Old 08-12-2018, 04:46 PM   #1
1QIKZL1
Drives: N/A
Cool 2017 ZL1 - Marble Sound in Front Wheels
All;
Looking for some input as today I heard what appears to be "marbles" sound when turning left and right at low speeds. No issues with stopping and no vibrations at higher speeds. Brakes? Rotors? Wheels? All lugs tight.
2017 Camaro ZL1-Silver Ice/A10/PDR/NAV/RF-Sold
2018 Traverse AWD-Silver Ice/V6/Special Order-Own
2016 Chevy SS Sedan-PBM/A6/Roof/Spare-#256-Sold
2014 Chevy SS Sedan-PBM/A6/RF/Spare-#326-Traded
2006 Suburban LTZ AWD-Traded
2005 Silverado LTZ 2500 4x4 Diesel-Traded
2003 Avalanche LTZ 4x4-Traded
1996 Corvette C5 Grand Sport LT4-#417-Sold
1996 Corvette C5 Collector Edition LT4-Sold
1989 Corvette C4 Red on Red - Sold
1QIKZL1 is offline   Reply With Quote
Old 08-12-2018, 06:01 PM   #2
nighttowl
Sarcasm loading --------
nighttowl's Avatar
Drives: 2018 ZL1 1LE
bad wheel bearing.
jack the front up and see if you can wobble the wheel at all in any direction.
2018 MBM ZL1 1LE - Stock
2014 CRT ZL1 574 rwhp, 537 rwtq - SOLD
2010 IBM SS Camaro VVT L99 w/ TR6060 swap, 489 rwhp, 444 rwtq - SOLD
nighttowl is offline   Reply With Quote
Old 08-12-2018, 06:25 PM   #3
1QIKZL1
Drives: N/A
Cool
Originally Posted by nighttowl View Post
bad wheel bearing.
Wow..ok..Already a wheel bearing failing..I guess it like anything - parts are parts and they fail..I kinda thought but dang..Thanks for idea - will check..
Old 08-12-2018, 06:59 PM   #4
LiqTenExp
LiqTenExp's Avatar
Drives: 2017 ZL1
2 piece rotors + loose front wheel nuts + maybe dirt/corrosion = your problem. Tq to 140 ft/lbs or remove/clean then tq and it should go away. TSB on this, search for the #
Old 08-12-2018, 09:35 PM   #5
cavalierssr
cavalierssr's Avatar
Drives: 2018 Camaro ZL1
+1
2018 Camaro ZL1 - Rotofab, Ported TB, Tune, 1LE smoked taillights/third brake light, JWM smoked sidemarkers, Solo Performance Cat Back Exhaust.
cavalierssr is offline   Reply With Quote
Old 08-13-2018, 08:34 AM   #6
Firehead640
DEVLMAN
Drives: White 2018 ZL1
It isn't your wheel bearings.
Just a torquing issue with the 2-peice rotors. Easy fix, had the same issue with mine.
Firehead640 is offline   Reply With Quote
