05-07-2016, 10:10 AM | #29 |
Too much is never enough!
Drives: AGP TT SS [COTW] 4/20/15 Join Date: Feb 2014
Jessrayo, I knew you couldn't leave the 6th gen alone! I followed your compound boost thread big time, it was a killer project.
AGP what gives? Word on the street is you have had a couple 6th gens in your garage....are they still there or have you delivered them to the customers? The greatest quote from a movie, IMO is from The Gladiator. When the Emperors sister tells him, "The mob is fickle brother, he'll be forgotten in a week. Give the people what they want brother." While I am certain, that this will not be forgotten in a week.....Kevin, give the people what they want brother!
AGP TT kit, 54/57 Forged rotating assembly, Custom grind cam... Dual nozzle meth, ID850's, Livernois dual fuel pumps, ECS BAP, 25% UDP, 3 inch Magnaflow catback with X pipe, Mantic 9000 clutch, DSS 1000hp axles, DSS aluminum driveshaft, ZL1 rear end, solid subframe bushings, HE differential offset bushings, BMR Trailing arm, BMR toe rods, Lingenfelter LNC-2000,SJM Line Lock. 747 whp 714wtq
Build thread http://www.camaro5.com/forums/showth...55#post8107855 |
05-07-2016, 01:46 PM | #30 | ||
Speed Freak
Drives: 2013 ZL1 Camaro, 2016 Camaro SS Join Date: Jun 2013
On totally stock LT1 car the high engine compression and fuel pump limitations mean you can only give it around 6 pounds of boost before it needs more fuel pump. The turbos I had installed are not hardly working at 6 psi so the turbo wastegates are open a lot at that setting. Originally he left the wastegates open but at 6 psi they are almost blowing open every time you touch the throttle. He is plumbing the wastegates back through the mufflers and putting a bigger lift pump in the fuel tank and then we will see what it does on the dyno. I'm told it drives great already. The small turbos are making boost as fast as the transmission can downshift so when you step on it, it just plain hits. Quote:
I can can tell you that this Gen6 has been a big project for AGP. A lot of little nuances on this car that have been complex, factory crushed exhaust, all the stock cooling... quad cats, direct injection, entire fuel system is pressurized differently. Really, if you ask any shop that has done a lot of work on the LT1, it is a completely different ballgame than the old LS. But having said that, I'm expecting my car to be done in two weeks. (It is scheduled for pick-up) So the fickle mob will soon see what my mild gen 6 turbo set-up looks like...
2016 SS -AGP twin Borg Warner 7163 EFR's, LT4 mechanical pump, LT4 injectors, Walbro 255 low side, Castrol SRF. 734whp/759 tq
2013 ZL1 -ADM - 427 LSX 6 bolt, O-ringed block built by LME. Twin PT6466 turbos. RPM custom manual trans, RPS Quad carbon clutch, 9" Hendrix rear diff & axles. ADM/squash fuel system, Ron Davis radiator, Spal fans, AGP air to air, turbo plumbing. LPE oil cooler, rear bushing upgrade, roll bar...etc. rwhp 1400+... 212.5mph, best Texas mile to date. |
05-07-2016, 02:11 PM | #31 | |
Looking forward To the results! And based on your last/ongoing build I'm excited to see how this one goes.
05-07-2016, 08:34 PM | #32 | |
Drives: 2016 Black 1SS Camaro Join Date: Jul 2012
2016 Camaro 1SS M6 with MRC and NPP.
“Two things are infinite: the universe and human stupidity; and I'm not sure about the universe.” Albert Einstein |
05-07-2016, 08:35 PM | #33 | |
05-08-2016, 12:30 PM | #34 | |
Speed Freak
I assume AGP will eventually have a kit designed to run at its maximum efficiency on the stock fuel system with only 6 pounds of boost. The thing about turbochargers is the turbo is an inertia system driven by exhaust gasses and not a belt like a supercharger. That makes them more efficient in the long run but to minimize turbo lag you have to be pretty specific about the size of the turbo you install. The further a turbo gets from it's peak efficiency the more you are going to feel it in the car. My ZL1 has twin turbos that can make 900whp each. If I tried to run them at 6 pounds of boost...they would come on so hard they would hit like shot of nitrous and then the wastegate would just open up and bleed all the "extra boost" into the atmosphere. Actually my ZL1 does this now if the supercharger is not on the car but it is a 1000whp shot. The turbos I have in my '16 SS are good for about 400-450whp each. So running the turbos at 6 psi and 550whp is still pretty far below the best efficiency of these turbos on my car. AGP is upgrading my first stage of fuel pump now. I have not seen a lot about this on the Camaro boards but the direct injection LT motors have a 2 stage fuel pump system where the LS motors just had the one stage. Direct injection must have a lot more pressure because the injector is spraying into a combustion chamber that is in a compression stroke where the old system sprayed into the air that was either atmosphere or boost. I don't remember my exact physics but one atmosphere is generally equal to around 15 pounds of boost so 15 pounds of boost with all other variables equal is about twice the air pressure. Well, LT1 is using 11 to 1 piston compression. That is potentially 5x more pressure than you are ever going to see in a LS fuel injection system. So LT adds another mechanical pump with camshaft lobes is what I'm told. On the "at the limit" builds on the Corvette boards getting fuel is actually more of a factor than the air. For years I have been saying that airflow available from the forced induction system has always limited max power potential of these engine. It seems I may have to change my tune to the real power limitation of these DI engines is fuel delivery. So far most of the forced induction kits are set up to give more air but it seems obvious to me at this point that some fuel system upgrades will be mandatory to tap into what these engines can really do with the air available from a supercharger or turbo. Within the next couple of weeks we will have results for my car with a lift pump upgrade. For the guys that know me, it probably is just a matter of time before the cam pump is upgraded. Once I start to mod a car, it can be a bit of an addiction for me.
05-08-2016, 01:14 PM | #35 |
Drives: '16 2SS / '05 SRT10 Ram / '65 bu Join Date: Dec 2015
Good write up jessrayo and I look forward to your results also.
Are you going with 1 7/8 headers and no mufflers ?
05-08-2016, 04:32 PM | #36 |
Speed Freak
I have never been the guy that really likes the loud cars. It used to be that all sound reduction limited power and the fastest cars were the loudest, but now you can make a lot of power without destroying anyone's hearing. I like that I can sneak into most events without being noticed and then when the lights turn green destroy most of the loud cars. I think I'm one of the few guys that really wants peak performance more than attention. I have always liked the quote from T. Roosevelt, "speak softly and carry a big stick". There are no headers on this build. The turbos really don't need headers unless you are looking for absolute max power or more sound. The stock NPP exhaust is still on my car and I'm told it is much quieter with the turbos in place. That is the way I prefer it.
05-08-2016, 04:38 PM | #37 | |
Always open for input and suggestions!! Thanks again and I can't wait to see your results!!!
“Two things are infinite: the universe and human stupidity; and I'm not sure about the universe.” Albert Einstein Last edited by MIAMI2SSRS; 06-02-2016 at 09:05 PM. |
05-09-2016, 08:21 AM | #38 |
05-09-2016, 09:51 PM | #39 | |
Drives: 2007 335i Join Date: May 2016
Now there's guys running 2 walbro 450s, in tank, with supplementary port injection driven off Hobbs switches. |
05-10-2016, 09:20 AM | #40 | |
Speed Freak
05-19-2016, 03:15 PM | #41 | |
Please, let us know. Thank you.
05-20-2016, 09:56 AM | #42 | |
Speed Freak
The guy I have been using as a car hauler had a death in the family so my scheduled pick-up had to get pushed back. I elected at the last minute to just fly out to Arizona and drive the car home so tomorrow morning I will be on the road for 1000 miles.... When I get home on Saturday night or Sunday I should have a very good idea about the car.
