12-29-2016, 05:48 PM | #29 |
Drives: 16 2SS 6MT NPP MRC / 15 K1300S Join Date: Mar 2016
Replacement or supplemental lift pump?
Rohana RFX-5 10/11, M/T 275/305, Eibachs, Hellwigs, Hurst SS, DMS LT4 SC 596HP/589TQ, DMS Low-side, Kooks 2LTs, MBRP Race, Rotofab, MMS CC |
12-29-2016, 06:17 PM | #30 |
Drives: 2016 Camaro SS Join Date: Oct 2016
Very nice! Very tempting.
12-30-2016, 02:38 AM | #31 |
Drives: '16 2SS GD1 MX0 NPP F55 IO6 Join Date: Jun 2013
Has the first car turned the pistons back into powder yet?
Kit + pump + E85 - cam = 675 to the wheels? Scary... |
01-13-2017, 11:52 AM | #32 | |
Too much is never enough!
Drives: AGP TT SS [COTW] 4/20/15 Join Date: Feb 2014
750whp is at the moment, what is widely considered safe, or the limit for the LT1. And there are people above that.....675 is easy. Adding meth, and e85 only lets you run more timing...=more horsepower...safely. So why would that contribute to it? Ask Jessrayo if his pistons have gone to powder yet? I believe it's him that has the first one that was done by AGP, he is not affraid to drive it hard, nor is he scared of spending money on an engine.
AGP TT kit, 54/57 Forged rotating assembly, Custom grind cam... Dual nozzle meth, ID850's, Livernois dual fuel pumps, ECS BAP, 25% UDP, 3 inch Magnaflow catback with X pipe, Mantic 9000 clutch, DSS 1000hp axles, DSS aluminum driveshaft, ZL1 rear end, solid subframe bushings, HE differential offset bushings, BMR Trailing arm, BMR toe rods, Lingenfelter LNC-2000,SJM Line Lock. 747 whp 714wtq
Build thread http://www.camaro5.com/forums/showth...55#post8107855 |
01-13-2017, 03:08 PM | #33 | ||
Speed Freak
Drives: 2013 ZL1 Camaro, 2016 Camaro SS Join Date: Jun 2013
The lift pump is a separate line with external pump run in parallel to the stock line. The external pump can be heard at times but keeps line pressure up well into the limits of the LT4 mechanical pump on stock cam lobes.
The short answer is that the pistons are holding up fine so far. Almost 7000 miles right now. I will confess that it is currently running the 650 whp pump gas tune though and not the 730 whp race gas tune. Quote:
I'm no stranger to engine work....lol. My 2013 ZL1 is in for its 4th engine rebuild right now. Going over 1200 whp has been hard on engines. Last trip to the Texas mile fractured the head casting and then leaked the coolant into a cylinder.... at 200 mph. If the LT1 turns the pistons to powder I'll rebuild the whole bottom, forged with lower compression pistons....but so far the AGP kit on the LT1 is unbreakable. And the car is fast.
2016 SS -AGP twin Borg Warner 7163 EFR's, LT4 mechanical pump, LT4 injectors, Walbro 255 low side, Castrol SRF. 734whp/759 tq
2013 ZL1 -ADM - 427 LSX 6 bolt, O-ringed block built by LME. Twin PT6466 turbos. RPM custom manual trans, RPS Quad carbon clutch, 9" Hendrix rear diff & axles. ADM/squash fuel system, Ron Davis radiator, Spal fans, AGP air to air, turbo plumbing. LPE oil cooler, rear bushing upgrade, roll bar...etc. rwhp 1400+... 212.5mph, best Texas mile to date. |
01-13-2017, 05:39 PM | #34 |
Drives: 2016 Camaro SS M6 w/ NPP Join Date: Jun 2016
I have about 10,000 miles on my build. No piston dust yet.
Whipple 2.9, Custom New Era Performance cam,
E85, LT4 fuel system, Motec powered port injection, teeny tiny Nitrous Outlet system, Stainless Works LTs, Centerforce Triad, GForce 9" with strange pro case 3.50 gears. Carlyle 15" conversion 28"x10.5" MT ET Drag 28"x4.5" M&H fronts PB: 9.569 @ 151.05 |
01-13-2017, 11:46 PM | #35 |
Just like the LS3 the LT1 will take time to show people what it can and can't take.
02-06-2017, 12:55 PM | #36 |
Drives: 2007 335i Join Date: May 2016
Has anyone heard anything from AGP? I tried checking the thread in the classifieds, but get an error. Seems the thread was deleted? I had the same problem with another thread, but was able to open it by going to a different page of the thread. Possible site issue?
02-06-2017, 01:06 PM | #37 | |
Drives: 2019 Dodge Challenger Scat Pack Join Date: Jun 2016
"Submariners are a bunch of intelligent misfits that somehow seem to get along, understand each other and work well together." - overheard from a surface officer explaining to another sailor about Submariners
02-06-2017, 01:26 PM | #38 |
Thought that might be the case. Probably just invalid links. I'll try checking from my computer, kind of hard to check from my phone.
02-06-2017, 02:00 PM | #39 |
Drives: All things Turbocharged Join Date: Dec 2010
Camaro6 just started their sponsorship requirements. So they killed all old sales threads from before sponsorships started. We a few kits complete and a few more kits that we have only shipped partials to. Email us directly if you have any questions. Intercoolers and the last turbos are shipping today.
02-09-2017, 10:04 PM | #40 | |
#becauseracecar
Drives: 2016 SS Sedan, 2016 Camaro SS Join Date: May 2015
02-10-2017, 05:54 AM | #41 |
Drives: Black Join Date: Jan 2017
Fyi - drop in pistons to support well over 700whp
http://www.corvetteforum.com/forums/...-ring-kit.html |
02-10-2017, 07:51 AM | #42 |
FMPG
Drives: 2016 2SS Join Date: Dec 2015
This kit looks great and I can't wait to see what kind of 1/4 mile time it's able to hit. Hopefully more people go turbo. It's great to see different builds and what can be achieved with each of them.
I haven't been able to drive my car much since getting it back because of winter here, I did have a few nice days where I drove it hard and so far so good. The company that started all of that piston failure stuff after 700rwhp was also selling aftermarket forged pistons. It's hard to know what to believe. You could replace the pistons and then something else could go. It's also relative to how the person uses the car, the tune and the car itself. Once you start doubling the stock output of an engine I'd say all bets are off. The rods and other smaller components make sense to replace, but you'd probably be better off taking that money and putting it towards a different motor.
ARH 1 7/8" ceramic coated full sys w/NPP; Maggie 9.2psi (85mm); Jannetty rough idle cam(TSP), tune and LT4 fuel system; Forgeline VX1 Black PVD (20x10,11); R88R 315's; ALPriority; BMR rear arms, bushings, DS loop; RF intake (red); nGauge 93 octane: 712rwhp, 654rwtq / E85 (E66 mix): 734rwhp, 674rwtq (SuperFlow Dyno) |
