05-08-2021, 09:41 AM | #1 |
Drives: 2010 Turbo LS3 Join Date: Dec 2009
Is This a Blown Head Gasket
I took the turbo manifold off because I had an exhaust leak and as I was putting it back together I noticed these little pieces of wire from between the head and block sticking out below #5. The plugs from 5 and 7 are also lighter in color on the tips than 1 and 3.
Gaskets are factory LS9s. No water in oil or oil in coolant.
2011 Vert - 416/w 230/236 .612/.602 115lsa, 1LE suspension w/32mm rear bar. Z28 diff. ZL1 brakes. Last edited by CamaroCracka; 05-08-2021 at 11:18 AM. |
05-08-2021, 09:44 AM | #2 |
Drives: 2015 1LE Join Date: Oct 2015
sure looks like it
2015 1LE, TSP 225/236 113+3, VMAX Throttle Body, CAI with race scoop, GPI Ported Intake, Land Speed Stage 2 Heads, 1-7/8 headers, NPP exhaust, 25% Fluidampr, LT1-S Monster Clutch, 485 RWHP & 444 TQ
05-09-2021, 01:27 AM | #3 |
Drives: 2010 LS Join Date: Feb 2021
It's blown when oil or coolant is LEAKING from it.
The block looks dry to me, so it's not blown out there, you would have an oil leak there. Those plugs really aren't telling a story either. |
05-09-2021, 09:56 AM | #4 |
Thanks Alan, I'll start it today and update. Those little slivers of gasket have me concerned
2011 Vert - 416/w 230/236 .612/.602 115lsa, 1LE suspension w/32mm rear bar. Z28 diff. ZL1 brakes. |
05-09-2021, 10:23 AM | #5 |
Thank god you are not working on my car.
05-09-2021, 05:22 PM | #6 |
I just took it on a shake down run and exhaust tick is gone. Seems to be running normally.
05-10-2021, 01:45 AM | #7 |
05-10-2021, 02:02 AM | #8 | |
compression to escape out of the engine, causing a ticking noise at idle that can sound like an exhaust leak. You will also experience rough running, and a loss of power. https://haynes.com/en-us/tips-tutori...asket-can-fail Can you feel AIR coming out? |
05-15-2021, 08:26 AM | #9 |
Rather than burn the crap out of my arm, I taped a piece of paper over the area and there was zero sign of any air, fire, or fluid coming out after I started it and let it run a minute. Only thing I can figure is I must have drug the turbo manifold across that area and broke those little pieces of wire free. Time to put the slicks on it and make a few more runs.
