01-10-2018, 10:11 AM | #1 |
Drives: LSx Powered Join Date: Oct 2009
HPA Tuned ZL1 (not all tunes are created equal)
We had a very clean ZL1 that was just purchased a few days ago by a customer that contacted us wanting it checked over as it just didn't feel right to him. We did a base pull for him to see where the car was, and to see if we could experience what the customer was feeling. Needless to say it was very rich and had a lot of other issues in the tune. We swapped plugs and properly tuned the vehicle for our customer. Needless to say Huge gains were made in just a few hours.
01-10-2018, 10:20 AM | #2 |
Drives: 2013 ZL1 and 2019 Ram Laramie Join Date: May 2017
Wow. Plugs and a tune for 160rwhp and 180rwt. I'm in!
Hopefully no damage was done to the engine prior to your tune. |
01-10-2018, 10:31 AM | #3 |
Drives: 2010 Camaro SS/RS Join Date: Mar 2014
got pics of the plugs that were pulled from the engine? what could have caused the tune to get so out of wack?
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53 |
01-10-2018, 11:22 AM | #4 |
Drives: 2013 ZL1 M6 Join Date: Sep 2016
Maybe the previous owner took aftermarket items off of the car before they sold it and didn't do anything with the tune.
Fast 850cc Injectors, ATI Balancer, 8.66 Lower Pulley, 2.55 Upper Pulley, Lingenfelter CAI, Kooks LT with cat delete pipes, Noweeds Exhaust Cutouts (extremely loud under full throttle), BTR Stage 3 Cam, BTR Platinum 660 Valve Spring Kit, TR7ix Iridium Spark Plugs, Lingenfelter Solid Isolator, 160 Degree Thermostat, Larger SC Coolant Reservoir with Hose Relocation Kit, BMR 1.25" Lowering Springs, MGW Short Throw Shifter, Racing Brake 2 piece rotors front and rear, Starkweather Performance Custom Dyno Tune on 91 Octane.
691.38 RWHP 630.35 RWTQ |
01-10-2018, 11:39 AM | #5 |
fo'shizZL1
Drives: 2017 ZL1 Join Date: Aug 2017
Crazy. It looks like redline was set at 5500 in the original "tune"
2017 ZL1 M6 Black | Maggie 2650 // 103TB // Big Gulp
Past Rides- 2014 ZL1 M6 Red Hot | Tons of mods 2004 CTS-V M6 Silver | Many mods 1995 Corvette M6 Torch Red | A few more mods 1992 Camaro M5 White | A few mods |
01-10-2018, 12:02 PM | #6 |
I'm betting a reset to stock job?
Or maybe cracked plug? |
01-10-2018, 03:34 PM | #7 |
We aren't to sure exactly what mods were on it prior or who tuned it before the customer bought it. The customer brought the car to us to do the tuning. We found it was running extremely rich on the baseline pull
01-11-2018, 09:33 AM | #8 | |
Drives: 2013 VR ZL1, M6 Join Date: Nov 2017
Peak power on these cars don't usually happen until around 6000rpm. The power curve of the baseline pull is awful to. What was smoothing set to on both pulls?
#3257 | 485whp 526wtq | K&N 63-3079 | Gates K080660HD (Green Belt) | ACDelco UPF48R | ZL1 Addons Wicker Bill | Mild2Wild
01-11-2018, 11:13 AM | #9 |
We stopped it because there was no need to pull it any further with what logging was showing. Smoothing was set to 5 and the car never left the dyno on the baseline pull to the final pulls.
02-04-2018, 08:33 PM | #10 |
Drives: zl1 blk Join Date: Nov 2017
Do you know what mods have been done to this to make such good power ?
02-06-2018, 03:11 PM | #11 |
Drives: HSV LSA Gen f gts Join Date: Oct 2016
There are tuners and there are tuners, you need to find a tuner that is the best, that can only be done by other guys who have had tunes and producing the perfect tune.
I had my LSA with cam, injectors, pulleys, intake and double springs. I had it remotely tuned by a guy in Australia called Luis sola he does it via a link to your laptop, you will need a wide band connected in the Exhaust with EFI live, it is the only way you can get a perfect tune, this is my tune after Luis done his magic, he also has a Facebook page called LS tuning, it has a lovely curve and the AFR is perfect. |
02-06-2018, 07:30 PM | #12 |
Drives: 2019 ZL1 Join Date: Dec 2016
Wow, that’s amazing
