12-10-2014, 12:01 AM | #43 |
Iron fist, lead foot
Drives: 2003 Mustang Cobra Join Date: Jul 2013
Why would the drive train be heavier? The 5.2 is NA (no sc of turbo wiring, tubing, or piping), the Tremec 3160 weighs 115lbs(dry) vs the MT-82's 123.5lbs(dry), it'll sadly have the same 2-piece drive shaft (so no loss, but no gain either), and the diff used in all current Mustangs, the "Super 8.8" (9.75" guts in an 8.8" housing) is more than stout enough for GT350 duty.
The other two, wheels/tires and the brakes? Yeah, those will be heavier. How much more is to be seen. I then have to wonder what efforts we're put into action to counter these slight gains. Doesn't seen as though itd have to be all too extreme.
12-10-2014, 02:23 AM | #44 | |
Drives: 13' 1LE Join Date: Apr 2012
I think its gonna weight the same or 50lbs more max. Nothing major.
13' 1LE
Old setup: TSP 231-236/Tick 660/.105 PR, UDP, SW LT 2'' & HFC, stock NPP & H pipe, VR-DRX CAI, air scoop, Goertz1 manifold, 102mm BBK, 26" Toyo DRs, Forgestars R17x10 & F18x8, rear seat delete, remote Pat G tune Autocal, 7400 limiter, Spec Mini Twin. 91oct. 11.90@122.3, 0-60ft 2.0 / 11.99@123.6, 0-60ft 2.1 DA+819 ...519RWHP SAE Solid roller SBE LS3, FED, LLSR, 91oct, 605rwhp N/A. Tuned by Pat G. Build by me. |
12-10-2014, 09:11 AM | #45 |
Drives: some to distraction Join Date: Sep 2011
I think the "specially-reinforced block" may be heavier. Whether they saved any weight with its unique heads and intake and exhaust remains to be seen. They did save some weight with the 3160, and smaller-diameter dual-mass clutch, but the 3160's reduced capacity will limit power-producing mods or may necessitate a swap to the heavier MT-82 or T-6060, depending on power levels sought.
12-10-2014, 09:19 AM | #46 |
12-10-2014, 09:24 AM | #47 | |
Drives: Current Camaro-less Join Date: Jul 2014
12-10-2014, 10:04 AM | #48 | |
BTW, SID should have been a little better prepared. It would seem he's a little star-struck @ having a filmed one-on-one with Hameedi, who generally puts his pants on, one leg at a time. |
