View Poll Results: Do you have 2nd Gear Grind, what's your shifter? | |||
OEM | 75 | 28.85% | |
OEM Hurst | 76 | 29.23% | |
Aftermarket | 49 | 18.85% | |
No | 60 | 23.08% | |
Voters: 260. You may not vote on this poll |
Thread Tools |
03-04-2012, 02:32 PM | #57 |
I have a 2012 and it grinds into second at any rpm and any temperature shifting fast. Shifts fine slowly although notchy.
There's more to life than gas mileage
LS3, Whipple, Custom Comp Cam, springs, pushrods, timing set, CAI intake, Apex cold air scoop, Doug Thorley TRI-Y headers, Billet Custom Products baffled Valve covers, Mighty Mouse Catch can, ADM FPCM, ZL1 fuel pump, MSD boost-a-pump, Hex Vent hood vents, ProSport gauges(fuel pressure, AFR, Boost), Corsa, 100 cell Cats. Jannetty remote tuned, Pfadt trailing arms, all parts user installed. No Dyno yet. Manual trans. 3.45 gears. |
03-12-2012, 08:26 PM | #58 |
I just got mine back from the dealer in time to park it for the winter. Out of all the TR6060 tremecs out there (Ford Dodge and Chevy),It seems to be just us Camaro guy/gals that have the problem. Them is with the syncros. My trans was completely torn apart by the dealer. They said that the syncros were the cause. and because of this 2nd gear was chewed up a little. The also said that blocking ring looked burnt and discolored.(prob something to do with the skip shift). The problem I had was, I could granny shift it all day long no prob. Get on the throttle though and 2nd grindage. But only got the grind in 2nd power through every other gear no prob. It`s not caused by any of your shifter but on other threads people have said it is more noticeable with a shot shifter. I have since bought a skip shift eliminator for mine in the hopes that I don`t have anymore issues.
03-12-2012, 08:32 PM | #59 |
1100 miles new and did it twice.... cant say which shifter i have.....happened in a hig rpm shift...
03-13-2012, 02:15 PM | #60 |
Drives: '11 SS, M6 Black w/ IOM stripes Join Date: Jul 2011
Agree with zkengo, mine does it usually about the point you would expect skip-shift to kick in (OEM Hurst, 15k). Has happened maybe a dozen times, but only a couple that made me wince. Gotta be something to do with the threshold it wants to skip at
2011 SS/RS with Hurst short throw. New Era OTR intake, Texas Speed 1 7/8" LTs, Magnaflow mufflers, tuned by Haddad: 420hp/421tq
03-13-2012, 04:00 PM | #61 |
More Human Than Human
Drives: 2011 1LT IOM M6 Join Date: Feb 2011
I'll just leave this here...
Sent from my Samsung Infuse 4G |
03-14-2012, 12:57 PM | #62 | |
Drives: 2010 2SS CGM Camaro, 1988 6.6L IROC Join Date: Mar 2010
http://www.modularfords.com/forums/f...oblems-173258/ http://www.fordgt500.com/forums/showthread.php?t=9441 http://www.challengertalk.com/forums...rinding-64972/ FYI... skip shift eliminator will not resolve the issue. |
03-22-2012, 03:04 AM | #63 |
Drives: 2012 2SS LS3, 2012 Ford Focus SE Join Date: Mar 2012
03-22-2012, 03:32 AM | #64 |
Drives: 2012 45th 2LT RS Join Date: May 2011
Mines only when going into 3rd
Sent from my iPad using Tapatalk
03-22-2012, 06:37 PM | #65 |
The Bolt-On Beast
Drives: 2011 2SS/RS IBM w/CGM Stripes Join Date: Jul 2010
OEM Hurst, no grinding issues.
2011 2SS/RS 6M Imperial Blue Metallic|Cyber Gray Metallic Stripes|Gray Interior|Factory (KAE) Hurst Short Throw Shifter|Sunroof
MODS - 1LE Track Pack Suspension Upgrade|Kooks Custom Stepped Headers & HFCs|Cold Air Inductions Black CAI|ADM Performance Scoop|Vmax IBM CNC Ported Throttle Body|Rx Extreme IBM Catch Can & Breather|Borla S-Type Catback Exhaust w/Solo J-pipes|IBM Heritage Grill|LG ZL1 10 Spoke Replica Wheels w/Goodyear Supercar G2 Tires|Z/TA Rear Spoiler|463RWHP/459RWTQ Tune by Dale Cherry |
03-27-2012, 10:56 PM | #66 |
Drives: camaro Join Date: Feb 2012
grinding into 2nd (prominent when car is cold, or car has been sitting; whether rpm is low or high)
sometimes refuses to go into 2nd (prominent when car is cold, or car has been sitting; whether rpm is low or high) sometimes drops out of second into neutral (at high rpms). hurst. |
01-16-2013, 06:25 PM | #67 |
Drives: 2010 2ss 6 speed Join Date: Apr 2011
MGW
2010 2SS WITH MGW SHIFTER
EVERYTHING WORKS GREAT |
01-25-2013, 12:26 PM | #68 |
Drives: 2011 2ss conv. red jewel, 69 ss con Join Date: Jul 2012
did it with oem and hurst. Dealer said they know its a problem with the trans. (1-2 synchros) but they will not touch it with the shifter. Going to put stock shifter back on and try again.
02-11-2013, 10:40 AM | #69 |
Im a noob
Oem hurst. Only when cold. Always notchy.
02-11-2013, 10:53 AM | #70 |
Always a lil notchy when til the tranny warms up. Waiting on my order of Redline fluid. A lot of positive feedback indicating that it helped. Certainly can't hurt.
MGW shifter. Raising the knob just a little higher helped also since there's better leverage being applied. Sent from my SPH-L710 using Tapatalk 2
2010 Camaro 2SS/RS | RotoFab CAI | ARH 1 7/8" LT Headers w/ HFC | SW Retro Exhaust | ZL1 Shifter | Ridetech Coilovers | FE4 conversion | UMI toe rods & trailing arms | Prothane Subframe & UCA bushings | Detroit Speed sways | Forgestar F14 wheels | ZR1 Blue Calipers | Tuned by ADM Performance SSeric's Build Thread |
Similar Threads | ||||
Thread | Thread Starter | Forum | Replies | Last Post |
Rear End Gears 101 | danhr | V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) | 92 | 06-02-2021 04:17 AM |
Another TR6060 with 2nd gear grind | DRG BSTN SQUIRREL | V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) | 9 | 12-16-2011 03:41 PM |
2011 2SS/RS Problems: Engine Squealing, Brake Squealing, 1,2 Gear Grind. Please Help. | qniknam | V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) | 4 | 10-30-2011 10:36 AM |
2nd gear and Reverse of Fiero grind/won't go into gears. Any takers? | Arachnyd | General Automotive + Other Cars Discussion | 0 | 03-20-2011 01:05 PM |
3rd gear grind ? Only 3000km | Inferno Orange SS | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 22 | 12-28-2010 03:25 PM |
