TireRack
Old 09-15-2009, 05:52 PM   #1
SS Mike
SS Mike's Avatar
Drives: 2010 Camaro SS/RS CGM M6
Rattle in the trunk!!! Not from the spoiler!!
So a few weeks ago, a good friend from this forum had me check my spoiler bolts to make sure they were all tight. 2 were loose so we tightened them up. I thought all was good, until a few days ago I kept getting a strange sound when I opened my trunk. It didn't sound like something inside, it sounded more like leaves being crushed on the sides of the openeing I know that sounds weird, but that's just what it sounded like! So I checked all the spoiler bolts, all there and tight. Anyway, a couple days ago as I was accelerating from a stop I heard it loud and clear, something was rolling around INSIDE the trunk lid!! So now I guess I have to take off the trunk and see if I can get whatever it is out. Anyone else have this issue?
Vortech V-3 Kit, ARH LT's, Custom Exhaust, Aeromotive A1000 Fuel System, Custom Tune - 582 rwhp 533 rwtq
22" Modulare H2 Wheels, CF Hood, Trunk, Spoiler & Roof by Carbon by Design, Custom Steering Wheel from P-Factor
Brembo GT BBK, Alpine INA-900, Alpine Type-R Speakers, Hurst Shifter, APR Splitter, Custom Quad Tip Diffuser
CKS C1 Coilovers, Falken 452 Tires, 265/35/22 & 285/35/22, Custom Grille, AAC Halos, and much more to come!!
SS Mike is offline   Reply With Quote
Old 09-15-2009, 05:53 PM   #2
Scott@Bjorn3D
Scott@Bjorn3D's Avatar
Drives: Kami, 2013 2SS LS3 Luvin
Send a message via MSN to Scott@Bjorn3D
There are 6 nuts to tighten. I bet you only did 4.
Scott@Bjorn3D is offline   Reply With Quote
Old 09-15-2009, 05:55 PM   #3
SS Mike
SS Mike's Avatar
Scott, you're awesome! You are correct. I will find the other 2, most likely only one now. I'll let you know, thank you sir!
Old 09-15-2009, 05:58 PM   #4
Scott@Bjorn3D
Here is a trick to get the other one that came off. Slightly pull the carpeting out and the bottom of the trunk lid and it may fall in your hand. Then of coarse you have to take the carpeting off to get it back on and tighten the other one.
Mine feel in my hand.
Old 09-15-2009, 06:06 PM   #5
SS Mike
SS Mike's Avatar
Great tip, thank you. I will try it tonight. So you got yours out pretty easily then?
Old 09-15-2009, 06:18 PM   #6
BBQTriAngle
BBQTriAngle's Avatar
Drives: 2010 IBM SS/RS
I got this too, sounds like a marble moving when i open and close the trunk
BBQTriAngle is offline   Reply With Quote
Old 09-15-2009, 06:55 PM   #7
rickerda
rickerda's Avatar
Drives: 2010 Camaro 2LT RS
You may need a telescoping magnetic retrieving tool, You remove trunk lid liner (or just the bottom corner) Insert the magnet towards the lower corner of the trunk lid, you should hear the magnet pick up the nut Remove the tool and nut. Reinstall the nut.
Notes: There may be more than four nuts, there may be two in the middle for a total of six. Also there may be extra nuts, dropped when it was installed or replaced by someone that didn’t retrieve the original nut.
rickerda is offline   Reply With Quote
Old 09-15-2009, 06:56 PM   #8
SS Mike
SS Mike's Avatar
Yea, exactly, pretty annoying!!
Old 09-15-2009, 06:57 PM   #9
SS Mike
SS Mike's Avatar
I had one of those tools, but I lost it. If I can't get it out, I will go pick one up. Scott said above that there are 6 nuts total.
Old 09-15-2009, 07:01 PM   #10
two_wheel_mayhem
Would rather be riding
two_wheel_mayhem's Avatar
Drives: No car no more
You will need to do something to keep them from coming loose again.
I tightened mine once without anything and a month later they came loose again, so I used loctight.
Others have used nylock nuts.
I used to see spoilers and ground f/x bolted on with some kind of sealer/black goop on the bolts. I think thats why they come loose, GM used no sealer..just metal to metal
two_wheel_mayhem is offline   Reply With Quote
Everyone with a Spoiler... PLEASE READ! mlee Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 116 07-06-2013 09:48 PM
SLP 2010 Camaro ZL575 supercharged -- unique aero parts & "SS" on grill nUcLeArEnVoY Camaro Photos | Spyshots | Video | Media Gallery 129 04-22-2010 02:59 PM
Answers to people asking about the highwing spoiler; DJ ATOMIX Cosmetics and Lighting Modification Discussions 21 06-29-2009 07:46 PM
Request for spoiler mount pictures KK2010SS Camaro Photos | Spyshots | Video | Media Gallery 2 05-27-2009 10:35 AM
