10-20-2020, 09:10 AM | #15 |
And I think you missed mine: valve cover choice was not something to overlook when installing a catch can.
10-20-2020, 09:11 AM | #16 | |
So yea if you run SE valve covers, then you might need to put a restrictor in-line so the CC(regardless of brand) doesn't fill with oil.
2016 NFG 1SS A8
10-20-2020, 09:32 AM | #17 | |
10-20-2020, 12:16 PM | #18 | |
Drives: 2019 ZL1 Join Date: Mar 2019
No one knew the new MM catch can was designed differently which is why there was issues, the previous model didn't have issues with the same valve covers. I didn't install it, a shop did. No one knew. The only other one they did with the newly designed can was a fully built z06 with big cam which didnt have the issue (same covers). |
10-20-2020, 12:41 PM | #19 | |
10-20-2020, 03:44 PM | #20 |
10-21-2020, 11:00 AM | #21 | |
Drives: 2019 ZL1 Riverside Join Date: Apr 2020
Everything is relative so "no issues" doesn't really mean anything. How does your blower lid look when removed? Is there oil blowby getting past the can? That's the real test - as well as inspection of the valves for coking |
