04-05-2022, 08:19 PM | #1 |
A10 Tap Up 2nd gear in manual ?
Is it possible while in manual mode, and while not moving, to tap the trans up from 1st to 2nd gear? HHP told me this can be done, but I tried it today with no luck (?)
'20 ZL1 1LE A10,
04-05-2022, 09:44 PM | #2 |
Petro-sexual
I haven't seen it. I believe you have to downshift to 2nd before coming to a stop and it stays in that gear. That's how I've got it to work. I can't force-shift it from 1st at a stop.
04-05-2022, 11:22 PM | #3 | |
Drives: Chevrolet Camaro, Ford Mustang Join Date: Oct 2019
Best regards, Dave
2022 SS 1LE - Vivid Orange - SCCA CAM-C & Optima Ultimate Street Car GT
Katech, MSD, QA1, Hurst, Anderson Composites, ProParts USA Custom Suspension, MFR Engineering, Forgeline Wheels, G-Loc Brakes, Nine Lives Racing, MTX Audio, Penske Rapid Repair |
04-06-2022, 07:48 AM | #4 |
#A8Lyfe
2016 NFG 1SS A8
04-06-2022, 11:39 AM | #5 |
04-06-2022, 12:31 PM | #6 |
Drives: 22 ZL1, 20 Taco, 20 Cayenne S Join Date: Oct 2019
Just curious as to why one would want to do this (traction/MPG)?
04-06-2022, 01:15 PM | #7 |
Petro-sexual
Because higher-power combinations can blow the tires-off so much easier with that really short 1st gear ratio. Starting in 2nd can help reduce effective torque from the line.
04-06-2022, 01:18 PM | #8 | |
Drives: 2018 Camaro ZL1 Join Date: Aug 2018
1st gear is very short so starting is 2nd gives the car a better launch and more time to gain some MPH before needing to shift. Plus helps the car from making the tires go up in a smoke show. It's good for those that drag race or red light race. Doesn't benefit us who do what the car was meant to do..... |
04-06-2022, 01:24 PM | #9 | ||
04-06-2022, 02:15 PM | #10 |
Don't use the factory launch control. It's ok but the old school method of foot braking works better.
04-06-2022, 02:51 PM | #11 |
04-06-2022, 03:55 PM | #12 | |
Drives: 2019 ZL1 Join Date: Mar 2019
It can be done in the tune. CSP does it. Not sure about 2020+ with the tcm swap but should be the same.
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90 |
04-06-2022, 09:13 PM | #13 |
Correct me if I am wrong but from what I seen CSP tuning doesn't allow you to upshift to second from a stop. It keeps the trans from ever downshifting into 1st on the A10 when in manual mode. Granted the info I seen from CSP was from a couple years ago. Either way there isn't much in the A10's tune file via HPt that allows any changes other then TUTD shift scheduling.
2016 NFG 1SS A8
04-06-2022, 10:22 PM | #14 |
Petro-sexual
Like King' said below - the only video Andrew shows (that I know - and I've watched all videos, except the Tesla garbage) is him coming to a stop and all that I just described. Maybe he was holding back more, but I'm with King' on what he's said. He's got a lot more experience than me, but I've been over my TCM file for as long as it's been installed, and it all matches what CSP posted. I'd like to know if I'm wrong though.
