Old 03-31-2021, 10:56 PM   #1
zupesterLT1
2018 Convertible ZL1
zupesterLT1's Avatar
Drives: 2018 ZL1 Convertible
Will tuning void my warranty?
I have a 2021 Camaro LT1 and I am interested in tuning and dyno. Will having my car tuned void my warranty?
zupesterLT1 is offline   Reply With Quote
Old 03-31-2021, 11:47 PM   #2
Sorange
Sorange's Avatar
Drives: 2018 ZL1 1LE
Yes, Tuning does void warranty
Sorange is offline   Reply With Quote
Old 04-01-2021, 12:04 AM   #3
Puddin
Only the power train portion of the warranty.
Old 04-01-2021, 12:26 AM   #4
2SS Capt
2020 Shadow Gray 2SS
2SS Capt's Avatar
Yes. (that is a period, so, YES.)
2020 SGM 2SS - A10, NPP, MRC, Red Calipers, Black Camaro Fender Badge, Footwell Lighting
Added after delivery: - GMP CAI, GMP Black Strut Tower Brace, MRR017 1LE Wheels, SS Armrest, Black Fuel Door, Stainless Sport Pedals, SS Wheel Caps, Black Lugs/Locks, GM Splash Guards, DD Smoked LED Markers, Smoked Rear Reflectors, Mishimoto Catch Can, Xpel PPF - Full Front, SunTek 35% Tint, CeramicPro coating, RST Stainless Brake Lines, Castrol SRF, MSD Super Conductor Wires
Left: My "fun" ride. Right: My "work" ride: a Gulfstream G600. One's top speed is 180 Mph, the other, 620 Mph...
Old 04-01-2021, 05:30 AM   #5
CHASLT1
Drives: 2021 Camaro LT1
Any tuning will kill it. Soon tuning will be done away with anyways.
CHASLT1 is offline   Reply With Quote
Old 04-01-2021, 07:12 AM   #6
Chrome383Z
Chrome383Z's Avatar
Drives: 2019 Camaro 2SS
This is what I’m worried about. I’m thinking about pulling the trigger earlier then I planned so that I can get it tuned.
2019 Shock 2SS A10. 2650@10psi/LPE HPFP/XDI+30/LT4 LPFP+JMS/Soler 95mm/Rotofab, E65, CSP 2” Headers/GESI GenII Cats. MM Wild/GM SG3 suspension/1LE Brakes, Velgen VF5 Wheels/GY SC3. JRE Tuned.
Chrome383Z is offline   Reply With Quote
Old 04-01-2021, 07:32 AM   #7
SJFGTO
Oh Oh it's Friday Night!
SJFGTO's Avatar
Drives: 2018 ZL1 1LE Nightfall Gray
Wait until you add mods that require a tune, typically that starts with long tube headers. That way you won’t have to get tuned again when you mod for the first time. When you do get a tune, make sure you invest in a dyno and street tune. Simply tuning off the dyno leaves HP on the table and can result in some drivability issues. Tuning a totally stock vehicle will pick up some HP but it is not a cost effective option in my opinion.
Four that wanna own me
Two that wanna stone me
One says she's a friend of mine...
SJFGTO is offline   Reply With Quote
Old 04-01-2021, 08:30 AM   #8
Dathomas94
Drives: Camaro 2021 ZL1 6 speed ragtop
What do you mean “ soon tuning will be done away with”? Please explain
Dathomas94 is offline   Reply With Quote
Old 04-01-2021, 08:36 AM   #9
Puddin
He's being a little dramatic but to answer your question it's getting harder to crack these new ecus and with the push for electric/epa restrictions some people think tuning is on its way out.
Old 04-01-2021, 08:38 AM   #10
Tricksta
Tricksta's Avatar
Drives: 2018 ZL1 A10
Last I knew, you currently cant tune 2021?
Modifications
GM Dark Tail Lights / 3rd Brake Light & Reflectors | LED Reverse Lights | Diode Dynamics Side Markers | Borla "ATAK" Cat Back Exhaust
Tricksta is offline   Reply With Quote
Old 04-01-2021, 08:43 AM   #11
Doc Oc
Drives: 2017 Camaro 2SS
The Magnuson Act says they have to prove that the modified part caused the failure so there may be some gray area depending on the problem but don't expect much. Depending on the dealer they may not go right to the ecu on an otherwise stock vehicle and you might get lucky, never know. But a major powertrain failure they'll definitely look so you need to be prepared for the worst or don't do it.
My dealer has covered the a8 shudder issue, a broken afm valve, and a noisy rear end knowing full well I'm modded. But if my engine pops I'm not even going there.
2017 2SS A8 TSP LT's, ported msd/95 mm, e85
Doc Oc is offline   Reply With Quote
Old 04-01-2021, 10:33 AM   #12
MatthewAMEL
MatthewAMEL's Avatar
Drives: 2023 CT5 Blackwing
And don’t believe people who tell you it’s possible to fool the dealer by just flashing back to stock.
The tool the dealer uses can see flash counts on the ECU. There is also a checksum that changes every time the ECU is written.
2017 HBM SS 1LE
Sold
2023 Wave Metallic
CT5-V Blackwing M6
Old 04-01-2021, 10:44 AM   #13
L78toLT1
L78toLT1's Avatar
Mat is correct that you can't fool the dealer. You cannot get too complacent when dealing with mod friendly dealers either. If you scatter the motor, GM has to approve the replacement and you can bet that they will want to see the flash count.
Baby Blue
Old 04-01-2021, 11:06 AM   #14
LT4Greg
LT4Greg's Avatar
Drives: 2017 Camaro ZL1 Coupe
Yes tuning will void your warranty but if you’re not concerned about losing it, then tune away!
