and felt driving. It drives me insane haha |
06-12-2019, 11:21 AM | #28 |
the center support is really flimsy. If I had any issues I would look into pouring liquid urethane into it.
