Old 05-01-2018, 07:52 PM   #15
USAFS197
USAFS197's Avatar
Drives: 2018 Audi TT RS
Do you guys do different blower hats than the ones that say corvette on it? Also, if you guys could PM me with the price of this build overall, that would be awesome. I also have a 2018 1LE.
2018 Audi TT RS
2019 Audi RS3
About as fast as the TT RS
2019 Camaro ZL1 1LE
Sold
2018 Camaro SS 1LE
Sold
2019 Corvette Z06
Sold
Sold
Old 05-02-2018, 09:44 AM   #16
asthmamax11
asthmamax11's Avatar
Heat soak spinning that little lt4 like that
16 1SS M6 White
Magnuson 2.3 Heartbeat
Roto Fab
Hurst short shifter
#'s coming soon
Riaction coilovers
1LE sway bars
BMR mm
BMR chassis brace
02 Z28 M6 35th anniversary
80k miles
T-tops
Leather
Bolt ons
Daily Driver
Old 05-02-2018, 12:52 PM   #17
RideZX6R
Probably tired right now
RideZX6R's Avatar
Drives: 1Lap1LE | EV6 FE | 18 F150
...at 9psi? which is stock IIRC
Not really.
-Seven
'17 SS 1LE - 1LAP 1LE (Now with more 427!)
'18 F150 Platinum Powerstroke diesel
'22 Kia EV6 First Edition
'18 RS3 (1 of 2) Cumulus Blue
'24 911 T (ordered)
Formers...
'19 RS5 Sportback Sonoma Green | '07 Cayman S 6MT | '16 Audi S3 Prestige Viper Green (APR Stage 3+) | '19 Mustang Shelby GT350R | '17 SS 1LE MBM 575whp all-motor
RideZX6R is offline   Reply With Quote
Old 05-02-2018, 08:10 PM   #18
ADM PERFORMANCE
Drives: Anything I want
They start at $6995 installed and tuned.Lids without corvette are $100 extra
ADM PERFORMANCE is offline   Reply With Quote
Old 05-04-2018, 06:50 PM   #19
ADM PERFORMANCE
Originally Posted by MIAMI2SSRS View Post
Thank you for sharing the info on this build. Awesome numbers!!
As per you description this is a 2018 1LE. I have a M6 1SS. If you don't mind me asking, what other parts/components would I needed to get this results or similar with my car?
Thanks in advance.
The only additional part you don't have is the 1LE FPCM and 1LE/ZL1 Fuel Pump in tank.
If you do the rest exactly as stated you will be fine.
Old 05-04-2018, 07:41 PM   #20
MIAMI2SSRS
MIAMI2SSRS's Avatar
Drives: 2016 Black 1SS Camaro
Thank you for the information. I appreciate the it.
2016 Camaro 1SS M6 with MRC and NPP.
“Two things are infinite: the universe and human stupidity; and I'm not sure about the universe.”
Albert Einstein
MIAMI2SSRS is offline   Reply With Quote
Old 05-04-2018, 09:39 PM   #21
Hard Parker
OMWTFYB
Hard Parker's Avatar
Drives: ZL1
Are you not worried about pistons?
2017 Camaro 1LE Nightfall Gray Metallic RIP ☠️☠️☠️
2017 Camaro ZL1 Black Exposed CF|Sunroof|6 Speed
Click HERE to follow my build!!
Click HERE to follow me on Instagram
#savethemanuals
Hard Parker is offline   Reply With Quote
Old 05-05-2018, 09:16 PM   #22
ADM PERFORMANCE
No.
Old 05-07-2018, 04:28 PM   #23
RideZX6R
RideZX6R's Avatar
Honestly it's the ring gap you worry about - not the pistons themselves
-Seven
'24 911 T (ordered)
Formers...
Old 05-07-2018, 05:41 PM   #24
Eldi Z
Drives: 17' 1SS 1LE GBA-Black
So how to determine the ring gap on the OE pistons? Motor must be stripped and pistons removed to check the rings...
Old 05-08-2018, 12:18 AM   #25
RideZX6R
RideZX6R's Avatar
Most aren't doing the work themselves and figure "well if I'm pulling the pistons out anyways to do ring gap" - they pay for drop ins.
But the core issue is ring gap that is too tight and/or inconsistent
-Seven
'24 911 T (ordered)
Formers...
Old 05-08-2018, 08:31 AM   #26
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Most of the failures that get blamed on the LT1's piston rings are actually due to not enough fuel supply. If you research hard and long enough, most failures have been around 600whp and the engine was still using the stock HPFP, Injectors, and Low side. The problem is on the Dyno the fuel supply looks good. However after a few long pulls out on the street, the engine pops a ring because pressure started dropping and injector pulse went above the safe threshold, so the increased heat pinched a ring.
I am not saying the LT1 does not have tight or inconsistent ring gaps, but the engine overall in most cases can handle some power when setup correctly. Do Not Skimp on the fuel system and it will be happy. Also do not rely strictly on Dyno tuning...get the car on the street and make some high gear pulls with a Data logger.
2016 NFG 1SS A8
Options-2SS Leather/NPP
Old 05-15-2018, 11:37 AM   #27
RideZX6R
RideZX6R's Avatar
Either way pistons are a safe drop in.
I'm gonna be likely above 650whp, so I did a full LT4 fuel system, cam fuel lobe, and pistons - So this scenario doesn't necessarily apply to me
-Seven
'24 911 T (ordered)
Formers...
Old 05-15-2018, 08:55 PM   #28
KingLT1
KingLT1's Avatar
for sure...nothing wrong with doing pistons. I was just saying that more LT1 failures are due to lack of proper fuel system and not the Piston rings. I'm right behind you...just paid off my car, now I have to decide which way I want to go.
2016 NFG 1SS A8
