04-19-2021, 05:42 PM | #1 |
Drives: 2012 Camaro SS A6 SIM Join Date: Nov 2016
Oil weight for dry sump.
Recently installed a ARE dry sump system in my Camaro. Uses stock oil pump for pressure. Currently running 5w-30 at the moment. Any input on what would probably be a a better weight to run? Opinions welcomed.
04-19-2021, 06:51 PM | #2 |
Drives: 2014 Camaro SS 1Le Join Date: Feb 2016
5/30 is fine. I have 5/30 in my C6Z, and it works just fine.
2014 SS 1LE Money Pit/ Forged 402
CAM 22X/24X, .619/.617, 113 LSA/ LS9 Heads FIC 1200cc/DSX Aux Pump//McLeod RXT Clutch 730whp: 630Trq |
04-19-2021, 08:10 PM | #3 |
Did you alter the factory bearing clearances? If motor is stock otherwise, no reason to change oil viscosity just because you changed from a wet sump to a dry sump setup.
Slick mod, though! I'm gonna have to check that out... |
04-19-2021, 08:56 PM | #4 |
Only thing I hate with the dry dump, is that you have to unscrew 2 bolts to drain the oil (for my c6z at least). Idk how yours is set up.
04-20-2021, 09:44 AM | #5 |
What dry-sump kit are you running?
2013 1SS/1LE
Corsa Extreme cat-back, Speed Engineering LT Headers with black ceramic coating, C7 Z06 Front Brake Upgrade, Mishimoto Oil Cooler, BMR Tunnel Brace, Mishimoto Oil Catch Can, MSD Plug Wires, Mishimoto Radiator and Hoses. |
04-20-2021, 11:46 AM | #6 |
Evil Genius of Chevrolet
Drives: 2017 Z06, 2019 XTS, 2013 SS Join Date: Feb 2017
I was told that if you want to increase pressure you can safely run 0-40 in our engines.
GPI SS2 VVT cam, ECS Novi 1500 supercharger, Corsa Extreme, Detroit Speed and BMR suspension, Circle D triple disc, Melling oil pump, LS2 chain tensioner, ATI 10% UD, DSX E85 kit, High Energy coils, BTR springs, LS2 Lifter trays, Titanium retainers, hardened push rods, FIC 1000 injectors, ZL1 pump, Mighty Mouse catch can, AEM gauges, Tial BOV, Richmond 3.91 gears, Custom gauge bezels, Speed Engineering headers, Stainless Works HF cats, DSX Aux pump, 710rwhp on E85.
04-20-2021, 03:07 PM | #7 |
04-20-2021, 03:16 PM | #8 |
Tank is mounted in the trunk. Pump itself takes the AC compressors spot.
04-20-2021, 05:42 PM | #9 | |
Filling mine with about 9qts (8 + ~1 for the oil cooler) is already about $150 in AMSOIL every 3k miles. But 14 would be insane! Was looking at doing dry sump in the future to keep the engine happy on the road course/Auto-X.
2013 1SS/1LE
