04-26-2021, 10:37 PM | #29 | |
I had checked the torque on every bolt I could reach with the aluminum plate in place. When I replaced the hose I torqued the remaining bolts. It would be nice if more people knew what caused their hose to fail. I’d really suggest anyone that has the time to check every oil pan bolt. I’ll check the 4-ply silicone hose I bought at the next oil change, if not sooner.
09-24-2021, 10:35 PM | #30 |
Just happened to me while doing some test pulls. The hose has a 2" slice in it. Went sideways. Pretty hairy. Looks like its part 12656725 for me. Going to the shop on Monday. I'm at 57k miles.
New Mods - GPI drop ins, Kooks 2", LT4 fueling, Cam, Circle D Converter, 3.5 pulley & dual nozzle meth. Last edited by grampa_ss; 09-24-2021 at 10:47 PM. |
09-25-2021, 09:36 AM | #31 |
Drives: 2017 1SS Hyper Blue Join Date: Apr 2017
I’m reading thru this thread, trying to get a sense on the cause. Is the common denominator here that the failure is occurring on cars that have had some work done, like headers, cam, etc. ?
09-25-2021, 11:16 AM | #32 |
Drives: like an old lady Join Date: Jun 2012
it is an issue i've read about since day 1. those bolts are loose when they leave the factory and/or they are very sensitive to torque values and loosen up over time.
09-25-2021, 03:31 PM | #33 |
Had the car in the air today and checked the silicone hose. Everything is dry and looks as good as it did when I replaced it last year.
09-25-2021, 03:34 PM | #34 |
good to know. what tool did you use to get the clamps off? it looks pretty tight in there.
09-25-2021, 03:48 PM | #35 | |
I will say that if I only had the dual hinged 45° needle nose pliers, I may have been able to get the clamp closest to the front of the car. But the hose clamp pliers kit sure helped too. https://www.amazon.com/Crescent-PSX2...2602734&sr=8-3 https://www.amazon.com/Pliers-Flexib...2602851&sr=8-1
09-25-2021, 03:53 PM | #36 |
Thank you!
09-26-2021, 09:49 AM | #37 |
Drives: 17 2SS, 8L90, Cam, Heads, E85 Join Date: Dec 2016
This is going to cause a lot of people who don't know any better and ones who don't pay attention to their car to ruin their engine. I think the LT1 will still overheat in limp mode though and I think the AFM will start cycling different cylinders to try to stop the overheating. I am not sure if it will eventually overheat and damage the heads or something else even when in limp mode. I am sure it probably would.
Mine did happen when I had my heads and cam on, but I don't think that had anything to do with it. I put a lot of miles on my car and I think I some of the first cars to get that much miles (80k+) and it eventually failed after so many heat cycles. I shouldn't have tried to limp mine home and should of towed it but it was really close to home. |
09-26-2021, 10:11 AM | #38 |
Drives: 22 Camaro 2SS, 20 Subaru Crosstrek Join Date: Aug 2021
Looking through this thread, it looks like everybody that has encountered the issue has a 2016 or 2017 based on their "Drives" info. Curious if Chevy has addressed this - have there been any reports on later model years?
Earth is an oblate spheroid
2022 | 2SS | M6 | NPP | Summit White | Carbon Flash Wheels | Black Lugs | Red Calipers | Adrenaline Red | Red Knee Pads | Nav | - 1100 - 8/16/21 - 3000 - 9/21/21 - TPW 10/18/21 - 3400 - 10/1/21 - 3800 - 10/20/21 - built 10/19/21 - 5000 - 11/12/21 - 6000 - 11/13/21 |
09-27-2021, 06:33 PM | #39 | |
In this case I'm not sure if there might be "political" reasons why they wouldn't make a TSB on it since its not a hidden issue that would be hard to diagnose. I think they mainly do TSB's to not have techs spending unnecessary time diagnosing things. If the hose fails or leaks you would either see it on the ground or you will eventually overheat which I fear could eventually kill a lot of motors. I am wondering if when mine failed and it ran at higher temps if it could have caused my intake valve seats failing, not sure how it would have but overheating can cause a lot of issues like that. |
09-27-2021, 07:10 PM | #40 | |
You’re welcome! I’ll also add that clamp kit is anything but Snap-On quality. But hey, it did the job.
This might be specific to the the years you mentioned. Maybe they changed to a braided hose or heat wrapped it after 2017. It would be worth someone sharing by poking around with a light and cellphone camera to capture an image. I’m sure any of us that addressed this could tell you real fast if it was updated.
09-27-2021, 08:22 PM | #41 |
It was really weird. I didn’t even know anything happened. Car didn’t go into limp mode. Temp gauge was normal. This is what happened.
Did a pull in 2nd gear at 45. All was good. Did another pull and rear end kick out hard, real hard, 90 degrees. Done lots of pulls on this same road for 4 years. Scared the hell out of me. Went home 1/2 mile away and noticed the fans running full speed. Popped the hood, looked clean, but coolant reservoirs empty. The driveway had a solid trail of coolant. Got under the car and started drying it up, then found the torn hose.
06-16-2023, 10:35 PM | #42 |
Drives: Chevy Camaro 2SS 1LE Manual Join Date: Oct 2022
I would make a heatshield.
Another item on the "if I ever mod it" list. |
