10-14-2022, 08:30 AM | #29 |
For some reason he did not print the chart (?!)
'20 ZL1 1LE A10.
LME 390, E2650, FBO, 100 oct. Not a DD. |
10-14-2022, 08:30 AM | #30 | |
Drives: 2017 Chevrolet Camaro ZL1 Join Date: Jul 2018
2017 ZL1 - PB 8.05 @ 172 MPH @ 3730 lbs @ 70 DA (work in progress)
Built by Vengeance Racing, tuned by Elite Tuned |
10-14-2022, 08:35 AM | #31 |
Bottom section of HPT:
I don't see where HPT captures back pressure at the exhaust valve, which might be helpful here.
'20 ZL1 1LE A10.
10-14-2022, 08:37 AM | #32 | |
'20 ZL1 1LE A10.
10-14-2022, 08:40 AM | #33 |
It does seem like at some point the car should have registered more power than before. The dyno plot would be nice. The MAP plot is good, fuel is ok enough (just rich), TPS seems fine, but the spark dancing like it does obviously isn't right. I can only think of something in the torque mgmt or traction systems causing that looking at the other data. Admittedly, I'm not a tuner, I just look at a lot of my own logs and consult with guys much smarter in this area than me and learn from that. Lol.
10-14-2022, 08:42 AM | #34 | |
Kong's first guess was slipping belt, but he had not seen the log and the MAP curve.
'20 ZL1 1LE A10.
LME 390, E2650, FBO, 100 oct. Not a DD. Last edited by JSH; 10-14-2022 at 10:34 AM. |
10-14-2022, 08:45 AM | #35 |
You said it gained boost and the graph doesn't show any variances as you go up in RPM. It just goes higher as it should. I'm going to say that's not it. If boost was lower than before that would make sense, or if it had peaks and valleys. To my previous point, I could show you a MAP plot before the 10 rib that looked fine and then after the 10 rib with no changes and MAP peak was higher. But in your case, its already consistently higher than you had before the change.
10-14-2022, 09:05 AM | #36 |
Drives: 2015 Camaro ZL1 Join Date: Oct 2020
Post the actual log file as an attachment.
If the throttle body was being pulled shut you would be able to see it in commanded vs actual in the log. Someone mentioned earlier that you may have cats? Is the true? |
10-14-2022, 09:23 AM | #37 |
MAP shows an increase through the curve all the way out to limiter. Doesn't look like belt slip.
Timing 21-22 degrees from 4000-6750rpm, should be making plenty of power with that. Fuel is rich, but not killing power. Just unnecessary strain on the fuel system. It's running about 5% richer then commanded so the MAF needs work. Throttle might be closing but I would think you would see a drop in KPA when that starts to happen. Crimp section isn't hurting much. It's flattened but widened so overall it's not much if any smaller in diameter vs the rest of the exhaust. I would still remove it. If it still has green cats, they are likely junk. I think I remember you saying that they were removed. Need to be logging more PIDS in plotter. MAT, Rail / low side psi, and Wideband should be plotted. Your SOI seems low for a Cam car. Might be causing the EOI to be a little on the low side? With your injector MS around 4.8-5ms range I would expect to see EOI in the 170-180's not 140. 140 is what I typically see with injectors in the 5.7-5.8ms range. Either way I don't see any of that causing that big of a loss in power. When you start talking about losing 100+ whp with more boost and potential flow, I think that indicates something more on the mechanical side vs tune.
2016 NFG 1SS A8
10-14-2022, 10:15 AM | #38 | |
No more green cats. They were mangled so we scraped them out.
'20 ZL1 1LE A10.
10-14-2022, 10:24 AM | #39 |
Drives: like an old lady Join Date: Jun 2012
965 @ 7k
850 & 5800 what power did it make @ 5800 on the first dyno?
10-14-2022, 10:30 AM | #40 | |
It essentially rolled over about 175-200 hp short of expected peak. Never seen this before. Lots of fuel, lots of air.
'20 ZL1 1LE A10.
10-14-2022, 10:32 AM | #41 | |
Too bad we can't see back pressure at the exhaust valve. Might it do this if traction control was on?
'20 ZL1 1LE A10.
10-14-2022, 10:35 AM | #42 |
Drives: Chevrolet Camaro Join Date: Apr 2022
What transmission? Clutch/trans slip?
Procharger P1X, CSP Big Boy Cam, CSP Headers, LT4 HPFP, LT4 Injectors, JMS BAP - 722WHP
